Author Topic: website creation questions  (Read 1249 times)
Offline dsscheibe
  • Phoenix, AZ
  • Win NT 10.0
  • Firefox 61.0
    • Scotts Weather Station, Cactus Wren, Phoenix, Arizona
« on: August 27, 2018, 09:04:47 AM »
I  think I have set all the ftp settings to upload every 10 minutes, how ever WD is uploading like every 2 minutes. What have I missed?
Scott
Davis Pro2 Plus daytime aspirated, wired
Weather Display
Online Weather Display
  • Davis VP2
  • New Zealand
  • Win NT 10.0
  • Chrome 68.0.3440.106
    • Weather Display
Re: website creation questions
« Reply #1 on: August 27, 2018, 07:56:11 PM »
if you could post some screen shots of the setup that would be good
Offline dsscheibe
  • Phoenix, AZ
  • Win NT 10.0
  • Firefox 61.0
« Reply #2 on: August 28, 2018, 11:12:52 AM »
which set up? , there are so many menus for every thing..
Another question, where does it keep file names of files it creates? I only have two files in custom files but it is also creating index.html.html and indexhtml.gif I need to get rid of. It should only be creating index.html and tags.html as weill as the nooa, details, files
Also the ftp only seems to be uploading the images, how do I make it upload *.html and *.htm files? It is updating the files but they are not on the website.
http://weather.scottsworld.info/index.html is not the current one localy
Scott
Weather Display
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #3 on: August 28, 2018, 06:48:41 PM »
if you are using the customise internet and file creation setup then post some screen shots of that
or email me your settings files
Offline dsscheibe
  • Phoenix, AZ
  • Win NT 10.0
  • Firefox 62.0
« Reply #4 on: September 10, 2018, 03:27:40 AM »
Now I have the opposite problem, it is uploading the custom webfiles but nothing else.
though the page says it was updated at 8:10 pm  the weather conditions still say early morning. And the next update tag stopped working either when I added the time and date tags before it or I updated to b81 which I did the same day..
[This page will refresh every 5 minutes]
Website should update Automatically every 10 minutes, last update: 8:10 PM 9/9/2018, next update: ---
by Weather Display v10.37S b81
using a Davis Instruments Vantage Pro2 Plus Weather Station
NOAA warning:
Down Up Stop Top
AZZ544
There are no active watches, warnings or advisories
Early Morning   clear
Its Early Morning,clear and it feels Caution Extreme Heat outside. The temperature has been falling for the last few hours. There is a Calm from the East north east
Scott
Weather Display
Offline dsscheibe
  • Phoenix, AZ
  • Win NT 10.0
  • Firefox 62.0
« Reply #5 on: September 10, 2018, 03:34:19 AM »
can not get forecast to work, it was working but showing the Davis forecast I think.  I got noaa and metar working then it quit working
5 Dayforcast:
forecast Icon
Today ---
T ---
T ---
T ---
T ---
Scott
Weather Display
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #6 on: September 10, 2018, 06:31:24 PM »
i suspect you do not have the noaa warning and noaa 5 day forecast setup correctly in WD
Offline dsscheibe
  • Phoenix, AZ
  • Win NT 10.0
  • Firefox 62.0
« Reply #7 on: September 12, 2018, 03:36:29 AM »
Pretty sure the problem is WD is not saving the file. I have seen it ftp files several times this evening, It logs into the noaa server, downloads the file, shows a progress bar,  says it saved the file to d:\weatherdisplay\downloads\   But when you look in the directory there is nothing there, so there is nothing when the settings asks where the 5 day file is to point it to.
The problem with the images is after each file it is trying to upload it tries to change the directory to public_html/weather when it did that when it logged in so it is already in that directory and causes a directory not found error.
It would be very helpful to know what all the files do and are sources for creating web pages
for instace http://weather.scottsworld.info/wxlocal.html  is showing a forecast for Kansas for some reason..
http://weather.scottsworld.info/climatedata.html   this file is not updating
Scott
Weather Display
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #8 on: September 12, 2018, 06:33:32 PM »
I do have a youtube video showing how to setup the 5 day forecast
but maybe you could post some screen shots of how you have that setup
also try resetting the download location
also its
http://weather.scottsworld.info/climatedataout.html
Offline dsscheibe
  • Phoenix, AZ
  • Win NT 10.0
  • Firefox 62.0
« Reply #9 on: September 15, 2018, 07:44:57 AM »
I turned the main internet switch off and later turned it on and WD started uploading everything with out putting chd after every file trying to changed the directory.  Very weird, everything seems to be working now but the 5 day forecast and the UV and solar dials are not updating but the text UV and solar tags do work. Though the solarconditions tag was always saying gloomy and overcast even though there hasn't been a cloud in the sky for days.. So I removed it and the dials.
The NOAAscroll tag does not scroll, they issued an excessive heat warning for Friday and saturday so it worked for the first time. I replaced it with NOAAraw tag I believe and put it in a marquee tag, for some reason the marquee appears half a line above the NOAA warning: text which are in the same div tag and line
NOAA warning: AZZ544 Excessive Heat Warning is
Scott
Weather Display
Offline dsscheibe
  • Phoenix, AZ
  • Win NT 10.0
  • Firefox 62.0
« Reply #10 on: September 16, 2018, 11:39:43 AM »
changing the file name to lower case fixed it, hower the forecast looks lik this..:
expires 201809162300723253 fpus55 kpsr 160933 zfppsr zone forecast product for southwest arizonasoutheast california national weather service phoenix az 232 am mst sun sep 16 2018 this is an automatically generated product that provides average values for large geographical areas and may not be representative of the exact location that you are interested in. for a more site specific forecast, please visit weather.govphoenix and either 1 select a location from the dropdown menu above the map or 2 click a location on the map. you can refine your selection by clicking on the map displayed on the resulting page. azz537-540-544-546-548-550-551-162300- northwest valley-buckeyeavondale-deer valley-central phoenix- north phoenixglendale-scottsdaleparadise valley-east valley- south mountainahwatukee-southeast valleyqueen creek- including the cities of circle city, surprise, wittmann, beardsley, sun city west, avondale, cashion, goodyear, liberty, peoria, phoenix, paradise valley, mesa, chandler, tempe, gilbert, sun lakes, and queen creek 232 am mst sun sep 16 2018 .today...mostly sunny and hot. highs 101 to 106. southeast wind around 5 mph in the morning becoming southwest 5 to 10 mph in the afternoon. .tonight...clear. lows 78 to 85. west wind 5 to 10 mph. .monday...sunny and hot. highs 103 to 107. southeast wind around 5 mph in the morning becoming southwest 5 to 10 mph in the afternoon. .monday night...clear. lows 77 to 84. northwest wind 5 to 10 mph. .tuesday...mostly sunny and hot. highs 101 to 106. southwest wind 5 to 10 mph. .tuesday night...partly cloudy. lows in the mid 70s to lower 80s. .wednesday...partly sunny with a 10 percent chance of showers and thunderstorms. not as warm. highs 95 to 100. .wednesday night...partly cloudy with a 20 percent chance of showers and thunderstorms. cooler. lows in the upper 60s to mid 70s. .thursday...partly sunny with a 10 percent chance of showers and thunderstorms. highs in the mid to upper 90s. .thursday night...partly cloudy with a 20 percent chance of showers and thunderstorms. lows in the lower to mid 70s. .friday...partly sunny with a 20 percent chance of showers and thunderstorms. highs in the mid to upper 90s. .friday night...mostly clear with a 10 percent chance of showers and thunderstorms. lows in the upper 60s to mid 70s. EXPIRES
.saturday...partly sunny. a 10 percent chance of afternoon showers and thunderstorms. highs in the mid to upper 90s.
Scott
Weather Display
Offline dsscheibe
  • Phoenix, AZ
  • Win NT 10.0
  • Firefox 62.0
« Reply #11 on: September 16, 2018, 11:50:36 AM »
Is it possible to get the metar.txt wd produces into a page?
http://weather.scottsworld.info/metar.html
I found a replacement for  the dead weather.noaa.gov metar pages
https://metar.com  though sometimes it times out before loading.. seems to work better on my phone than on a computer
Scott
Weather Display
Offline dsscheibe
  • Phoenix, AZ
  • Win NT 10.0
  • Firefox 62.0
« Reply #12 on: September 17, 2018, 04:03:35 AM »
climatedata.html    you sort of gave me the impression this was the source file for climatedataout.html  how ever adding my menu and code to the first did nothing to the out files..
Can we do more than 5 custom pages, I don't see a setting for it.
http://weather.scottsworld.info/gaugesss.html
I customized the basic html 5 steel gauges file and renamed it, but the wd tags are not updating as I have not set it to be a custom file upload as I only have one left
Scott
Weather Display
Offline R_o_B
  • Maple Bay, British Columbia, Canada
  • Win NT 10.0
  • Firefox 52.0
    • Tzouhalem-Maple Bay Weather
« Reply #13 on: September 17, 2018, 12:43:14 PM »
Scott, Brian (the designer behind Weather Display) has surely other things to do (such as supporting Weather Display software) than trying to help someone, anyone, designing a weather web site.
May I suggest that you have a look at Ken True's 'PHP/AJAX Website Template Sets' in order to develop a multi-page weather web site.
You could also look at 'Weather34 Home Weather Station Dashboard Template' for a more modern one-page weather web site.
R_o_B
eMail: weather@tzweather.org
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #14 on: September 17, 2018, 07:55:26 PM »
WD  can be set to parse and upload up to 40 custom web pages
re the forecast, if you add <pre> and </pre> around the text then it will look better in the html page
