Problem
I have the latest version installed and am using the Bavis Vantage Pro 2. Everytime the rain starts, my Weather Display crashes and stops recording anything.
Help please.
Thank you
Michael
when you say crashes, can you give more info?
(as I am bit confused by you then say it stops recording anything…does that mean its still running but not getting any more updates or that its not running at all?)
the more detailed information you can provide the better
The WD “freezes”. It does display the temp and the “data received” is blank (not flashing) and “data quality” is red. Further, after I restart WD, it does not show any rain recorded.
Thank you
is it still responsive?
i.e when this happens, what shows under view, program event log?
The event log is empty.
We are cu50" in 10 minutesently having a heavy thunderstorm. It has rained .50" i WD program. It stops, locks and I have to restar (several times).n ten minutes. The data is regestering on the console, but not in the WD program. It stops, freezes and I have to restart the program several times.
so the problem is occuring when rain (heavy) is being recorded?
