Missing display
Brian
Had a power failure last night that turned WD computer off. When restarted and data downloaded from logger /display unit W@D display as per pfail 1
Convert this month’s logfile to datafile and the graphs will return, and see if that also corrects the rain data. Also may be a good idea to recreate the last 31 days graph data.
you should have hopefully a back of the settings file too
i,e the wdisplay.ini settings file
in the databackup folder
to copy across (when WD is not running)
