after a few years of stability with WD working it just stopped updating a few days ago. Having played around a bit (and after reviewing previous posts of the forum) there is no improvement.
History for this issue:
WD stopped working - first noticed wince the ftp uploads were not working to my website.
Going to WD (10.37S build 2) the station seting seemed to be unusual. Reset to Davis VP2, tried a few of the settings (baud, FW version, rain guage type etc but the best I get to is that the Green Data light is flashing but data quality is red and the data received index is not incrementaing as normal.
I then tried:
working with weatherlink current data and history is all working ok, The com port is 3, it’s in serial mode and baud rate is 14400
Going back to WD I checked the station setup and have covered the following:
making sure the comport is the same as weatherlink (Com3, 14400)
on the station setup using
0.2mm rainguage
Solar sensor
RevB FW
VP2 with FW update (beleived to be the case , but cheked both settings anyway)
checking that a baro offset has been applied (from another thread) - no difference. (5mb applied)
Then I updated to latest weatherdisplay to 10.37b81.
At this point WD looked a bit different to the previous version in that the WD main page was more completely populated, although some of the data was a wrong (no current temperature, max gust last hour had a time more than an hour ago, wind reading zero kts/north etc etc) . However the bahaviour is exactly the same - green blinking data received light , zero data count and red data quality light.
earlier I set raw data logging (on 10.37b2 and 10.37b81) and the file is empty
If I go to debug info from the control panel then there are hundreds of “asking for loop data now” messages
Any clues?
Russ
