Author Topic: Errors in Clientraw.txt  (Read 674 times)
Offline PSJohn
  • Palm Springs, CA. USA
  • Win NT 10.0
  • Firefox 61.0
    • Desertweather.com
« on: August 30, 2018, 06:58:19 AM »
Has anyone seen this before...
WD has advanced the fields in clientraw.txt by one and combined field 176 with 175. Also see that there are only suppose to be 177 fields. see attached image.
I have tried going back to the previous version and also a reboot with no success.
John
Palm Springs, California
Davis Vantage Pro 2, FARS
Offline PSJohn
  • Win NT 10.0
  • Firefox 61.0
    • Desertweather.com
Re: Errors in Clientraw.txt
« Reply #1 on: August 30, 2018, 07:04:47 AM »
OK, shorty after posting this midnight rolled by and that has seemed to fix it! Still curious in what caused this?
John
  • Davis VP2
  • New Zealand
  • Win NT 10.0
  • Chrome 68.0.3440.106
    • Weather Display
« Reply #2 on: August 30, 2018, 09:50:10 AM »
that will happen if there is an extra space in the data where it should not have been
(a copy of the file at the time would have been good)
Offline weatherbee
  • Sherman, Ct.
  • Win NT 10.0
  • Chrome 64.0.3282.140
    • Sherman Ct. Weather
« Reply #3 on: August 30, 2018, 10:03:03 AM »
I have been getting errors in my clientraw.txt file and customclientraw.txt file for apparent temps.
Using Ver 10.37S79
Tom
I notice when in advanced setup when check  show THSW index is when apparent temperature readings are high.  Un check it and apparent temperature seems good.
« Last Edit: August 30, 2018, 10:12:19 AM by weatherbee »
Sony Pentium 4, 1.6 GHZ,512 MB Ram, Windows XP Pro, SP2
Offline Gus
  • Halethorpe, Maryland USA
  • Win NT 10.0
    • Halethorpe Weather-Watch
« Reply #4 on: August 30, 2018, 11:20:44 AM »
@ Weatherbee
The apparent temperature is being uploaded in the clientraw.txt file as the fahrenheit value rather than celsius value has been around for awhile..
https://www.weather-watch.com/smf/index.php/topic,66772.msg536898.html#msg536898
Davis VP2+ & LabJack w/lightning counter, soil/grass temp
HP i5, 16GB, Windows10 CW1550 KMDBALTI12
Offline weatherbee
  • Sherman, Ct.
  • Win NT 10.0
« Reply #5 on: August 30, 2018, 11:38:23 AM »
Thanks Gus.  That is the problem.
Tom
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #6 on: August 30, 2018, 06:48:07 PM »
I missed seeing that other thread and have fixed this now in the latest .zip update  8O
Offline bitsostring
  • Oregon Scientific WMR200
  • Edinburgh, UK
  • Win NT 10.0
  • Mozilla compatible
    • Home Weather Station
« Reply #7 on: August 30, 2018, 07:03:03 PM »
Getting back to this thread:
I too have seen errors in clientraw.txt while building my own version of clientrawdescription.txt. I put it down to opening a file that is being regularly updated, as the problem doesn't last long.
Next time I'll post a copy.
It's meant to be fun. . .
Offline PSJohn
  • Win NT 10.0
  • Firefox 62.0
    • Desertweather.com
« Reply #8 on: September 07, 2018, 09:45:41 PM »
For the past two days the error has been showing up. I don't know exactly when but sometime mid day. I have attached a copy of the clientraw file.
It looks like the error/addition seems to be in field 164 "daily low hum" and it has no value. then it throws the data off by one the rest of the file(see attachment):
« Last Edit: September 07, 2018, 09:49:47 PM by PSJohn »
John
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #9 on: September 07, 2018, 09:51:44 PM »
did you have an actual copy of the clientraw.txt file at the time that error was occuring?
Offline PSJohn
  • Win NT 10.0
  • Firefox 62.0
    • Desertweather.com
« Reply #10 on: September 07, 2018, 09:55:22 PM »
Yes the clientraw file attached to previous message was at the time it happened. Also when it starts to error it stays that way until mid-nite reset.
I noticed that it has two spaces between some data (35 an 9):
Code: [Select]
33.82222 116.39722 0.0 35  9 0.0 5:07_AM
« Last Edit: September 07, 2018, 10:09:09 PM by PSJohn »
John
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #11 on: September 07, 2018, 11:24:17 PM »
that extra space is the likely problem
and only occurs if your daily low humidity is less than 10
use a new .zip update of WD to fix that
Offline PSJohn
  • Win NT 10.0
  • Firefox 61.0
    • Desertweather.com
« Reply #12 on: September 08, 2018, 06:07:52 AM »
Just got the time to download the latest Zip and install. That fixed it as mentioned.
Also I wanted to take this opportunity to say thanks for the continued support and development of Weather Display. In a time when it seems that a number of weather related programs have stagnated it is always appreciated to see that you are still supporting WD on a regular basis!
thanks again!  :D \:D/ :greenjumpers:
John
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #13 on: September 08, 2018, 10:20:36 AM »
that bug was a bit hidden that is for sure, was only going to show up when someone got less than 10% hum (I never see that here myself ) ;)
Offline dsscheibe
  • Phoenix, AZ
  • Win NT 10.0
  • Firefox 62.0
    • Scotts Weather Station, Cactus Wren, Phoenix, Arizona
« Reply #14 on: September 27, 2018, 02:37:10 AM »
Not unusual for Phoenix.
Humidity
Current: 25 %
High: 93% @ 7:07 AM
Low: 13% @ 3:18 PM
Dew point: 52.8F%
We are coming out of Monsoon season  so it is higher than normal, I've seen it as low as 5%
Scott
Davis Pro2 Plus daytime aspirated, wired
Weather Display
