After installing FreshWDLmaster and config.js in the same directory as the client* files I saw nothing at all on the server. I started changing the permisions on those two files and finally saw the “splash” screen but now, no data. I’m running Ubuntu 16.04LTS with Apache2. The browser is Firefox Quantum 61.0.1 (32-bit) for Ubuntu.
If I load FreshWDL it comes up saying “Data currently unavailable.” If I right-click on the screen and look at “Inspect Element (Q)” and go to the Network tab it shows error code 403 for all the client* attempts and code 200 for all of Yerren’s program calls.
I tried changing permissions on the client files on the server side but the next download reset them to what they were.
My browser thinks clientraw.txt is at http://www.af1hs.com/wx/clientraw.txt but the permissions are preventing it being shown. If that is the location then the permissions issue will stop FreshWDL working.
Forbidden
You don't have permission to access /wx/clientraw.txt on this server.
Apache/2.4.18 (Ubuntu) Server at www.af1hs.com Port 80
Niko: everything was properly set on the Realtime Tab but when I changed the port to 22 on the Connections tab, the data became live. Thank you so much.
