I have been running ConsoleWD on a Pi 2 for a few years. The file system got corrupted and I rebuilt Raspian and downloaded the latest 32 bit ConsoleWD for the Pi 2. It does not have a Deploy folder with the .so files to copy to /usr/lib and /usr/local/lib. When I ‘sudo ./consolewd’ it errors off because it can’t find libcom.so. I had that file from the older version backed up and installed it but still get the same error. So, probably a mis-match with the older version.
Is the lack of the the Deploy folder an oversight, or is it not needed with the newer version?
Thank you.
it is needed, yes
I will fire up my raspberry pi and check on the compressed files to see if its there or not
Thanks!
No rush. I set up consolewd on an Ubuntu desktop to get the weather station back online, until the Raspberry Pi is back working.
i have updated it now
Thank you Brian!
