Author Topic: Weatherflow setup  (Read 1851 times)
  • Davis VP2
  • Chrome 68.0.3440.106
    • Weather Display
Re: Weatherflow setup
« Reply #30 on: August 31, 2018, 04:30:16 AM »
by default it gets the data via UDP from the HUB (i.e via your wifi)
if that is not set then it gets the data from the weather flow server
history data (if you have the switch on in the data logger setup) is from the weatherflow server
Offline winedog
  • Waiheke Island, New Zealand
  • Chrome 69.0.3497.92
« Reply #31 on: September 12, 2018, 11:00:02 PM »
I've finally gotten my Weatherflow station setup and testing it with WD.  It seems that I can only get it to work if I set my Weatherflow station to Public, though?  I have the UDP option enabled in cronweather, but as soon as I toggle off the Public option it stops working.  Toggling Public back on returns everything to working.
Weather Stations:
Davis Vantage Pro 2 Wireless w/Solar Sensor & Testing WeatherFlow
Extra 1-Wire network:
LinkUSBi 1-wire Adapter, 1-wire Humidity, and 8 x Extra Temp Sensor
WD 10.37Sb93 on Win7x64 Pro 2.9Ghz Intel (Ivy Bridge) 4GB RAM
  • Davis VP2
    • Weather Display
« Reply #32 on: September 12, 2018, 11:25:10 PM »
I can only suggest asking weatherflow about that
Offline winedog
« Reply #33 on: September 12, 2018, 11:34:18 PM »
Not quite sure I understand your response so I just want to clarify and make sure I follow you....as far as you are aware WD should be able to read via UDP while Public sharing is disabled?
Weather Stations:
  • Davis VP2
    • Weather Display
« Reply #34 on: September 13, 2018, 12:45:59 AM »
you need to ask weatherflow that Q
that is what I am saying
(I am not sure why anyone would not want the public sharing enabled personally )
Offline mihec
  • Mac OS X 10.13.6
  • Safari 11.1.2
« Reply #35 on: September 16, 2018, 01:41:57 PM »
I hope it's not too off-topic. I got my WF station. Out of curiosity I've set up a WD (different PC than for my original Davis setup) to check how it works. Two observations:
- The wind data does not get updated every 3 seconds but sometimes it just freezes for e.g. 10 seconds. I've been visually comparing the public link from the WF server to the WD display.
- I can't (don't know) download the history data
I have a latest Mac version of WD trial version. My Mac is in the same Wifi as the WF and I set the WD to read the local UDP (not the web). For getting the history data, I've entered the station ID, restarted WD and tried with a "Data logger" switch Enabled.
It's not a big issue I just wanted to do a side by side test with Davis.
  • Davis VP2
    • Weather Display
« Reply #36 on: September 16, 2018, 06:22:03 PM »
are you talking about the mac version?
Offline mihec
  • iOS 11.4.1
  • Safari 11.0
« Reply #37 on: September 16, 2018, 06:23:04 PM »
Yes, itís a Mac version. I could try with a Win, if that helps.
  • Davis VP2
  • Android 7.1.1
  • Chrome 68.0.3440.91
    • Weather Display
« Reply #38 on: September 17, 2018, 01:29:11 AM »
With the mac version, it's the separate
Cronweatherflow app that you need to first
Monitor /check
Offline mihec
  • (Linux Mint)
  • Firefox 62.0
« Reply #39 on: September 17, 2018, 08:44:51 AM »
I've tried with a Win7 version now and confirm it works nicely!
