Author Topic: Cronweatherflow can not open local file for writing  (Read 758 times)
Offline thebaldgeek
  • Win NT 10.0
  • Chrome 68.0.3440.106
Re: Cronweatherflow can not open local file for writing
« Reply #15 on: September 04, 2018, 03:21:17 AM »
Brian.
Great work!
Thanks so much for taking a good look at it.
Working as expected. Data in the cron and data on the main weatherdisplay window.
Very excited.
Happy to test any other versions if you need.
Thanks again for your time. Greatly appreciate it.
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #16 on: September 04, 2018, 04:52:37 AM »
that's good
is that with the UDP  not set?
(does it work if that is set and then restarted?)
Offline thebaldgeek
  • Win NT 10.0
« Reply #17 on: September 04, 2018, 02:13:30 PM »
It works with UDP set Ok.
The only problem I can find thus far is that the solar radiation (and UV) is not coming in correctly (With or without UDP ticked).
It is just reading 0.0 Wm/2 all the time. But the weatherflow app shows it correctly, as does my raw udp data into Node-RED.
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #18 on: September 04, 2018, 06:25:11 PM »
I just tested here (cant test with UDP) using your ID
and UV and solar does show OK in the cronweatherflow program
do you see that data?
Offline thebaldgeek
  • Win NT 10.0
« Reply #19 on: September 04, 2018, 09:07:08 PM »
Here is a screen shot of what I am I seeing.
Note the lack of solar or UV.
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #20 on: September 04, 2018, 09:28:16 PM »
if you unset to use udp
does solar and uv show?
Offline thebaldgeek
  • Win NT 10.0
« Reply #21 on: September 05, 2018, 02:25:35 PM »
Had to wait for the sun to come up (Im in California).....
Sadly, even with the UDP unchecked, there is no solar or UV readings.
I can see it in my local UDP stream via Node-RED and I can see the readings in my WeatherFlow Android app.
Thanks for you time looking into this.
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #22 on: September 05, 2018, 06:11:09 PM »
but uv and solar is working here with the udp not ticked
and using your ID (i.e the data comes from the weatherflow server)
so it should be working for you
with the latest update of cronweatherflow
(did you restart that after unsetting to use udp, as a test)
Offline thebaldgeek
  • Win NT 10.0
« Reply #23 on: September 06, 2018, 12:15:50 AM »
Brian,
Ok, i did not understand there was a difference starting cronweatherflow separately from weatherdisplay.
After starting cronweatherflow I am now getting solar and UV.
Thanks for clarifying that.
« Last Edit: September 06, 2018, 12:18:26 AM by thebaldgeek »
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #24 on: September 06, 2018, 03:03:38 AM »
normally WD starts the cron program when its started
do you mean it was not running, or?
