Is it possible for WDL to work under a different name than clientraw.txt?
Maybe clientrawdavis.txt.
If so how can it be done?
You should set the full path and name in the wdl-config.xml Example
<clientraw>http://www.abc.be/clientrawxyz.txt</clientraw>
<clientrawextra>http://www.abc.be/clientrawextra.txt</clientrawextra>
<clientrawdaily>http://www.abc.be/clientrawdaily.txt</clientrawdaily>
<clientrawhour>http://www.abc.be/clientrawhour.txt</clientrawhour>
See also http://www.weather-display.com/downloadfiles/Configuring_wdl.pdf page 13
OK
