…i think the rain amount issue is related to the delay in the minute change.
its missing catching data at that time.
Nevermind.
I manually set the raintotals at the end of each day with rain. :roll:
re the solar, maybe you have set a solar offset?
the data received not going green is just a minor cosmetic issue…wont affect anything…but I can fix
The file input option still cant be changed to file input, its always set to CR200 on re-opening it.do you mean you need to use the file input option? (i.e set to use the logfile created by the campbell scientific software....which if that is the case then cronpakbus does not need to run I would have thought
Thanks for your reply, much appreciated.
Let me try to explain the issue.
I dont use the cronpakbusnew because im running WD together with Loggernet.
You mentioned to use the file input, but its not saving. On reopening its always set to cr200.
WD is using the public.dat file which update every second, live data.
No i havent set a solar offset, its showing 1.5 at night on mainscreen, but when i restart WD the solar data field on mainscreen is empty.
Re the data received not going green, would be great if its working so i see all is ok.
The 60 Excel files in the WD map updating every minute to check missing data on the minutecange dont contain data, i think because cronpakbus isnt running?
Could that cause the rainamout issue? See picture above and attatched.
I noticed since i dont use the cronpakbusnew, the minutechange takes sometimes more then 5 or so seconds.
With kindest regards.
I managed to get the data from the source and from WD side by side.
The data on the left is the source, on the right from WD.
As you can see, from 04:58, WD is missing data:
12-11-2018 04:33:00, 0.00, 0.00 12/11/2018 04:33 0.000 0 0.000
12-11-2018 04:34:00, 10.00, 0.01 12/11/2018 04:34 0.000 10 0.010
12-11-2018 04:35:00, 10.00, 0.01 12/11/2018 04:35 0.010 10 0.010
12-11-2018 04:36:00, 0.00, 0.01 12/11/2018 04:36 0.000 0 0.010
12-11-2018 04:37:00, 0.00, 0.01 12/11/2018 04:37 0.000 0 0.010
12-11-2018 04:38:00, 10.00, 0.02 12/11/2018 04:38 0.000 10 0.020
12-11-2018 04:39:00, 10.00, 0.02 12/11/2018 04:39 0.010 10 0.020
12-11-2018 04:40:00, 0.00, 0.02 12/11/2018 04:40 0.000 0 0.020
12-11-2018 04:41:00, 0.00, 0.02 12/11/2018 04:41 0.000 0 0.020
12-11-2018 04:42:00, 0.00, 0.02 12/11/2018 04:42 0.000 0 0.020
12-11-2018 04:43:00, 0.00, 0.02 12/11/2018 04:43 0.000 0 0.020
12-11-2018 04:44:00, 0.00, 0.02 12/11/2018 04:44 0.000 0 0.020
12-11-2018 04:45:00, 0.00, 0.02 12/11/2018 04:45 0.000 0 0.020
12-11-2018 04:46:00, 0.00, 0.02 12/11/2018 04:46 0.000 0 0.020
12-11-2018 04:47:00, 0.00, 0.02 12/11/2018 04:47 0.000 0 0.020
12-11-2018 04:48:00, 10.00, 0.03 12/11/2018 04:48 0.000 10 0.030
12-11-2018 04:49:00, 10.00, 0.03 12/11/2018 04:49 0.010 10 0.030
12-11-2018 04:50:00, 0.00, 0.03 12/11/2018 04:50 0.000 0 0.030
12-11-2018 04:51:00, 0.00, 0.03 12/11/2018 04:51 0.000 0 0.030
12-11-2018 04:52:00, 10.00, 0.04 12/11/2018 04:52 0.000 10 0.040
12-11-2018 04:53:00, 10.00, 0.04 12/11/2018 04:53 0.010 10 0.040
12-11-2018 04:54:00, 10.00, 0.04 12/11/2018 04:54 0.000 10 0.040
12-11-2018 04:55:00, 0.00, 0.04 12/11/2018 04:55 0.000 0 0.040
12-11-2018 04:56:00, 0.00, 0.04 12/11/2018 04:56 0.000 0 0.040
12-11-2018 04:57:00, 0.00, 0.04 12/11/2018 04:57 0.000 0 0.040
12-11-2018 04:58:00, 0.00, 0.05 12/11/2018 04:58 0.000 0 0.040
12-11-2018 04:59:00, 10.00, 0.05 12/11/2018 04:59 0.000 10 0.040
12-11-2018 05:00:00, 10.00, 0.05 12/11/2018 05:00 0.000 10 0.040
12-11-2018 05:01:00, 0.00, 0.05 12/11/2018 05:01 0.000 0 0.040
12-11-2018 05:02:00, 10.00, 0.06 12/11/2018 05:02 0.000 10 0.050
12-11-2018 05:03:00, 10.00, 0.06 12/11/2018 05:03 0.010 10 0.050
12-11-2018 05:04:00, 0.00, 0.06 12/11/2018 05:04 0.000 0 0.050
12-11-2018 05:05:00, 0.00, 0.06 12/11/2018 05:05 0.000 0 0.050
12-11-2018 05:06:00, 0.00, 0.06 12/11/2018 05:06 0.000 0 0.050
12-11-2018 05:07:00, 0.00, 0.06 12/11/2018 05:07 0.000 0 0.050
12-11-2018 05:08:00, 10.00, 0.07 12/11/2018 05:08 0.000 10 0.060
12-11-2018 05:09:00, 10.00, 0.07 12/11/2018 05:09 0.010 10 0.060
12-11-2018 05:10:00, 10.00, 0.08 12/11/2018 05:10 0.000 10 0.070
12-11-2018 05:11:00, 10.00, 0.09 12/11/2018 05:11 0.010 10 0.080
12-11-2018 05:12:00, 10.00, 0.09 12/11/2018 05:12 0.010 10 0.080
12-11-2018 05:13:00, 0.00, 0.09 12/11/2018 05:13 0.000 0 0.080
12-11-2018 05:14:00, 0.00, 0.09 12/11/2018 05:14 0.000 0 0.080
12-11-2018 05:15:00, 10.00, 0.10 12/11/2018 05:15 0.000 10 0.090
12-11-2018 05:16:00, 10.00, 0.10 12/11/2018 05:16 0.010 10 0.090
12-11-2018 05:17:00, 0.00, 0.10 12/11/2018 05:17 0.000 0 0.090
12-11-2018 05:18:00, 0.00, 0.10 12/11/2018 05:18 0.000 0 0.090
12-11-2018 05:19:00, 10.00, 0.11 12/11/2018 05:19 0.000 10 0.100
12-11-2018 05:20:00, 10.00, 0.11 12/11/2018 05:20 0.010 10 0.100
12-11-2018 05:21:00, 10.00, 0.12 12/11/2018 05:21 0.000 10 0.110
12-11-2018 05:22:00, 10.00, 0.12 12/11/2018 05:22 0.010 10 0.110
12-11-2018 05:23:00, 10.00, 0.13 12/11/2018 05:23 0.000 10 0.120
12-11-2018 05:24:00, 10.00, 0.14 12/11/2018 05:24 0.010 10 0.130
12-11-2018 05:25:00, 10.00, 0.14 12/11/2018 05:25 0.010 10 0.130
12-11-2018 05:26:00, 10.00, 0.14 12/11/2018 05:26 0.000 10 0.130
12-11-2018 05:27:00, 10.00, 0.15 12/11/2018 05:27 0.000 10 0.140
12-11-2018 05:28:00, 10.00, 0.16 12/11/2018 05:28 0.010 10 0.150
12-11-2018 05:29:00, 10.00, 0.16 12/11/2018 05:29 0.010 10 0.150
12-11-2018 05:30:00, 10.00, 0.17 12/11/2018 05:30 0.000 10 0.160
12-11-2018 05:31:00, 10.00, 0.17 12/11/2018 05:31 0.010 10 0.160
12-11-2018 05:32:00, 10.00, 0.18 12/11/2018 05:32 0.000 10 0.170
12-11-2018 05:33:00, 10.00, 0.18 12/11/2018 05:33 0.010 10 0.170
12-11-2018 05:34:00, 0.00, 0.18 12/11/2018 05:34 0.000 0 0.170
12-11-2018 05:35:00, 10.00, 0.19 12/11/2018 05:35 0.000 10 0.180
12-11-2018 05:36:00, 10.00, 0.19 12/11/2018 05:36 0.010 10 0.180
12-11-2018 05:37:00, 10.00, 0.19 12/11/2018 05:37 0.000 10 0.180
12-11-2018 05:38:00, 10.00, 0.20 12/11/2018 05:38 0.000 10 0.190
12-11-2018 05:39:00, 10.00, 0.20 12/11/2018 05:39 0.010 10 0.190
12-11-2018 05:40:00, 0.00, 0.20 12/11/2018 05:40 0.000 0 0.190
12-11-2018 05:41:00, 0.00, 0.20 12/11/2018 05:41 0.000 0 0.190
12-11-2018 05:42:00, 10.00, 0.21 12/11/2018 05:42 0.000 10 0.200
12-11-2018 05:43:00, 10.00, 0.21 12/11/2018 05:43 0.010 10 0.200
12-11-2018 05:44:00, 0.00, 0.21 12/11/2018 05:44 0.000 0 0.200
12-11-2018 05:45:00, 10.00, 0.22 12/11/2018 05:45 0.000 10 0.210
12-11-2018 05:46:00, 10.00, 0.22 12/11/2018 05:46 0.010 10 0.210
12-11-2018 05:47:00, 10.00, 0.23 12/11/2018 05:47 0.000 9 0.220
12-11-2018 05:48:00, 10.00, 0.23 12/11/2018 05:48 0.010 10 0.220
12-11-2018 05:49:00, 10.00, 0.24 12/11/2018 05:49 0.000 10 0.230
12-11-2018 05:50:00, 10.00, 0.25 12/11/2018 05:50 0.010 10 0.240
12-11-2018 05:51:00, 10.00, 0.26 12/11/2018 05:51 0.010 10 0.250
12-11-2018 05:52:00, 10.00, 0.27 12/11/2018 05:52 0.010 10 0.260
12-11-2018 05:53:00, 10.00, 0.28 12/11/2018 05:53 0.010 10 0.270
12-11-2018 05:54:00, 10.00, 0.30 12/11/2018 05:54 0.010 10 0.280
12-11-2018 05:55:00, 10.00, 0.30 12/11/2018 05:55 0.010 10 0.280
12-11-2018 05:56:00, 10.00, 0.31 12/11/2018 05:56 0.000 10 0.280
12-11-2018 05:57:00, 10.00, 0.32 12/11/2018 05:57 0.000 10 0.290
12-11-2018 05:58:00, 10.00, 0.32 12/11/2018 05:58 0.010 10 0.290
12-11-2018 05:59:00, 10.00, 0.33 12/11/2018 05:59 0.000 10 0.300
12-11-2018 06:00:00, 10.00, 0.34 12/11/2018 06:00 0.010 10 0.310
12-11-2018 06:01:00, 10.00, 0.36 12/11/2018 06:01 0.010 10 0.330
12-11-2018 06:02:00, 10.00, 0.37 12/11/2018 06:02 0.020 10 0.340
12-11-2018 06:03:00, 10.00, 0.38 12/11/2018 06:03 0.010 10 0.350
12-11-2018 06:04:00, 10.00, 0.39 12/11/2018 06:04 0.010 10 0.360
12-11-2018 06:05:00, 10.00, 0.40 12/11/2018 06:05 0.010 10 0.370
12-11-2018 06:06:00, 10.00, 0.41 12/11/2018 06:06 0.010 10 0.380
12-11-2018 06:07:00, 10.00, 0.42 12/11/2018 06:07 0.010 10 0.390
12-11-2018 06:08:00, 10.00, 0.44 12/11/2018 06:08 0.010 10 0.410
12-11-2018 06:09:00, 10.00, 0.44 12/11/2018 06:09 0.020 10 0.410
12-11-2018 06:10:00, 0.00, 0.44 12/11/2018 06:10 0.000 0 0.410
12-11-2018 06:11:00, 10.00, 0.45 12/11/2018 06:11 0.000 10 0.410
12-11-2018 06:12:00, 10.00, 0.46 12/11/2018 06:12 0.000 10 0.410
12-11-2018 06:13:00, 10.00, 0.47 12/11/2018 06:13 0.000 10 0.420
12-11-2018 06:14:00, 10.00, 0.47 12/11/2018 06:14 0.010 10 0.420
12-11-2018 06:15:00, 10.00, 0.48 12/11/2018 06:15 0.000 10 0.430
12-11-2018 06:16:00, 10.00, 0.48 12/11/2018 06:16 0.010 10 0.430
12-11-2018 06:17:00, 0.00, 0.48 12/11/2018 06:17 0.000 0 0.430
12-11-2018 06:18:00, 0.00, 0.48 12/11/2018 06:18 0.000 0 0.430
12-11-2018 06:19:00, 10.00, 0.49 12/11/2018 06:19 0.000 10 0.440
12-11-2018 06:20:00, 10.00, 0.49 12/11/2018 06:20 0.010 10 0.440
12-11-2018 06:21:00, 10.00, 0.50 12/11/2018 06:21 0.000 10 0.450
12-11-2018 06:22:00, 10.00, 0.50 12/11/2018 06:22 0.010 10 0.450
12-11-2018 06:23:00, 10.00, 0.51 12/11/2018 06:23 0.000 10 0.460
12-11-2018 06:24:00, 10.00, 0.51 12/11/2018 06:24 0.010 10 0.460
12-11-2018 06:25:00, 10.00, 0.52 12/11/2018 06:25 0.000 10 0.470
12-11-2018 06:26:00, 10.00, 0.52 12/11/2018 06:26 0.010 10 0.470
12-11-2018 06:27:00, 10.00, 0.54 12/11/2018 06:27 0.000 10 0.480
12-11-2018 06:28:00, 10.00, 0.54 12/11/2018 06:28 0.010 10 0.480
12-11-2018 06:29:00, 10.00, 0.55 12/11/2018 06:29 0.000 10 0.490
12-11-2018 06:30:00, 10.00, 0.56 12/11/2018 06:30 0.010 10 0.500
12-11-2018 06:31:00, 10.00, 0.57 12/11/2018 06:31 0.010 10 0.510
12-11-2018 06:32:00, 10.00, 0.57 12/11/2018 06:32 0.010 10 0.510
12-11-2018 06:33:00, 10.00, 0.58 12/11/2018 06:33 0.000 10 0.520
12-11-2018 06:34:00, 10.00, 0.59 12/11/2018 06:34 0.010 10 0.530
12-11-2018 06:35:00, 10.00, 0.59 12/11/2018 06:35 0.010 10 0.530
12-11-2018 06:36:00, 0.00, 0.59 12/11/2018 06:36 0.000 0 0.530
12-11-2018 06:37:00, 10.00, 0.60 12/11/2018 06:37 0.000 10 0.540
12-11-2018 06:38:00, 10.00, 0.60 12/11/2018 06:38 0.010 10 0.540
12-11-2018 06:39:00, 0.00, 0.60 12/11/2018 06:39 0.000 0 0.540
12-11-2018 06:40:00, 0.00, 0.60 12/11/2018 06:40 0.000 0 0.540
12-11-2018 06:41:00, 10.00, 0.61 12/11/2018 06:41 0.000 10 0.540
12-11-2018 06:42:00, 10.00, 0.62 12/11/2018 06:42 0.000 10 0.550
12-11-2018 06:43:00, 10.00, 0.62 12/11/2018 06:43 0.010 10 0.550
12-11-2018 06:44:00, 0.00, 0.62 12/11/2018 06:44 0.000 0 0.550
12-11-2018 06:45:00, 10.00, 0.63 12/11/2018 06:45 0.000 10 0.560
12-11-2018 06:46:00, 10.00, 0.63 12/11/2018 06:46 0.010 10 0.560
12-11-2018 06:47:00, 0.00, 0.63 12/11/2018 06:47 0.000 0 0.560
12-11-2018 06:48:00, 0.00, 0.63 12/11/2018 06:48 0.000 0 0.560
12-11-2018 06:49:00, 0.00, 0.63 12/11/2018 06:49 0.000 0 0.560
12-11-2018 06:50:00, 10.00, 0.64 12/11/2018 06:50 0.000 6 0.570
12-11-2018 06:51:00, 10.00, 0.64 12/11/2018 06:51 0.010 10 0.570
12-11-2018 06:52:00, 10.00, 0.64 12/11/2018 06:52 0.000 10 0.570
12-11-2018 06:53:00, 0.00, 0.64 12/11/2018 06:53 0.000 0 0.570
12-11-2018 06:54:00, 0.00, 0.64 12/11/2018 06:54 0.000 0 0.570
12-11-2018 06:55:00, 10.00, 0.65 12/11/2018 06:55 0.000 10 0.580
12-11-2018 06:56:00, 10.00, 0.65 12/11/2018 06:56 0.010 10 0.580
12-11-2018 06:57:00, 0.00, 0.65 12/11/2018 06:57 0.000 0 0.580
12-11-2018 06:58:00, 0.00, 0.65 12/11/2018 06:58 0.000 0 0.580
12-11-2018 06:59:00, 0.00, 0.65 12/11/2018 06:59 0.000 0 0.580
12-11-2018 07:00:00, 10.00, 0.66 12/11/2018 07:00 0.000 10 0.590
12-11-2018 07:01:00, 10.00, 0.66 12/11/2018 07:01 0.010 10 0.590
12-11-2018 07:02:00, 0.00, 0.66 12/11/2018 07:02 0.000 0 0.590
12-11-2018 07:03:00, 0.00, 0.66 12/11/2018 07:03 0.000 0 0.590
12-11-2018 07:04:00, 10.00, 0.67 12/11/2018 07:04 0.000 10 0.600
12-11-2018 07:05:00, 10.00, 0.67 12/11/2018 07:05 0.010 10 0.600
12-11-2018 07:06:00, 0.00, 0.67 12/11/2018 07:06 0.000 0 0.600
12-11-2018 07:07:00, 10.00, 0.68 12/11/2018 07:07 0.000 10 0.610
12-11-2018 07:08:00, 10.00, 0.68 12/11/2018 07:08 0.010 10 0.610
12-11-2018 07:09:00, 0.00, 0.68 12/11/2018 07:09 0.000 0 0.610
12-11-2018 07:10:00, 0.00, 0.68 12/11/2018 07:10 0.000 0 0.610
12-11-2018 07:11:00, 0.00, 0.68 12/11/2018 07:11 0.000 0 0.610
12-11-2018 07:12:00, 10.00, 0.69 12/11/2018 07:12 0.000 10 0.620
12-11-2018 07:13:00, 10.00, 0.69 12/11/2018 07:13 0.010 10 0.620
12-11-2018 07:14:00, 0.00, 0.69 12/11/2018 07:14 0.000 0 0.620
12-11-2018 07:15:00, 0.00, 0.69 12/11/2018 07:15 0.000 0 0.620
12-11-2018 07:16:00, 0.00, 0.69 12/11/2018 07:16 0.000 0 0.620
12-11-2018 07:17:00, 0.00, 0.69 12/11/2018 07:17 0.000 0 0.620
12-11-2018 07:18:00, 0.00, 0.69 12/11/2018 07:18 0.000 0 0.620
12-11-2018 07:19:00, 0.00, 0.69 12/11/2018 07:19 0.000 0 0.620
12-11-2018 07:20:00, 10.00, 0.70 12/11/2018 07:20 0.000 10 0.630
12-11-2018 07:21:00, 10.00, 0.70 12/11/2018 07:21 0.010 10 0.630
12-11-2018 07:22:00, 10.00, 0.71 12/11/2018 07:22 0.000 10 0.640
12-11-2018 07:23:00, 10.00, 0.71 12/11/2018 07:23 0.010 10 0.640
12-11-2018 07:24:00, 10.00, 0.72 12/11/2018 07:24 0.000 10 0.650
12-11-2018 07:25:00, 10.00, 0.72 12/11/2018 07:25 0.010 10 0.650
12-11-2018 07:26:00, 0.00, 0.72 12/11/2018 07:26 0.000 0 0.650
12-11-2018 07:27:00, 10.00, 0.73 12/11/2018 07:27 0.000 10 0.660
12-11-2018 07:28:00, 10.00, 0.74 12/11/2018 07:28 0.010 10 0.670
12-11-2018 07:29:00, 10.00, 0.74 12/11/2018 07:29 0.010 10 0.670
12-11-2018 07:30:00, 0.00, 0.74 12/11/2018 07:30 0.000 0 0.670
12-11-2018 07:31:00, 10.00, 0.75 12/11/2018 07:31 0.000 10 0.680
12-11-2018 07:32:00, 10.00, 0.75 12/11/2018 07:32 0.010 10 0.680
12-11-2018 07:33:00, 10.00, 0.76 12/11/2018 07:33 0.000 10 0.690
12-11-2018 07:34:00, 10.00, 0.77 12/11/2018 07:34 0.010 10 0.700
12-11-2018 07:35:00, 10.00, 0.78 12/11/2018 07:35 0.010 10 0.710
12-11-2018 07:36:00, 10.00, 0.78 12/11/2018 07:36 0.010 10 0.710
12-11-2018 07:37:00, 10.00, 0.79 12/11/2018 07:37 0.000 10 0.720
12-11-2018 07:38:00, 10.00, 0.79 12/11/2018 07:38 0.010 10 0.720
12-11-2018 07:39:00, 10.00, 0.80 12/11/2018 07:39 0.000 10 0.730
12-11-2018 07:40:00, 10.00, 0.81 12/11/2018 07:40 0.010 10 0.740
12-11-2018 07:41:00, 10.00, 0.82 12/11/2018 07:41 0.010 10 0.750
12-11-2018 07:42:00, 10.00, 0.83 12/11/2018 07:42 0.010 10 0.760
12-11-2018 07:43:00, 10.00, 0.85 12/11/2018 07:43 0.010 10 0.770
12-11-2018 07:44:00, 10.00, 0.86 12/11/2018 07:44 0.010 10 0.780
12-11-2018 07:45:00, 10.00, 0.87 12/11/2018 07:45 0.010 10 0.790
12-11-2018 07:46:00, 10.00, 0.88 12/11/2018 07:46 0.010 10 0.790
12-11-2018 07:47:00, 10.00, 0.90 12/11/2018 07:47 0.000 10 0.810
12-11-2018 07:48:00, 10.00, 0.91 12/11/2018 07:48 0.020 10 0.810
12-11-2018 07:49:00, 10.00, 0.92 12/11/2018 07:49 0.000 10 0.810
12-11-2018 07:50:00, 10.00, 0.93 12/11/2018 07:50 0.000 10 0.820
12-11-2018 07:51:00, 10.00, 0.94 12/11/2018 07:51 0.010 10 0.830
12-11-2018 07:52:00, 10.00, 0.95 12/11/2018 07:52 0.010 10 0.840
12-11-2018 07:53:00, 10.00, 0.96 12/11/2018 07:53 0.010 10 0.850
12-11-2018 07:54:00, 10.00, 0.96 12/11/2018 07:54 0.010 10 0.850
12-11-2018 07:55:00, 10.00, 0.97 12/11/2018 07:55 0.000 10 0.860
12-11-2018 07:56:00, 10.00, 0.99 12/11/2018 07:56 0.010 10 0.880
12-11-2018 07:57:00, 10.00, 1.01 12/11/2018 07:57 0.020 10 0.900
12-11-2018 07:58:00, 10.00, 1.02 12/11/2018 07:58 0.020 10 0.910
12-11-2018 07:59:00, 10.00, 1.04 12/11/2018 07:59 0.010 10 0.920
Continued from previous page…
12-11-2018 08:00:00, 10.00, 1.05 12/11/2018 08:00 0.010 10 0.920
12-11-2018 08:01:00, 10.00, 1.06 12/11/2018 08:01 0.010 10 0.920
12-11-2018 08:02:00, 10.00, 1.07 12/11/2018 08:02 0.010 10 0.920
12-11-2018 08:03:00, 10.00, 1.09 12/11/2018 08:03 0.010 10 0.950
12-11-2018 08:04:00, 10.00, 1.11 12/11/2018 08:04 0.020 10 0.970
12-11-2018 08:05:00, 10.00, 1.11 12/11/2018 08:05 0.020 10 0.970
12-11-2018 08:06:00, 10.00, 1.13 12/11/2018 08:06 0.000 10 0.970
12-11-2018 08:07:00, 10.00, 1.15 12/11/2018 08:07 0.000 10 0.980
12-11-2018 08:08:00, 10.00, 1.17 12/11/2018 08:08 0.010 10 1.000
12-11-2018 08:09:00, 10.00, 1.18 12/11/2018 08:09 0.020 10 1.010
12-11-2018 08:10:00, 10.00, 1.19 12/11/2018 08:10 0.010 10 1.020
12-11-2018 08:11:00, 10.00, 1.20 12/11/2018 08:11 0.010 10 1.030
12-11-2018 08:12:00, 10.00, 1.21 12/11/2018 08:12 0.010 10 1.040
12-11-2018 08:13:00, 10.00, 1.22 12/11/2018 08:13 0.010 10 1.050
12-11-2018 08:14:00, 10.00, 1.24 12/11/2018 08:14 0.010 10 1.070
12-11-2018 08:15:00, 10.00, 1.25 12/11/2018 08:15 0.020 10 1.080
12-11-2018 08:16:00, 10.00, 1.27 12/11/2018 08:16 0.010 10 1.100
12-11-2018 08:17:00, 10.00, 1.29 12/11/2018 08:17 0.020 10 1.120
12-11-2018 08:18:00, 10.00, 1.30 12/11/2018 08:18 0.020 10 1.130
12-11-2018 08:19:00, 10.00, 1.31 12/11/2018 08:19 0.010 10 1.140
12-11-2018 08:20:00, 10.00, 1.32 12/11/2018 08:20 0.010 10 1.150
12-11-2018 08:21:00, 10.00, 1.32 12/11/2018 08:21 0.010 10 1.150
12-11-2018 08:22:00, 10.00, 1.33 12/11/2018 08:22 0.000 10 1.160
12-11-2018 08:23:00, 10.00, 1.33 12/11/2018 08:23 0.010 10 1.160
12-11-2018 08:24:00, 10.00, 1.34 12/11/2018 08:24 0.000 10 1.170
12-11-2018 08:25:00, 10.00, 1.34 12/11/2018 08:25 0.010 10 1.170
12-11-2018 08:26:00, 10.00, 1.35 12/11/2018 08:26 0.000 10 1.170
12-11-2018 08:27:00, 10.00, 1.35 12/11/2018 08:27 0.000 10 1.170
12-11-2018 08:28:00, 10.00, 1.36 12/11/2018 08:28 0.000 10 1.180
12-11-2018 08:29:00, 10.00, 1.36 12/11/2018 08:29 0.010 10 1.180
12-11-2018 08:30:00, 10.00, 1.36 12/11/2018 08:30 0.000 10 1.180
12-11-2018 08:31:00, 0.00, 1.36 12/11/2018 08:31 0.000 0 1.180
12-11-2018 08:32:00, 10.00, 1.37 12/11/2018 08:32 0.000 10 1.190
12-11-2018 08:33:00, 10.00, 1.37 12/11/2018 08:33 0.010 10 1.190
12-11-2018 08:34:00, 0.00, 1.37 12/11/2018 08:34 0.000 0 1.190
12-11-2018 08:35:00, 10.00, 1.38 12/11/2018 08:35 0.000 10 1.200
12-11-2018 08:36:00, 10.00, 1.38 12/11/2018 08:36 0.010 10 1.200
12-11-2018 08:37:00, 10.00, 1.39 12/11/2018 08:37 0.000 10 1.210
12-11-2018 08:38:00, 10.00, 1.39 12/11/2018 08:38 0.010 10 1.210
12-11-2018 08:39:00, 10.00, 1.40 12/11/2018 08:39 0.000 10 1.220
12-11-2018 08:40:00, 10.00, 1.40 12/11/2018 08:40 0.010 10 1.220
12-11-2018 08:41:00, 10.00, 1.41 12/11/2018 08:41 0.000 10 1.220
12-11-2018 08:42:00, 10.00, 1.42 12/11/2018 08:42 0.000 10 1.230
12-11-2018 08:43:00, 10.00, 1.42 12/11/2018 08:43 0.010 10 1.230
12-11-2018 08:44:00, 10.00, 1.43 12/11/2018 08:44 0.000 10 1.240
12-11-2018 08:45:00, 10.00, 1.43 12/11/2018 08:45 0.010 10 1.240
12-11-2018 08:46:00, 10.00, 1.44 12/11/2018 08:46 0.000 10 1.250
12-11-2018 08:47:00, 10.00, 1.44 12/11/2018 08:47 0.010 10 1.250
12-11-2018 08:48:00, 10.00, 1.45 12/11/2018 08:48 0.000 10 1.260
12-11-2018 08:49:00, 10.00, 1.55 12/11/2018 08:49 0.010 10 1.380
12-11-2018 08:50:00, 10.00, 1.56 12/11/2018 08:50 0.120 10 1.390
12-11-2018 08:51:00, 10.00, 1.56 12/11/2018 08:51 0.010 10 1.390
12-11-2018 08:52:00, 0.00, 1.56 12/11/2018 08:52 0.000 0 1.390
12-11-2018 08:53:00, 10.00, 1.57 12/11/2018 08:53 0.000 10 1.400
12-11-2018 08:54:00, 10.00, 1.57 12/11/2018 08:54 0.010 10 1.400
12-11-2018 08:55:00, 0.00, 1.57 12/11/2018 08:55 0.000 0 1.400
12-11-2018 08:56:00, 10.00, 1.58 12/11/2018 08:56 0.000 10 1.410
12-11-2018 08:57:00, 10.00, 1.58 12/11/2018 08:57 0.010 10 1.410
12-11-2018 08:58:00, 10.00, 1.59 12/11/2018 08:58 0.000 10 1.420
12-11-2018 08:59:00, 10.00, 1.59 12/11/2018 08:59 0.010 10 1.420
12-11-2018 09:00:00, 10.00, 1.60 12/11/2018 09:00 0.000 10 1.420
12-11-2018 09:01:00, 10.00, 1.61 12/11/2018 09:01 0.000 10 1.430
12-11-2018 09:02:00, 10.00, 1.62 12/11/2018 09:02 0.010 10 1.440
12-11-2018 09:03:00, 10.00, 1.63 12/11/2018 09:03 0.010 10 1.450
12-11-2018 09:04:00, 10.00, 1.63 12/11/2018 09:04 0.010 10 1.450
12-11-2018 09:05:00, 10.00, 1.64 12/11/2018 09:05 0.000 10 1.460
12-11-2018 09:06:00, 10.00, 1.64 12/11/2018 09:06 0.010 10 1.460
12-11-2018 09:07:00, 0.00, 1.64 12/11/2018 09:07 0.000 0 1.460
12-11-2018 09:08:00, 10.00, 1.68 12/11/2018 09:08 0.000 10 1.500
12-11-2018 09:09:00, 10.00, 1.71 12/11/2018 09:09 0.040 10 1.530
12-11-2018 09:10:00, 0.00, 1.72 12/11/2018 09:10 0.030 0 1.540
12-11-2018 09:11:00, 10.00, 1.73 12/11/2018 09:11 0.010 10 1.550
12-11-2018 09:12:00, 10.00, 1.73 12/11/2018 09:12 0.010 10 1.550
12-11-2018 09:13:00, 10.00, 1.74 12/11/2018 09:13 0.000 10 1.560
12-11-2018 09:14:00, 10.00, 1.74 12/11/2018 09:14 0.010 10 1.560
12-11-2018 09:15:00, 10.00, 1.74 12/11/2018 09:15 0.000 10 1.560
12-11-2018 09:16:00, 0.00, 1.74 12/11/2018 09:16 0.000 0 1.560
12-11-2018 09:17:00, 0.00, 1.74 12/11/2018 09:17 0.000 0 1.560
12-11-2018 09:18:00, 0.00, 1.74 12/11/2018 09:18 0.000 0 1.560
12-11-2018 09:19:00, 0.00, 1.74 12/11/2018 09:19 0.000 0 1.560
12-11-2018 09:20:00, 0.00, 1.74 12/11/2018 09:20 0.000 0 1.560
12-11-2018 09:21:00, 10.00, 1.75 12/11/2018 09:21 0.000 10 1.570
12-11-2018 09:22:00, 10.00, 1.75 12/11/2018 09:22 0.010 10 1.570
12-11-2018 09:23:00, 10.00, 1.75 12/11/2018 09:23 0.000 10 1.570
12-11-2018 09:24:00, 0.00, 1.75 12/11/2018 09:24 0.000 0 1.570
12-11-2018 09:25:00, 10.00, 1.76 12/11/2018 09:25 0.000 10 1.580
12-11-2018 09:26:00, 10.00, 1.76 12/11/2018 09:26 0.010 10 1.580
12-11-2018 09:27:00, 10.00, 1.77 12/11/2018 09:27 0.000 10 1.590
12-11-2018 09:28:00, 10.00, 1.77 12/11/2018 09:28 0.010 10 1.590
12-11-2018 09:29:00, 10.00, 1.78 12/11/2018 09:29 0.000 10 1.600
12-11-2018 09:30:00, 10.00, 1.78 12/11/2018 09:30 0.010 10 1.600
12-11-2018 09:31:00, 10.00, 1.79 12/11/2018 09:31 0.000 10 1.610
12-11-2018 09:32:00, 10.00, 1.80 12/11/2018 09:32 0.010 10 1.620
12-11-2018 09:33:00, 10.00, 1.80 12/11/2018 09:33 0.010 10 1.620
12-11-2018 09:34:00, 10.00, 1.81 12/11/2018 09:34 0.000 10 1.630
12-11-2018 09:35:00, 10.00, 1.81 12/11/2018 09:35 0.010 10 1.630
12-11-2018 09:36:00, 10.00, 1.81 12/11/2018 09:36 0.000 10 1.630
12-11-2018 09:37:00, 10.00, 1.82 12/11/2018 09:37 0.000 10 1.640
12-11-2018 09:38:00, 10.00, 1.82 12/11/2018 09:38 0.010 10 1.640
12-11-2018 09:39:00, 0.00, 1.82 12/11/2018 09:39 0.000 0 1.640
12-11-2018 09:40:00, 0.00, 1.82 12/11/2018 09:40 0.000 0 1.640
12-11-2018 09:41:00, 10.00, 1.83 12/11/2018 09:41 0.000 10 1.650
12-11-2018 09:42:00, 10.00, 1.83 12/11/2018 09:42 0.010 10 1.650
12-11-2018 09:43:00, 10.00, 1.84 12/11/2018 09:43 0.000 10 1.660
12-11-2018 09:44:00, 10.00, 1.84 12/11/2018 09:44 0.010 10 1.660
12-11-2018 09:45:00, 0.00, 1.84 12/11/2018 09:45 0.000 10 1.660
12-11-2018 09:46:00, 10.00, 1.85 12/11/2018 09:46 0.000 10 1.670
12-11-2018 09:47:00, 10.00, 1.85 12/11/2018 09:47 0.010 10 1.670
12-11-2018 09:48:00, 0.00, 1.85 12/11/2018 09:48 0.000 0 1.670
12-11-2018 09:49:00, 10.00, 1.86 12/11/2018 09:49 0.000 10 1.680
12-11-2018 09:50:00, 10.00, 1.86 12/11/2018 09:50 0.010 10 1.680
12-11-2018 09:51:00, 10.00, 1.87 12/11/2018 09:51 0.000 10 1.690
12-11-2018 09:52:00, 10.00, 1.87 12/11/2018 09:52 0.010 10 1.690
12-11-2018 09:53:00, 10.00, 1.87 12/11/2018 09:53 0.000 10 1.690
12-11-2018 09:54:00, 10.00, 1.88 12/11/2018 09:54 0.000 10 1.700
12-11-2018 09:55:00, 10.00, 1.88 12/11/2018 09:55 0.010 10 1.700
12-11-2018 09:56:00, 0.00, 1.88 12/11/2018 09:56 0.000 0 1.700
12-11-2018 09:57:00, 0.00, 1.88 12/11/2018 09:57 0.000 0 1.700
12-11-2018 09:58:00, 10.00, 1.89 12/11/2018 09:58 0.000 10 1.710
12-11-2018 09:59:00, 10.00, 1.89 12/11/2018 09:59 0.010 10 1.710
12-11-2018 10:00:00, 10.00, 1.89 12/11/2018 10:00 0.000 10 1.710
12-11-2018 10:01:00, 10.00, 1.90 12/11/2018 10:01 0.000 10 1.720
12-11-2018 10:02:00, 10.00, 1.90 12/11/2018 10:02 0.010 10 1.720
12-11-2018 10:03:00, 10.00, 1.91 12/11/2018 10:03 0.000 10 1.730
12-11-2018 10:04:00, 10.00, 1.91 12/11/2018 10:04 0.010 10 1.730
12-11-2018 10:05:00, 0.00, 1.91 12/11/2018 10:05 0.000 0 1.730
12-11-2018 10:06:00, 0.00, 1.91 12/11/2018 10:06 0.000 0 1.730
12-11-2018 10:07:00, 10.00, 1.92 12/11/2018 10:07 0.000 10 1.740
12-11-2018 10:08:00, 10.00, 1.92 12/11/2018 10:08 0.010 10 1.740
12-11-2018 10:09:00, 10.00, 1.94 12/11/2018 10:09 0.000 10 1.760
12-11-2018 10:10:00, 10.00, 1.94 12/11/2018 10:10 0.020 10 1.760
12-11-2018 10:11:00, 10.00, 1.95 12/11/2018 10:11 0.000 10 1.770
12-11-2018 10:12:00, 10.00, 1.95 12/11/2018 10:12 0.010 10 1.770
12-11-2018 10:13:00, 10.00, 1.96 12/11/2018 10:13 0.000 10 1.780
12-11-2018 10:14:00, 10.00, 1.96 12/11/2018 10:14 0.010 10 1.780
12-11-2018 10:15:00, 10.00, 1.97 12/11/2018 10:15 0.000 10 1.790
12-11-2018 10:16:00, 10.00, 1.97 12/11/2018 10:16 0.010 10 1.790
12-11-2018 10:17:00, 0.00, 1.97 12/11/2018 10:17 0.000 0 1.790
12-11-2018 10:18:00, 10.00, 1.98 12/11/2018 10:18 0.000 10 1.800
12-11-2018 10:19:00, 10.00, 1.98 12/11/2018 10:19 0.010 10 1.800
12-11-2018 10:20:00, 0.00, 1.98 12/11/2018 10:20 0.000 0 1.800
12-11-2018 10:21:00, 10.00, 1.99 12/11/2018 10:21 0.000 10 1.810
12-11-2018 10:22:00, 10.00, 1.99 12/11/2018 10:22 0.010 10 1.810
12-11-2018 10:23:00, 10.00, 2.00 12/11/2018 10:23 0.000 10 1.820
12-11-2018 10:24:00, 10.00, 2.00 12/11/2018 10:24 0.010 10 1.820
12-11-2018 10:25:00, 10.00, 2.02 12/11/2018 10:25 0.000 10 1.840
12-11-2018 10:26:00, 10.00, 2.04 12/11/2018 10:26 0.020 10 1.860
12-11-2018 10:27:00, 10.00, 2.05 12/11/2018 10:27 0.020 10 1.870
12-11-2018 10:28:00, 10.00, 2.05 12/11/2018 10:28 0.010 10 1.870
12-11-2018 10:29:00, 10.00, 2.07 12/11/2018 10:29 0.000 10 1.890
12-11-2018 10:30:00, 10.00, 2.08 12/11/2018 10:30 0.020 10 1.900
12-11-2018 10:31:00, 10.00, 2.09 12/11/2018 10:31 0.010 10 1.910
12-11-2018 10:32:00, 10.00, 2.10 12/11/2018 10:32 0.010 10 1.920
12-11-2018 10:33:00, 10.00, 2.10 12/11/2018 10:33 0.010 10 1.920
12-11-2018 10:34:00, 10.00, 2.11 12/11/2018 10:34 0.000 10 1.930
12-11-2018 10:35:00, 10.00, 2.11 12/11/2018 10:35 0.010 10 1.930
12-11-2018 10:36:00, 0.00, 2.11 12/11/2018 10:36 0.000 0 1.930
12-11-2018 10:37:00, 0.00, 2.11 12/11/2018 10:37 0.000 0 1.930
12-11-2018 10:38:00, 10.00, 2.12 12/11/2018 10:38 0.000 10 1.940
12-11-2018 10:39:00, 10.00, 2.12 12/11/2018 10:39 0.010 10 1.940
12-11-2018 10:40:00, 10.00, 2.12 12/11/2018 10:40 0.000 10 1.940
12-11-2018 10:41:00, 0.00, 2.12 12/11/2018 10:41 0.000 0 1.940
12-11-2018 10:42:00, 10.00, 2.13 12/11/2018 10:42 0.000 10 1.950
12-11-2018 10:43:00, 10.00, 2.13 12/11/2018 10:43 0.010 10 1.950
12-11-2018 10:44:00, 10.00, 2.14 12/11/2018 10:44 0.000 10 1.960
12-11-2018 10:45:00, 10.00, 2.14 12/11/2018 10:45 0.010 10 1.960
12-11-2018 10:46:00, 10.00, 2.15 12/11/2018 10:46 0.000 10 1.970
12-11-2018 10:47:00, 10.00, 2.15 12/11/2018 10:47 0.010 10 1.970
12-11-2018 10:48:00, 10.00, 2.16 12/11/2018 10:48 0.000 10 1.980
12-11-2018 10:49:00, 10.00, 2.17 12/11/2018 10:49 0.010 10 1.990
12-11-2018 10:50:00, 10.00, 2.17 12/11/2018 10:50 0.010 10 1.990
12-11-2018 10:51:00, 10.00, 2.18 12/11/2018 10:51 0.000 10 2.000
12-11-2018 10:52:00, 10.00, 2.19 12/11/2018 10:52 0.010 10 2.010
12-11-2018 10:53:00, 10.00, 2.20 12/11/2018 10:53 0.010 10 2.020
12-11-2018 10:54:00, 10.00, 2.21 12/11/2018 10:54 0.010 10 2.030
12-11-2018 10:55:00, 10.00, 2.22 12/11/2018 10:55 0.010 10 2.040
12-11-2018 10:56:00, 10.00, 2.24 12/11/2018 10:56 0.010 10 2.060
12-11-2018 10:57:00, 10.00, 2.24 12/11/2018 10:57 0.020 10 2.060
12-11-2018 10:58:00, 10.00, 2.25 12/11/2018 10:58 0.000 10 2.070
12-11-2018 10:59:00, 10.00, 2.26 12/11/2018 10:59 0.010 10 2.080
12-11-2018 11:00:00, 10.00, 2.27 12/11/2018 11:00 0.010 10 2.090
12-11-2018 11:01:00, 10.00, 2.28 12/11/2018 11:01 0.010 10 2.090
12-11-2018 11:02:00, 10.00, 2.28 12/11/2018 11:02 0.000 10 2.090
12-11-2018 11:03:00, 10.00, 2.29 12/11/2018 11:03 0.000 10 2.100
12-11-2018 11:04:00, 10.00, 2.29 12/11/2018 11:04 0.010 10 2.100
12-11-2018 11:05:00, 10.00, 2.30 12/11/2018 11:05 0.000 10 2.110
12-11-2018 11:06:00, 10.00, 2.30 12/11/2018 11:06 0.010 10 2.110
12-11-2018 11:07:00, 10.00, 2.31 12/11/2018 11:07 0.000 10 2.120
12-11-2018 11:08:00, 10.00, 2.31 12/11/2018 11:08 0.010 10 2.120
12-11-2018 11:09:00, 10.00, 2.32 12/11/2018 11:09 0.000 10 2.130
12-11-2018 11:10:00, 10.00, 2.32 12/11/2018 11:10 0.010 10 2.130
12-11-2018 11:11:00, 10.00, 2.33 12/11/2018 11:11 0.000 10 2.140
12-11-2018 11:12:00, 10.00, 2.34 12/11/2018 11:12 0.010 10 2.150
12-11-2018 11:13:00, 10.00, 2.34 12/11/2018 11:13 0.010 10 2.150
12-11-2018 11:14:00, 0.00, 2.34 12/11/2018 11:14 0.000 0 2.150
12-11-2018 11:15:00, 10.00, 2.35 12/11/2018 11:15 0.000 10 2.160
12-11-2018 11:16:00, 10.00, 2.35 12/11/2018 11:16 0.010 10 2.160
12-11-2018 11:17:00, 10.00, 2.36 12/11/2018 11:17 0.000 10 2.170
12-11-2018 11:18:00, 10.00, 2.36 12/11/2018 11:18 0.010 10 2.170
12-11-2018 11:19:00, 10.00, 2.37 12/11/2018 11:19 0.000 10 2.180
12-11-2018 11:20:00, 10.00, 2.37 12/11/2018 11:20 0.010 10 2.180
12-11-2018 11:21:00, 0.00, 2.37 12/11/2018 11:21 0.000 0 2.180
12-11-2018 11:22:00, 0.00, 2.37 12/11/2018 11:22 0.000 0 2.180
12-11-2018 11:23:00, 0.00, 2.37 12/11/2018 11:23 0.000 0 2.180
12-11-2018 11:24:00, 0.00, 2.37 12/11/2018 11:24 0.000 0 2.180
12-11-2018 11:25:00, 0.00, 2.37 12/11/2018 11:25 0.000 0 2.180
12-11-2018 11:26:00, 0.00, 2.37 12/11/2018 11:26 0.000 0 2.180
12-11-2018 11:27:00, 0.00, 2.37 12/11/2018 11:27 0.000 0 2.180
12-11-2018 11:28:00, 0.00, 2.37 12/11/2018 11:28 0.000 0 2.180
12-11-2018 11:29:00, 0.00, 2.37 12/11/2018 11:29 0.000 0 2.180
12-11-2018 11:30:00, 0.00, 2.37 12/11/2018 11:30 0.000 0 2.180
12-11-2018 11:31:00, 10.00, 2.38 12/11/2018 11:31 0.000 10 2.190
12-11-2018 11:32:00, 10.00, 2.38 12/11/2018 11:32 0.010 10 2.190
12-11-2018 11:33:00, 0.00, 2.38 12/11/2018 11:33 0.000 0 2.190
12-11-2018 11:34:00, 0.00, 2.38 12/11/2018 11:34 0.000 0 2.190
12-11-2018 11:35:00, 0.00, 2.38 12/11/2018 11:35 0.000 0 2.190
12-11-2018 11:36:00, 0.00, 2.38 12/11/2018 11:36 0.000 0 2.190
12-11-2018 11:37:00, 0.00, 2.38 12/11/2018 11:37 0.000 0 2.190
12-11-2018 11:38:00, 0.00, 2.38 12/11/2018 11:38 0.000 0 2.190
12-11-2018 11:39:00, 0.00, 2.38 12/11/2018 11:39 0.000 0 2.190
12-11-2018 11:40:00, 0.00, 2.38 12/11/2018 11:40 0.000 0 2.190
12-11-2018 11:41:00, 0.00, 2.38 12/11/2018 11:41 0.000 0 2.190
12-11-2018 11:42:00, 0.00, 2.38 12/11/2018 11:42 0.000 0 2.190
12-11-2018 11:43:00, 0.00, 2.38 12/11/2018 11:43 0.000 0 2.190
12-11-2018 11:44:00, 0.00, 2.38 12/11/2018 11:44 0.000 0 2.190
12-11-2018 11:45:00, 0.00, 2.38 12/11/2018 11:45 0.000 0 2.190
12-11-2018 11:46:00, 0.00, 2.38 12/11/2018 11:46 0.000 0 2.190
12-11-2018 11:47:00, 0.00, 2.38 12/11/2018 11:47 0.000 0 2.190
12-11-2018 11:48:00, 10.00, 2.39 12/11/2018 11:48 0.000 10 2.200
12-11-2018 11:49:00, 10.00, 2.39 12/11/2018 11:49 0.010 10 2.200
12-11-2018 11:50:00, 0.00, 2.39 12/11/2018 11:50 0.000 0 2.200
12-11-2018 11:51:00, 0.00, 2.39 12/11/2018 11:51 0.000 0 2.200
12-11-2018 11:52:00, 10.00, 2.40 12/11/2018 11:52 0.000 10 2.210
12-11-2018 11:53:00, 10.00, 2.40 12/11/2018 11:53 0.010 10 2.210
12-11-2018 11:54:00, 0.00, 2.40 12/11/2018 11:54 0.000 0 2.210
12-11-2018 11:55:00, 10.00, 2.41 12/11/2018 11:55 0.000 10 2.220
12-11-2018 11:56:00, 10.00, 2.41 12/11/2018 11:56 0.010 10 2.220
12-11-2018 11:57:00, 0.00, 2.41 12/11/2018 11:57 0.000 0 2.220
12-11-2018 11:58:00, 10.00, 2.42 12/11/2018 11:58 0.000 10 2.230
12-11-2018 11:59:00, 10.00, 2.43 12/11/2018 11:59 0.010 10 2.240
12-11-2018 12:00:00, 10.00, 2.43 12/11/2018 12:00 0.010 10 2.240
12-11-2018 12:01:00, 0.00, 2.43 12/11/2018 12:01 0.000 0 2.240
12-11-2018 12:02:00, 6.00, 2.44 12/11/2018 12:02 0.000 0 2.240
12-11-2018 12:03:00, 10.00, 2.44 12/11/2018 12:03 0.000 10 2.240
12-11-2018 12:04:00, 10.00, 2.44 12/11/2018 12:04 0.000 10 2.240
12-11-2018 12:05:00, 0.00, 2.44 12/11/2018 12:05 0.000 0 2.240
12-11-2018 12:06:00, 0.00, 2.44 12/11/2018 12:06 0.000 0 2.240
12-11-2018 12:07:00, 0.00, 2.44 12/11/2018 12:07 0.000 0 2.240
12-11-2018 12:08:00, 0.00, 2.44 12/11/2018 12:08 0.000 0 2.240
12-11-2018 12:09:00, 0.00, 2.44 12/11/2018 12:09 0.000 0 2.240
12-11-2018 12:10:00, 0.00, 2.44 12/11/2018 12:10 0.000 0 2.240
12-11-2018 12:11:00, 0.00, 2.44 12/11/2018 12:11 0.000 0 2.240
12-11-2018 12:12:00, 0.00, 2.44 12/11/2018 12:12 0.000 0 2.240
12-11-2018 12:13:00, 0.00, 2.44 12/11/2018 12:13 0.000 0 2.240
12-11-2018 12:14:00, 0.00, 2.44 12/11/2018 12:14 0.000 0 2.240
12-11-2018 12:15:00, 0.00, 2.44 12/11/2018 12:15 0.000 0 2.240
12-11-2018 12:16:00, 10.00, 2.45 12/11/2018 12:16 0.000 10 2.250
When you have some spare time, would you have a look at this issue please?
With kind regards.
…i really suspect its the delay during the minute change…
I dont know whats causing it, i shut down internet as a test, but that didnt help either.
I really dont know why Loggernet isnt having this issue, maybe because its writing the data at a faster rate probably…
Ive openend the Loggernet logtool and saw it updating data twice a second.
It depends on the amount of rain a day, but on average its recording approximately 0.15mm short every 1.5mm.
it could be that WD is not reading in all the decimal places with the rain data
if you could .zip and email me your settings files and the data file used as the data source, and any other associated files, and detail how it should be setup
Ive send you the settings files and the datafile by mail.
Loggernet is running and updating the .dat file and cronpakbusnew is running because that way WD updates faster in the minutechange…
Below are some settings currently set in WD.
In the last post in this topic on page 2 theres a detailed list of rain data recorded by WD.
The csv files in the last picture below doesnt contain data, that probably because cronpakbusnew isnt getting data, but cronpakbusnew is running because that way WD updates faster during the minutechange…
With kind regards.
to stop the cronpakbus starting up
see the screen shots attached
to have the data received light flash,
use this version:
for me, using your settings,WD completes the minute change over with the seconds being at 2
if your pc is a bit slow and WD is taking too long, then it might be missing some rain tips
Thanks for your effort.
The data received box is flashing ok know, great.
The datalogger type setup doesnt hold its setting, when i choose the file input option, its always set to cr200 when i re-open the setting. Ive mentioned this earlier. See picture below.
WD is still updating much slower when not running cronpakbusnew along with WD.
Without running cronpakbusnew it takes around 6 seconds, when running cronpakbusnew its about 2.
Really dont know why.
The 60 excel files to check for missing windgusts during the minutechange in the WD folder arent present when not running cronpakbusnew. You have set that some time ago.
Could this be implemented again when cronpakbusnew isnt running? Maybe to check for missing rain too?
I am wondering if its technically possible to bypass the delay during the minutechange?
Maybe by setting it to update 2 or 3 times a second during the minutechange?
Or writing the mainscreen graphs and data to internet (WU and WOW for example) faster.
If so, i really like to help/test for you.
The datalogger type setup doesnt hold its setting, when i choose the file input option, its always set to cr200 when i re-open the setting. Ive mentioned this earlier. See picture below.that does not matter the main thing is now the cronbackbus program does not start up
I am not seeing the slow minute change here with your settings and input file
Ive watched the source data (the .dat file i send you) and thats updating flawless every second, no delay in the minutechange. Also the minute data file im running in Loggernet is updating every minute fine without delay.
Do the Davis station users have the same delay during the minutechange?
Even if i stop the source from updating, WD is showing the delay.
Regarding the 60 csv files produced every minute to check for missing data when cronpakbusnew was running, isnt produced now cronpakbusnew isnt running.
Is it possible these can be produced again to check for missing data during the minutechange when cronpakbusnew isnt running now?
I just noticed when having the source data (.dat file) screen running next to the WD mainscreen that the live time shown on WD mainscreen sometimes makes a 2 second step instead of 1, and that the data shown in WD is one second behind the source data.
Could this be the delay issue?
Hi Brian, good morning,
I was wondering if its technically possible to resolve the minutechange delay?
That would solve this issue fine
It isnt related to pc, its a i5 processor with 8gb memory. Only running WD and Loggernet.
Not better when i switch off internet, no (animated) images running on the mainscreen…
The datasource hasnt got delays and is running smoothly.
You mentioned in a previously post “if WD is taking too long”, whats the cause of that?
With the kindest regards.
If the delay cant be fixed technically, (which i think can be done by increasing the update rate during the minutechange and solve this finally), a solution could be the check every minutechange, which was present when cronpakbusnew was running (now isnt) , was running to check for missing windgusts and other weather data during the annoying delay (60 excel files every minute overwritten in the WD folder…)
WD is running flawless with my hardware, except the issue mentioned above.
Is it technically possible to resolve it?
With kind regards.
I assume this isnt something thats possible to get solved no?
No, ok. I will correct the raintotals every end of the day by using data from Loggernet, which hasnt got the delay in the minute change so it doesnt miss raintips (and maybe more weatherdata…) on the minute change…
…as seen in this custom 1 second log, its missing data…
Unfortunately no seconds are shown, so you have to count the amount of data in a minute…
In the 22:47 its missing 5 seconds of data.
https://youtu.be/ljmdikk7_pI
13/1/2019 22:46 0.000 0 0.170
13/1/2019 22:47 0.000 0 0.170
13/1/2019 22:48 0.000 0 0.170
13/1/2019 22:49 0.000 0 0.170
13/1/2019 22:50 0.000 0 0.170
