WD has advanced the fields in clientraw.txt by one and combined field 176 with 175. Also see that there are only suppose to be 177 fields. see attached image.
I have tried going back to the previous version and also a reboot with no success.
I have been getting errors in my clientraw.txt file and customclientraw.txt file for apparent temps.
Using Ver 10.37S79
Tom
I notice when in advanced setup when check show THSW index is when apparent temperature readings are high. Un check it and apparent temperature seems good.
@ Weatherbee
The apparent temperature is being uploaded in the clientraw.txt file as the fahrenheit value rather than celsius value has been around for awhile… http://discourse.weather-watch.com/p/518225
I too have seen errors in clientraw.txt while building my own version of clientrawdescription.txt. I put it down to opening a file that is being regularly updated, as the problem doesn’t last long.
For the past two days the error has been showing up. I don’t know exactly when but sometime mid day. I have attached a copy of the clientraw file.
It looks like the error/addition seems to be in field 164 “daily low hum” and it has no value. then it throws the data off by one the rest of the file(see attachment):
Just got the time to download the latest Zip and install. That fixed it as mentioned.
Also I wanted to take this opportunity to say thanks for the continued support and development of Weather Display. In a time when it seems that a number of weather related programs have stagnated it is always appreciated to see that you are still supporting WD on a regular basis!
thanks again! :D/ :greenjumpers:
