like way faster
I identified that is the writting of the log files that is slow (as they are appended)
and so I now store the data to be written into a stringlist and then that is written out in 1 go at the end
much faster
I just need to work out how to allow for when the file name changes at the change of the month
then will need some testers (e.g Davis VP)
its available now build 81 .zip update
(note default method in use if the data starts at the month prior)
currently works for Davis, weatherflow, ambientweather.net . I will add in wmr200 support today
you should notice a big difference
also this update adds ability to turn off anti alias for the graphs (so they look more like WD of years ago), see in the graph setup, extra options
update: test version for wmr200 /300 htttp://www.weather-display.com/downloadfiles/weatherdisplaytest.zip
I just tested getting 18 hours of missed data
and the second part of that processes the data so fast now…its like done in seconds ( I do have a SDD though), where as before it would have taken minutes
Shut down WD for 30 mins and restarted after unzipping test file. Read history data OK and seemed to complete very quickly, BUT graphs not recreated and no history data logged at all. Not only that, but no live data was logged at all until I went back to build 79 (with only the .zip update file). I’ve lost an hour’s log data.
I actually don’t care how long it takes to process history data as long as I don’t lose any data - history or live. And you are well aware that I always lose live data when restarting WD. . .
