WDnot loading rain from weatherflow-solved
Hi I have WD running as a third party for weatrherflow, everything is working OK, but the rainfall is not being loaded
Regards
when you say loaded
how do you mean exactly?
the more information you can provide the better
WD is showing temp, wind hum, bar all OK but not showing rainfall either on the graph or in the rainfall totals at all.
On the WeatherFlow vers 1.4 reading from the top I have 13.0c 75% 963.1hpa 5.1 m/s 1.7 m/s 313.0 o 311.0 w/2 3.2 uv — — These last two readings I asume is probably rainfall but they have never registered anything
even though the rain total does not show in the cron program
WD should be still picking up rain OK from the raw file
(i.e when rain increases WD’s rain total increases…should be working OK with the latest update of WD linux)
here is a new cron program to show the rain total
http://www.weather-display.com/downloadfiles/cronweatherflowlinux.tar.gz
OK downloaded that but now evrything is fixed as at the last time when the previous version of cron was on, also is cron supposed to open up when WD does as it does not with this version
not sure what you mean by fixed
also not sure what you mean by your next sentence, as there is no update to WD, so nothing has changed in that regard
Hi Brian I solved that problem by changing the properties in the cron to execute as program its working Ok thanks very much :smiley:
