Thanks for your reply, much appreciated.
Let me try to explain the issue.
I dont use the cronpakbusnew because im running WD together with Loggernet.
You mentioned to use the file input, but its not saving. On reopening its always set to cr200.
WD is using the public.dat file which update every second, live data.
No i havent set a solar offset, its showing 1.5 at night on mainscreen, but when i restart WD the solar data field on mainscreen is empty.
Re the data received not going green, would be great if its working so i see all is ok.
The 60 Excel files in the WD map updating every minute to check missing data on the minutecange dont contain data, i think because cronpakbus isnt running?
Could that cause the rainamout issue? See picture above and attatched.
I noticed since i dont use the cronpakbusnew, the minutechange takes sometimes more then 5 or so seconds.
With kindest regards.
