The current default text for the tag “%NOAAEvent%” is “NO CURRENT ADVISORIES”. Can I change the default text to “NO ALERTS”? If so, how?
Thanks much.
Thanks much.
Is this for your rss setup? If so as I recall that’s a php script which could easily handle the substitution (assuming it’s hard coded in WD).
it’s so much as hard coded in WD, its just what is provided
niko, yes it is for my rss NWS alert feed. I see that it is pulling it from “wdisplay.ini” and as Brian mentioned it is hardcoded. I’ll need to look at modifying the rss feed NWS alert script to make this change.
Thank you both for your responses.
