Temp Wind Rain Chart
On the Temp Wind Rain Chart with the Year Data option chosen, the rain chart does not change when another year is chosen. The temp and wind charts do change to the correct year. There is no issue with the basic rain data, which shows correctly on the separate Rain Chart. I am using WD Version 10.37S76 on Windows 10.
I will do some testing
I haved fixed that now in the latest .zip update #-o
Thanks Brian, thats working fine now. Unfortunately, I have just noticed another aberration on the monthly option on the same chart. The current period is fine, but any previous month has the first day either blank or corrupted, and each days data is credited to the following date. The last day of the month loses its data entirely.
i will investigate as time permits and get back to you
give another .zip update a whirl, should be better
Thanks Brian, all sorted now.
Spoke too soon Brian, I am now getting date corruption on the current period setting. There are both missing and duplicate dates (see attachment). Funnily enough my other Client WD is ok, and both are latest version. Any thoughts?
Anyone else with similar symptoms ?
I’m not sure what’s going on here.
I’m sending my table, is that okay?
Yes, yours is ok. I’ve got a wonky calendar with date 16 missing, but with an extra date 28 and 6 !
