Author Topic: Reading from. dat file  (Read 2838 times)
Offline Asperitas
  • Android 7.0
  • Chrome 59.0.3071.125
Re: Reading from. dat file
« Reply #15 on: September 05, 2018, 06:41:53 PM »
Hi Brian, good morning :D
I just noticed when i choose the file input option, it doesnt save that setting.
When i reopen it, its always set to CR200...
I dont know if thats the cause of the above?
« Last Edit: September 05, 2018, 06:44:31 PM by Asperitas »
  • Davis VP2
  • New Zealand
  • Win NT 10.0
  • Chrome 68.0.3440.106
    • Weather Display
« Reply #16 on: September 06, 2018, 07:00:24 PM »
the next update of WD will fix that
make sure in the wdisplay.ini file
that
[Hawk settings]
device typenew=0
device type=0
Offline Asperitas
  • Android 7.0
  • Chrome 69.0.3497.76
« Reply #17 on: September 06, 2018, 07:32:55 PM »
Thanks for your reply.
I checked the wdisplay.ini file, they were set to 0.
Offline Asperitas
  • Android 7.0
« Reply #18 on: September 07, 2018, 01:41:47 AM »
Im running latest update,  but no change unfortunately.
I noticed the following:
1  The file input selection still doesnt save.
2  The minute change takes aproximately 5-7 seconds.
3 The rain amount isnt correct, on mainscreen and in the custom log file, see attached picture.
4 The max and min time values on the mainscreen from all weather data are all one minute before the actual
  Time  max/min values.
5 the solar value on the mainscreen is showing 1.5 w/m2 at night, while the solar source (the .dat file) is actually zero.
One minor thing,  but maybe related to an error: the data received box on the mainscreen is always red.
Maybe because of an error on my side?
« Last Edit: September 10, 2018, 08:36:01 AM by Asperitas »
Offline Asperitas
  • Android 7.0
« Reply #19 on: September 10, 2018, 05:25:54 AM »
Hi Brian, good afternoon.
I have checked all my settings and with my little knowledge i hope i have set up WD ok.
But i may have missed a setting #-o i dont know of :oops: perhaps...?
With kindest regards.
« Last Edit: September 10, 2018, 05:45:29 AM by Asperitas »
Offline Asperitas
  • Android 7.0
« Reply #20 on: September 10, 2018, 03:18:56 PM »
...i tried as a test to run cronpakbus.exe manually after WD started.
Cronpakbusnew isnt getting data but wd is faster in the minute change,  it takes now around 2-3 seconds.
Will keep an eye on the issues mentioned previously, they maybe solved when cronpakbusnew is running along with WD while its not getting data...
With kind regards.
Offline Asperitas
  • Win NT 10.0
« Reply #21 on: September 18, 2018, 09:14:57 AM »
im running WD fine, but only with cronpakbusnew along with it, otherwise the minutechange take 5-7 seconds.
With cronpakbusnew running at the same time it takes 1-2 seconds.
Is it possible to have WD running fine without having to run cronpakbusnew along with WD?
Just 4 issues keeps popping up:
- the solar live data on the mainscreen above the winddials keeps displaying 1.5 w/m2 at night, while the source is 0.
- the data received coloured box on the mainscreen WD is always red, not showing green flashing.
- The rain amount isnt good, it somtimes differ 1mm a day, compared to the source (.dat file)
- The file input option still cant be changed to file input, its always set to CR200 on re-opening it.
With kind regards.
« Last Edit: October 01, 2018, 05:29:24 PM by Asperitas »
Offline Asperitas
  • Android 7.0
  • Chrome 63.0.3239.111
« Reply #22 on: October 01, 2018, 05:19:24 PM »
Sorry to bring this up again, but im still having those symptoms mentioned above unfortunately...
« Last Edit: October 01, 2018, 05:23:00 PM by Asperitas »
Offline Asperitas
  • Android 7.0
  • Chrome 70.0.3538.64
« Reply #23 on: October 25, 2018, 05:53:26 AM »
Sorry to bring this up again :oops:
But im still having these issues.
With kind regards.
Offline Asperitas
  • Win NT 10.0
  • Chrome 69.0.3497.100
« Reply #24 on: November 08, 2018, 08:45:42 AM »
...i think the rain amount issue is related to the delay in the minute change.
its missing catching data at that time.
Offline Asperitas
  • Android 7.0
  • Chrome 70.0.3538.80
« Reply #25 on: November 09, 2018, 08:53:57 PM »
Nevermind.
I manually set the raintotals at the end of each day with rain. :roll:
  • Davis VP2
  • New Zealand
  • Win NT 10.0
  • Chrome 70.0.3538.77
    • Weather Display
« Reply #26 on: November 11, 2018, 09:26:25 PM »
re the solar, maybe you have set a solar offset?
the data received not going green is just a minor cosmetic issue...wont affect anything..but I can fix
Quote
do you mean you need to use the file input option? (i.e set to use the logfile created by the campbell scientific software....which if that is the case then cronpakbus does not need to run I would have thought
Offline Asperitas
  • Android 7.0
« Reply #27 on: November 12, 2018, 05:49:26 AM »
Thanks for your reply, much appreciated.
Let me try to explain the issue. :D
I dont use the cronpakbusnew because im running WD together with Loggernet.
You mentioned to use the file input, but its not saving. On reopening its always set to cr200.
WD is using the public.dat file which update every second, live data.
No i havent set a solar offset, its showing 1.5 at night on mainscreen, but when i restart WD the solar data field on mainscreen is empty.
Re the data received not going green, would be great if its working so i see all is ok.
The 60 Excel files in the WD map updating every minute to check missing data on the minutecange dont contain data, i think because cronpakbus isnt running?
Could that cause the rainamout issue? See picture above and attatched.
I noticed since i dont use the cronpakbusnew,  the minutechange takes sometimes more then 5 or so seconds.
« Last Edit: November 12, 2018, 06:38:19 AM by Asperitas »
Offline Asperitas
  • Win NT 10.0
  • Chrome 64.0.3282.140
« Reply #28 on: November 12, 2018, 01:43:46 PM »
I managed to get the data from the source and from WD side by side.
The data on the left is the source, on the right from WD.
As you can see, from 04:58, WD is missing data:
12-11-2018 04:33:00, 0.00, 0.00               12/11/2018  04:33  0.000  0 0.000
12-11-2018 04:34:00, 10.00, 0.01               12/11/2018  04:34  0.000  10 0.010
12-11-2018 04:35:00, 10.00, 0.01               12/11/2018  04:35  0.010  10 0.010
12-11-2018 04:36:00, 0.00, 0.01               12/11/2018  04:36  0.000  0 0.010
12-11-2018 04:37:00, 0.00, 0.01               12/11/2018  04:37  0.000  0 0.010
12-11-2018 04:38:00, 10.00, 0.02               12/11/2018  04:38  0.000  10 0.020
12-11-2018 04:39:00, 10.00, 0.02               12/11/2018  04:39  0.010  10 0.020
12-11-2018 04:40:00, 0.00, 0.02               12/11/2018  04:40  0.000  0 0.020
12-11-2018 04:41:00, 0.00, 0.02               12/11/2018  04:41  0.000  0 0.020
12-11-2018 04:42:00, 0.00, 0.02               12/11/2018  04:42  0.000  0 0.020
12-11-2018 04:43:00, 0.00, 0.02               12/11/2018  04:43  0.000  0 0.020
12-11-2018 04:44:00, 0.00, 0.02               12/11/2018  04:44  0.000  0 0.020
12-11-2018 04:45:00, 0.00, 0.02               12/11/2018  04:45  0.000  0 0.020
12-11-2018 04:46:00, 0.00, 0.02               12/11/2018  04:46  0.000  0 0.020
12-11-2018 04:47:00, 0.00, 0.02               12/11/2018  04:47  0.000  0 0.020
12-11-2018 04:48:00, 10.00, 0.03               12/11/2018  04:48  0.000  10 0.030
12-11-2018 04:49:00, 10.00, 0.03               12/11/2018  04:49  0.010  10 0.030
12-11-2018 04:50:00, 0.00, 0.03               12/11/2018  04:50  0.000  0 0.030
12-11-2018 04:51:00, 0.00, 0.03               12/11/2018  04:51  0.000  0 0.030
12-11-2018 04:52:00, 10.00, 0.04               12/11/2018  04:52  0.000  10 0.040
12-11-2018 04:53:00, 10.00, 0.04               12/11/2018  04:53  0.010  10 0.040
12-11-2018 04:54:00, 10.00, 0.04               12/11/2018  04:54  0.000  10 0.040
12-11-2018 04:55:00, 0.00, 0.04               12/11/2018  04:55  0.000  0 0.040
12-11-2018 04:56:00, 0.00, 0.04               12/11/2018  04:56  0.000  0 0.040
12-11-2018 04:57:00, 0.00, 0.04               12/11/2018  04:57  0.000  0 0.040
12-11-2018 04:58:00, 0.00, 0.05               12/11/2018  04:58  0.000  0 0.040
12-11-2018 04:59:00, 10.00, 0.05               12/11/2018  04:59  0.000  10 0.040
12-11-2018 05:00:00, 10.00, 0.05               12/11/2018  05:00  0.000  10 0.040
12-11-2018 05:01:00, 0.00, 0.05               12/11/2018  05:01  0.000  0 0.040
12-11-2018 05:02:00, 10.00, 0.06               12/11/2018  05:02  0.000  10 0.050
12-11-2018 05:03:00, 10.00, 0.06               12/11/2018  05:03  0.010  10 0.050
12-11-2018 05:04:00, 0.00, 0.06               12/11/2018  05:04  0.000  0 0.050
12-11-2018 05:05:00, 0.00, 0.06               12/11/2018  05:05  0.000  0 0.050
12-11-2018 05:06:00, 0.00, 0.06               12/11/2018  05:06  0.000  0 0.050
12-11-2018 05:07:00, 0.00, 0.06               12/11/2018  05:07  0.000  0 0.050
12-11-2018 05:08:00, 10.00, 0.07               12/11/2018  05:08  0.000  10 0.060
12-11-2018 05:09:00, 10.00, 0.07               12/11/2018  05:09  0.010  10 0.060
12-11-2018 05:10:00, 10.00, 0.08               12/11/2018  05:10  0.000  10 0.070
12-11-2018 05:11:00, 10.00, 0.09               12/11/2018  05:11  0.010  10 0.080
12-11-2018 05:12:00, 10.00, 0.09               12/11/2018  05:12  0.010  10 0.080
12-11-2018 05:13:00, 0.00, 0.09               12/11/2018  05:13  0.000  0 0.080
12-11-2018 05:14:00, 0.00, 0.09               12/11/2018  05:14  0.000  0 0.080
12-11-2018 05:15:00, 10.00, 0.10               12/11/2018  05:15  0.000  10 0.090
12-11-2018 05:16:00, 10.00, 0.10               12/11/2018  05:16  0.010  10 0.090
12-11-2018 05:17:00, 0.00, 0.10               12/11/2018  05:17  0.000  0 0.090
12-11-2018 05:18:00, 0.00, 0.10               12/11/2018  05:18  0.000  0 0.090
12-11-2018 05:19:00, 10.00, 0.11               12/11/2018  05:19  0.000  10 0.100
12-11-2018 05:20:00, 10.00, 0.11               12/11/2018  05:20  0.010  10 0.100
12-11-2018 05:21:00, 10.00, 0.12               12/11/2018  05:21  0.000  10 0.110
12-11-2018 05:22:00, 10.00, 0.12               12/11/2018  05:22  0.010  10 0.110
12-11-2018 05:23:00, 10.00, 0.13               12/11/2018  05:23  0.000  10 0.120
12-11-2018 05:24:00, 10.00, 0.14               12/11/2018  05:24  0.010  10 0.130
12-11-2018 05:25:00, 10.00, 0.14               12/11/2018  05:25  0.010  10 0.130
12-11-2018 05:26:00, 10.00, 0.14               12/11/2018  05:26  0.000  10 0.130
12-11-2018 05:27:00, 10.00, 0.15               12/11/2018  05:27  0.000  10 0.140
12-11-2018 05:28:00, 10.00, 0.16               12/11/2018  05:28  0.010  10 0.150
12-11-2018 05:29:00, 10.00, 0.16               12/11/2018  05:29  0.010  10 0.150
12-11-2018 05:30:00, 10.00, 0.17               12/11/2018  05:30  0.000  10 0.160
12-11-2018 05:31:00, 10.00, 0.17               12/11/2018  05:31  0.010  10 0.160
12-11-2018 05:32:00, 10.00, 0.18               12/11/2018  05:32  0.000  10 0.170
12-11-2018 05:33:00, 10.00, 0.18               12/11/2018  05:33  0.010  10 0.170
12-11-2018 05:34:00, 0.00, 0.18               12/11/2018  05:34  0.000  0 0.170
12-11-2018 05:35:00, 10.00, 0.19               12/11/2018  05:35  0.000  10 0.180
12-11-2018 05:36:00, 10.00, 0.19               12/11/2018  05:36  0.010  10 0.180
12-11-2018 05:37:00, 10.00, 0.19               12/11/2018  05:37  0.000  10 0.180
12-11-2018 05:38:00, 10.00, 0.20               12/11/2018  05:38  0.000  10 0.190
12-11-2018 05:39:00, 10.00, 0.20               12/11/2018  05:39  0.010  10 0.190
12-11-2018 05:40:00, 0.00, 0.20               12/11/2018  05:40  0.000  0 0.190
12-11-2018 05:41:00, 0.00, 0.20               12/11/2018  05:41  0.000  0 0.190
12-11-2018 05:42:00, 10.00, 0.21               12/11/2018  05:42  0.000  10 0.200
12-11-2018 05:43:00, 10.00, 0.21               12/11/2018  05:43  0.010  10 0.200
12-11-2018 05:44:00, 0.00, 0.21               12/11/2018  05:44  0.000  0 0.200
12-11-2018 05:45:00, 10.00, 0.22               12/11/2018  05:45  0.000  10 0.210
12-11-2018 05:46:00, 10.00, 0.22               12/11/2018  05:46  0.010  10 0.210
12-11-2018 05:47:00, 10.00, 0.23               12/11/2018  05:47  0.000  9 0.220
12-11-2018 05:48:00, 10.00, 0.23               12/11/2018  05:48  0.010  10 0.220
12-11-2018 05:49:00, 10.00, 0.24               12/11/2018  05:49  0.000  10 0.230
12-11-2018 05:50:00, 10.00, 0.25               12/11/2018  05:50  0.010  10 0.240
12-11-2018 05:51:00, 10.00, 0.26               12/11/2018  05:51  0.010  10 0.250
12-11-2018 05:52:00, 10.00, 0.27               12/11/2018  05:52  0.010  10 0.260
12-11-2018 05:53:00, 10.00, 0.28               12/11/2018  05:53  0.010  10 0.270
12-11-2018 05:54:00, 10.00, 0.30               12/11/2018  05:54  0.010  10 0.280
12-11-2018 05:55:00, 10.00, 0.30               12/11/2018  05:55  0.010  10 0.280
12-11-2018 05:56:00, 10.00, 0.31               12/11/2018  05:56  0.000  10 0.280
12-11-2018 05:57:00, 10.00, 0.32               12/11/2018  05:57  0.000  10 0.290
12-11-2018 05:58:00, 10.00, 0.32               12/11/2018  05:58  0.010  10 0.290
12-11-2018 05:59:00, 10.00, 0.33               12/11/2018  05:59  0.000  10 0.300
12-11-2018 06:00:00, 10.00, 0.34               12/11/2018  06:00  0.010  10 0.310
12-11-2018 06:01:00, 10.00, 0.36               12/11/2018  06:01  0.010  10 0.330
12-11-2018 06:02:00, 10.00, 0.37               12/11/2018  06:02  0.020  10 0.340
12-11-2018 06:03:00, 10.00, 0.38               12/11/2018  06:03  0.010  10 0.350
12-11-2018 06:04:00, 10.00, 0.39               12/11/2018  06:04  0.010  10 0.360
12-11-2018 06:05:00, 10.00, 0.40               12/11/2018  06:05  0.010  10 0.370
12-11-2018 06:06:00, 10.00, 0.41               12/11/2018  06:06  0.010  10 0.380
12-11-2018 06:07:00, 10.00, 0.42               12/11/2018  06:07  0.010  10 0.390
12-11-2018 06:08:00, 10.00, 0.44               12/11/2018  06:08  0.010  10 0.410
12-11-2018 06:09:00, 10.00, 0.44               12/11/2018  06:09  0.020  10 0.410
12-11-2018 06:10:00, 0.00, 0.44               12/11/2018  06:10  0.000  0 0.410
12-11-2018 06:11:00, 10.00, 0.45               12/11/2018  06:11  0.000  10 0.410
12-11-2018 06:12:00, 10.00, 0.46               12/11/2018  06:12  0.000  10 0.410
12-11-2018 06:13:00, 10.00, 0.47               12/11/2018  06:13  0.000  10 0.420
12-11-2018 06:14:00, 10.00, 0.47               12/11/2018  06:14  0.010  10 0.420
12-11-2018 06:15:00, 10.00, 0.48               12/11/2018  06:15  0.000  10 0.430
12-11-2018 06:16:00, 10.00, 0.48               12/11/2018  06:16  0.010  10 0.430
12-11-2018 06:17:00, 0.00, 0.48               12/11/2018  06:17  0.000  0 0.430
12-11-2018 06:18:00, 0.00, 0.48               12/11/2018  06:18  0.000  0 0.430
12-11-2018 06:19:00, 10.00, 0.49               12/11/2018  06:19  0.000  10 0.440
12-11-2018 06:20:00, 10.00, 0.49               12/11/2018  06:20  0.010  10 0.440
12-11-2018 06:21:00, 10.00, 0.50               12/11/2018  06:21  0.000  10 0.450
12-11-2018 06:22:00, 10.00, 0.50               12/11/2018  06:22  0.010  10 0.450
12-11-2018 06:23:00, 10.00, 0.51               12/11/2018  06:23  0.000  10 0.460
12-11-2018 06:24:00, 10.00, 0.51               12/11/2018  06:24  0.010  10 0.460
12-11-2018 06:25:00, 10.00, 0.52               12/11/2018  06:25  0.000  10 0.470
12-11-2018 06:26:00, 10.00, 0.52               12/11/2018  06:26  0.010  10 0.470
12-11-2018 06:27:00, 10.00, 0.54               12/11/2018  06:27  0.000  10 0.480
12-11-2018 06:28:00, 10.00, 0.54               12/11/2018  06:28  0.010  10 0.480
12-11-2018 06:29:00, 10.00, 0.55               12/11/2018  06:29  0.000  10 0.490
12-11-2018 06:30:00, 10.00, 0.56               12/11/2018  06:30  0.010  10 0.500
12-11-2018 06:31:00, 10.00, 0.57               12/11/2018  06:31  0.010  10 0.510
12-11-2018 06:32:00, 10.00, 0.57               12/11/2018  06:32  0.010  10 0.510
12-11-2018 06:33:00, 10.00, 0.58               12/11/2018  06:33  0.000  10 0.520
12-11-2018 06:34:00, 10.00, 0.59               12/11/2018  06:34  0.010  10 0.530
12-11-2018 06:35:00, 10.00, 0.59               12/11/2018  06:35  0.010  10 0.530
12-11-2018 06:36:00, 0.00, 0.59               12/11/2018  06:36  0.000  0 0.530
12-11-2018 06:37:00, 10.00, 0.60               12/11/2018  06:37  0.000  10 0.540
12-11-2018 06:38:00, 10.00, 0.60               12/11/2018  06:38  0.010  10 0.540
12-11-2018 06:39:00, 0.00, 0.60               12/11/2018  06:39  0.000  0 0.540
12-11-2018 06:40:00, 0.00, 0.60               12/11/2018  06:40  0.000  0 0.540
12-11-2018 06:41:00, 10.00, 0.61               12/11/2018  06:41  0.000  10 0.540
12-11-2018 06:42:00, 10.00, 0.62               12/11/2018  06:42  0.000  10 0.550
12-11-2018 06:43:00, 10.00, 0.62               12/11/2018  06:43  0.010  10 0.550
12-11-2018 06:44:00, 0.00, 0.62               12/11/2018  06:44  0.000  0 0.550
12-11-2018 06:45:00, 10.00, 0.63               12/11/2018  06:45  0.000  10 0.560
12-11-2018 06:46:00, 10.00, 0.63               12/11/2018  06:46  0.010  10 0.560
12-11-2018 06:47:00, 0.00, 0.63               12/11/2018  06:47  0.000  0 0.560
12-11-2018 06:48:00, 0.00, 0.63               12/11/2018  06:48  0.000  0 0.560
12-11-2018 06:49:00, 0.00, 0.63               12/11/2018  06:49  0.000  0 0.560
12-11-2018 06:50:00, 10.00, 0.64               12/11/2018  06:50  0.000  6 0.570
12-11-2018 06:51:00, 10.00, 0.64               12/11/2018  06:51  0.010  10 0.570
12-11-2018 06:52:00, 10.00, 0.64               12/11/2018  06:52  0.000  10 0.570
12-11-2018 06:53:00, 0.00, 0.64               12/11/2018  06:53  0.000  0 0.570
12-11-2018 06:54:00, 0.00, 0.64               12/11/2018  06:54  0.000  0 0.570
12-11-2018 06:55:00, 10.00, 0.65               12/11/2018  06:55  0.000  10 0.580
12-11-2018 06:56:00, 10.00, 0.65               12/11/2018  06:56  0.010  10 0.580
12-11-2018 06:57:00, 0.00, 0.65               12/11/2018  06:57  0.000  0 0.580
12-11-2018 06:58:00, 0.00, 0.65               12/11/2018  06:58  0.000  0 0.580
12-11-2018 06:59:00, 0.00, 0.65               12/11/2018  06:59  0.000  0 0.580
12-11-2018 07:00:00, 10.00, 0.66               12/11/2018  07:00  0.000  10 0.590
12-11-2018 07:01:00, 10.00, 0.66               12/11/2018  07:01  0.010  10 0.590
12-11-2018 07:02:00, 0.00, 0.66               12/11/2018  07:02  0.000  0 0.590
12-11-2018 07:03:00, 0.00, 0.66               12/11/2018  07:03  0.000  0 0.590
12-11-2018 07:04:00, 10.00, 0.67               12/11/2018  07:04  0.000  10 0.600
12-11-2018 07:05:00, 10.00, 0.67               12/11/2018  07:05  0.010  10 0.600
12-11-2018 07:06:00, 0.00, 0.67               12/11/2018  07:06  0.000  0 0.600
12-11-2018 07:07:00, 10.00, 0.68               12/11/2018  07:07  0.000  10 0.610
12-11-2018 07:08:00, 10.00, 0.68               12/11/2018  07:08  0.010  10 0.610
12-11-2018 07:09:00, 0.00, 0.68               12/11/2018  07:09  0.000  0 0.610
12-11-2018 07:10:00, 0.00, 0.68               12/11/2018  07:10  0.000  0 0.610
12-11-2018 07:11:00, 0.00, 0.68               12/11/2018  07:11  0.000  0 0.610
12-11-2018 07:12:00, 10.00, 0.69               12/11/2018  07:12  0.000  10 0.620
12-11-2018 07:13:00, 10.00, 0.69               12/11/2018  07:13  0.010  10 0.620
12-11-2018 07:14:00, 0.00, 0.69               12/11/2018  07:14  0.000  0 0.620
12-11-2018 07:15:00, 0.00, 0.69               12/11/2018  07:15  0.000  0 0.620
12-11-2018 07:16:00, 0.00, 0.69               12/11/2018  07:16  0.000  0 0.620
12-11-2018 07:17:00, 0.00, 0.69               12/11/2018  07:17  0.000  0 0.620
12-11-2018 07:18:00, 0.00, 0.69               12/11/2018  07:18  0.000  0 0.620
12-11-2018 07:19:00, 0.00, 0.69               12/11/2018  07:19  0.000  0 0.620
12-11-2018 07:20:00, 10.00, 0.70               12/11/2018  07:20  0.000  10 0.630
12-11-2018 07:21:00, 10.00, 0.70               12/11/2018  07:21  0.010  10 0.630
12-11-2018 07:22:00, 10.00, 0.71               12/11/2018  07:22  0.000  10 0.640
12-11-2018 07:23:00, 10.00, 0.71               12/11/2018  07:23  0.010  10 0.640
12-11-2018 07:24:00, 10.00, 0.72               12/11/2018  07:24  0.000  10 0.650
12-11-2018 07:25:00, 10.00, 0.72               12/11/2018  07:25  0.010  10 0.650
12-11-2018 07:26:00, 0.00, 0.72               12/11/2018  07:26  0.000  0 0.650
12-11-2018 07:27:00, 10.00, 0.73               12/11/2018  07:27  0.000  10 0.660
12-11-2018 07:28:00, 10.00, 0.74               12/11/2018  07:28  0.010  10 0.670
12-11-2018 07:29:00, 10.00, 0.74               12/11/2018  07:29  0.010  10 0.670
12-11-2018 07:30:00, 0.00, 0.74               12/11/2018  07:30  0.000  0 0.670
12-11-2018 07:31:00, 10.00, 0.75               12/11/2018  07:31  0.000  10 0.680
12-11-2018 07:32:00, 10.00, 0.75               12/11/2018  07:32  0.010  10 0.680
12-11-2018 07:33:00, 10.00, 0.76               12/11/2018  07:33  0.000  10 0.690
12-11-2018 07:34:00, 10.00, 0.77               12/11/2018  07:34  0.010  10 0.700
12-11-2018 07:35:00, 10.00, 0.78               12/11/2018  07:35  0.010  10 0.710
12-11-2018 07:36:00, 10.00, 0.78               12/11/2018  07:36  0.010  10 0.710
12-11-2018 07:37:00, 10.00, 0.79               12/11/2018  07:37  0.000  10 0.720
12-11-2018 07:38:00, 10.00, 0.79               12/11/2018  07:38  0.010  10 0.720
12-11-2018 07:39:00, 10.00, 0.80               12/11/2018  07:39  0.000  10 0.730
12-11-2018 07:40:00, 10.00, 0.81               12/11/2018  07:40  0.010  10 0.740
12-11-2018 07:41:00, 10.00, 0.82               12/11/2018  07:41  0.010  10 0.750
12-11-2018 07:42:00, 10.00, 0.83               12/11/2018  07:42  0.010  10 0.760
12-11-2018 07:43:00, 10.00, 0.85               12/11/2018  07:43  0.010  10 0.770
12-11-2018 07:44:00, 10.00, 0.86               12/11/2018  07:44  0.010  10 0.780
12-11-2018 07:45:00, 10.00, 0.87               12/11/2018  07:45  0.010  10 0.790
12-11-2018 07:46:00, 10.00, 0.88               12/11/2018  07:46  0.010  10 0.790
12-11-2018 07:47:00, 10.00, 0.90               12/11/2018  07:47  0.000  10 0.810
12-11-2018 07:48:00, 10.00, 0.91               12/11/2018  07:48  0.020  10 0.810
12-11-2018 07:49:00, 10.00, 0.92               12/11/2018  07:49  0.000  10 0.810
12-11-2018 07:50:00, 10.00, 0.93               12/11/2018  07:50  0.000  10 0.820
12-11-2018 07:51:00, 10.00, 0.94               12/11/2018  07:51  0.010  10 0.830
12-11-2018 07:52:00, 10.00, 0.95               12/11/2018  07:52  0.010  10 0.840
12-11-2018 07:53:00, 10.00, 0.96               12/11/2018  07:53  0.010  10 0.850
12-11-2018 07:54:00, 10.00, 0.96               12/11/2018  07:54  0.010  10 0.850
12-11-2018 07:55:00, 10.00, 0.97               12/11/2018  07:55  0.000  10 0.860
12-11-2018 07:56:00, 10.00, 0.99               12/11/2018  07:56  0.010  10 0.880
12-11-2018 07:57:00, 10.00, 1.01               12/11/2018  07:57  0.020  10 0.900
12-11-2018 07:58:00, 10.00, 1.02               12/11/2018  07:58  0.020  10 0.910
12-11-2018 07:59:00, 10.00, 1.04               12/11/2018  07:59  0.010  10 0.920
« Last Edit: November 12, 2018, 01:47:48 PM by Asperitas »
Offline Asperitas
  • Win NT 10.0
« Reply #29 on: November 12, 2018, 01:45:46 PM »
Continued from previous page...
12-11-2018 08:00:00, 10.00, 1.05               12/11/2018  08:00  0.010  10 0.920
12-11-2018 08:01:00, 10.00, 1.06               12/11/2018  08:01  0.010  10 0.920
12-11-2018 08:02:00, 10.00, 1.07               12/11/2018  08:02  0.010  10 0.920
12-11-2018 08:03:00, 10.00, 1.09               12/11/2018  08:03  0.010  10 0.950
12-11-2018 08:04:00, 10.00, 1.11               12/11/2018  08:04  0.020  10 0.970
12-11-2018 08:05:00, 10.00, 1.11               12/11/2018  08:05  0.020  10 0.970
12-11-2018 08:06:00, 10.00, 1.13               12/11/2018  08:06  0.000  10 0.970
12-11-2018 08:07:00, 10.00, 1.15               12/11/2018  08:07  0.000  10 0.980
12-11-2018 08:08:00, 10.00, 1.17               12/11/2018  08:08  0.010  10 1.000
12-11-2018 08:09:00, 10.00, 1.18               12/11/2018  08:09  0.020  10 1.010
12-11-2018 08:10:00, 10.00, 1.19               12/11/2018  08:10  0.010  10 1.020
12-11-2018 08:11:00, 10.00, 1.20               12/11/2018  08:11  0.010  10 1.030
12-11-2018 08:12:00, 10.00, 1.21               12/11/2018  08:12  0.010  10 1.040
12-11-2018 08:13:00, 10.00, 1.22               12/11/2018  08:13  0.010  10 1.050
12-11-2018 08:14:00, 10.00, 1.24               12/11/2018  08:14  0.010  10 1.070
12-11-2018 08:15:00, 10.00, 1.25               12/11/2018  08:15  0.020  10 1.080
12-11-2018 08:16:00, 10.00, 1.27               12/11/2018  08:16  0.010  10 1.100
12-11-2018 08:17:00, 10.00, 1.29               12/11/2018  08:17  0.020  10 1.120
12-11-2018 08:18:00, 10.00, 1.30               12/11/2018  08:18  0.020  10 1.130
12-11-2018 08:19:00, 10.00, 1.31               12/11/2018  08:19  0.010  10 1.140
12-11-2018 08:20:00, 10.00, 1.32               12/11/2018  08:20  0.010  10 1.150
12-11-2018 08:21:00, 10.00, 1.32               12/11/2018  08:21  0.010  10 1.150
12-11-2018 08:22:00, 10.00, 1.33               12/11/2018  08:22  0.000  10 1.160
12-11-2018 08:23:00, 10.00, 1.33               12/11/2018  08:23  0.010  10 1.160
12-11-2018 08:24:00, 10.00, 1.34               12/11/2018  08:24  0.000  10 1.170
12-11-2018 08:25:00, 10.00, 1.34               12/11/2018  08:25  0.010  10 1.170
12-11-2018 08:26:00, 10.00, 1.35               12/11/2018  08:26  0.000  10 1.170
12-11-2018 08:27:00, 10.00, 1.35               12/11/2018  08:27  0.000  10 1.170
12-11-2018 08:28:00, 10.00, 1.36               12/11/2018  08:28  0.000  10 1.180
12-11-2018 08:29:00, 10.00, 1.36               12/11/2018  08:29  0.010  10 1.180
12-11-2018 08:30:00, 10.00, 1.36               12/11/2018  08:30  0.000  10 1.180
12-11-2018 08:31:00, 0.00, 1.36               12/11/2018  08:31  0.000  0 1.180
12-11-2018 08:32:00, 10.00, 1.37               12/11/2018  08:32  0.000  10 1.190
12-11-2018 08:33:00, 10.00, 1.37               12/11/2018  08:33  0.010  10 1.190
12-11-2018 08:34:00, 0.00, 1.37               12/11/2018  08:34  0.000  0 1.190
12-11-2018 08:35:00, 10.00, 1.38               12/11/2018  08:35  0.000  10 1.200
12-11-2018 08:36:00, 10.00, 1.38               12/11/2018  08:36  0.010  10 1.200
12-11-2018 08:37:00, 10.00, 1.39               12/11/2018  08:37  0.000  10 1.210
12-11-2018 08:38:00, 10.00, 1.39               12/11/2018  08:38  0.010  10 1.210
12-11-2018 08:39:00, 10.00, 1.40               12/11/2018  08:39  0.000  10 1.220
12-11-2018 08:40:00, 10.00, 1.40               12/11/2018  08:40  0.010  10 1.220
12-11-2018 08:41:00, 10.00, 1.41               12/11/2018  08:41  0.000  10 1.220
12-11-2018 08:42:00, 10.00, 1.42               12/11/2018  08:42  0.000  10 1.230
12-11-2018 08:43:00, 10.00, 1.42               12/11/2018  08:43  0.010  10 1.230
12-11-2018 08:44:00, 10.00, 1.43               12/11/2018  08:44  0.000  10 1.240
12-11-2018 08:45:00, 10.00, 1.43               12/11/2018  08:45  0.010  10 1.240
12-11-2018 08:46:00, 10.00, 1.44               12/11/2018  08:46  0.000  10 1.250
12-11-2018 08:47:00, 10.00, 1.44               12/11/2018  08:47  0.010  10 1.250
12-11-2018 08:48:00, 10.00, 1.45               12/11/2018  08:48  0.000  10 1.260
12-11-2018 08:49:00, 10.00, 1.55               12/11/2018  08:49  0.010  10 1.380
12-11-2018 08:50:00, 10.00, 1.56               12/11/2018  08:50  0.120  10 1.390
12-11-2018 08:51:00, 10.00, 1.56               12/11/2018  08:51  0.010  10 1.390
12-11-2018 08:52:00, 0.00, 1.56               12/11/2018  08:52  0.000  0 1.390
12-11-2018 08:53:00, 10.00, 1.57               12/11/2018  08:53  0.000  10 1.400
12-11-2018 08:54:00, 10.00, 1.57               12/11/2018  08:54  0.010  10 1.400
12-11-2018 08:55:00, 0.00, 1.57               12/11/2018  08:55  0.000  0 1.400
12-11-2018 08:56:00, 10.00, 1.58               12/11/2018  08:56  0.000  10 1.410
12-11-2018 08:57:00, 10.00, 1.58               12/11/2018  08:57  0.010  10 1.410
12-11-2018 08:58:00, 10.00, 1.59               12/11/2018  08:58  0.000  10 1.420
12-11-2018 08:59:00, 10.00, 1.59               12/11/2018  08:59  0.010  10 1.420
12-11-2018 09:00:00, 10.00, 1.60               12/11/2018  09:00  0.000  10 1.420
12-11-2018 09:01:00, 10.00, 1.61               12/11/2018  09:01  0.000  10 1.430
12-11-2018 09:02:00, 10.00, 1.62               12/11/2018  09:02  0.010  10 1.440
12-11-2018 09:03:00, 10.00, 1.63               12/11/2018  09:03  0.010  10 1.450
12-11-2018 09:04:00, 10.00, 1.63               12/11/2018  09:04  0.010  10 1.450
12-11-2018 09:05:00, 10.00, 1.64               12/11/2018  09:05  0.000  10 1.460
12-11-2018 09:06:00, 10.00, 1.64               12/11/2018  09:06  0.010  10 1.460
12-11-2018 09:07:00, 0.00, 1.64               12/11/2018  09:07  0.000  0 1.460
12-11-2018 09:08:00, 10.00, 1.68               12/11/2018  09:08  0.000  10 1.500
12-11-2018 09:09:00, 10.00, 1.71               12/11/2018  09:09  0.040  10 1.530
12-11-2018 09:10:00, 0.00, 1.72               12/11/2018  09:10  0.030  0 1.540
12-11-2018 09:11:00, 10.00, 1.73               12/11/2018  09:11  0.010  10 1.550
12-11-2018 09:12:00, 10.00, 1.73               12/11/2018  09:12  0.010  10 1.550
12-11-2018 09:13:00, 10.00, 1.74               12/11/2018  09:13  0.000  10 1.560
12-11-2018 09:14:00, 10.00, 1.74               12/11/2018  09:14  0.010  10 1.560
12-11-2018 09:15:00, 10.00, 1.74               12/11/2018  09:15  0.000  10 1.560
12-11-2018 09:16:00, 0.00, 1.74               12/11/2018  09:16  0.000  0 1.560
12-11-2018 09:17:00, 0.00, 1.74               12/11/2018  09:17  0.000  0 1.560
12-11-2018 09:18:00, 0.00, 1.74               12/11/2018  09:18  0.000  0 1.560
12-11-2018 09:19:00, 0.00, 1.74               12/11/2018  09:19  0.000  0 1.560
12-11-2018 09:20:00, 0.00, 1.74               12/11/2018  09:20  0.000  0 1.560
12-11-2018 09:21:00, 10.00, 1.75               12/11/2018  09:21  0.000  10 1.570
12-11-2018 09:22:00, 10.00, 1.75               12/11/2018  09:22  0.010  10 1.570
12-11-2018 09:23:00, 10.00, 1.75               12/11/2018  09:23  0.000  10 1.570
12-11-2018 09:24:00, 0.00, 1.75               12/11/2018  09:24  0.000  0 1.570
12-11-2018 09:25:00, 10.00, 1.76               12/11/2018  09:25  0.000  10 1.580
12-11-2018 09:26:00, 10.00, 1.76               12/11/2018  09:26  0.010  10 1.580
12-11-2018 09:27:00, 10.00, 1.77               12/11/2018  09:27  0.000  10 1.590
12-11-2018 09:28:00, 10.00, 1.77               12/11/2018  09:28  0.010  10 1.590
12-11-2018 09:29:00, 10.00, 1.78               12/11/2018  09:29  0.000  10 1.600
12-11-2018 09:30:00, 10.00, 1.78               12/11/2018  09:30  0.010  10 1.600
12-11-2018 09:31:00, 10.00, 1.79               12/11/2018  09:31  0.000  10 1.610
12-11-2018 09:32:00, 10.00, 1.80               12/11/2018  09:32  0.010  10 1.620
12-11-2018 09:33:00, 10.00, 1.80               12/11/2018  09:33  0.010  10 1.620
12-11-2018 09:34:00, 10.00, 1.81               12/11/2018  09:34  0.000  10 1.630
12-11-2018 09:35:00, 10.00, 1.81               12/11/2018  09:35  0.010  10 1.630
12-11-2018 09:36:00, 10.00, 1.81               12/11/2018  09:36  0.000  10 1.630
12-11-2018 09:37:00, 10.00, 1.82               12/11/2018  09:37  0.000  10 1.640
12-11-2018 09:38:00, 10.00, 1.82               12/11/2018  09:38  0.010  10 1.640
12-11-2018 09:39:00, 0.00, 1.82               12/11/2018  09:39  0.000  0 1.640
12-11-2018 09:40:00, 0.00, 1.82               12/11/2018  09:40  0.000  0 1.640
12-11-2018 09:41:00, 10.00, 1.83               12/11/2018  09:41  0.000  10 1.650
12-11-2018 09:42:00, 10.00, 1.83               12/11/2018  09:42  0.010  10 1.650
12-11-2018 09:43:00, 10.00, 1.84               12/11/2018  09:43  0.000  10 1.660
12-11-2018 09:44:00, 10.00, 1.84               12/11/2018  09:44  0.010  10 1.660
12-11-2018 09:45:00, 0.00, 1.84               12/11/2018  09:45  0.000  10 1.660
12-11-2018 09:46:00, 10.00, 1.85               12/11/2018  09:46  0.000  10 1.670
12-11-2018 09:47:00, 10.00, 1.85               12/11/2018  09:47  0.010  10 1.670
12-11-2018 09:48:00, 0.00, 1.85               12/11/2018  09:48  0.000  0 1.670
12-11-2018 09:49:00, 10.00, 1.86               12/11/2018  09:49  0.000  10 1.680
12-11-2018 09:50:00, 10.00, 1.86               12/11/2018  09:50  0.010  10 1.680
12-11-2018 09:51:00, 10.00, 1.87               12/11/2018  09:51  0.000  10 1.690
12-11-2018 09:52:00, 10.00, 1.87               12/11/2018  09:52  0.010  10 1.690
12-11-2018 09:53:00, 10.00, 1.87               12/11/2018  09:53  0.000  10 1.690
12-11-2018 09:54:00, 10.00, 1.88               12/11/2018  09:54  0.000  10 1.700
12-11-2018 09:55:00, 10.00, 1.88               12/11/2018  09:55  0.010  10 1.700
12-11-2018 09:56:00, 0.00, 1.88               12/11/2018  09:56  0.000  0 1.700
12-11-2018 09:57:00, 0.00, 1.88               12/11/2018  09:57  0.000  0 1.700
12-11-2018 09:58:00, 10.00, 1.89               12/11/2018  09:58  0.000  10 1.710
12-11-2018 09:59:00, 10.00, 1.89               12/11/2018  09:59  0.010  10 1.710
12-11-2018 10:00:00, 10.00, 1.89               12/11/2018  10:00  0.000  10 1.710
12-11-2018 10:01:00, 10.00, 1.90               12/11/2018  10:01  0.000  10 1.720
12-11-2018 10:02:00, 10.00, 1.90               12/11/2018  10:02  0.010  10 1.720
12-11-2018 10:03:00, 10.00, 1.91               12/11/2018  10:03  0.000  10 1.730
12-11-2018 10:04:00, 10.00, 1.91               12/11/2018  10:04  0.010  10 1.730
12-11-2018 10:05:00, 0.00, 1.91               12/11/2018  10:05  0.000  0 1.730
12-11-2018 10:06:00, 0.00, 1.91               12/11/2018  10:06  0.000  0 1.730
12-11-2018 10:07:00, 10.00, 1.92               12/11/2018  10:07  0.000  10 1.740
12-11-2018 10:08:00, 10.00, 1.92               12/11/2018  10:08  0.010  10 1.740
12-11-2018 10:09:00, 10.00, 1.94               12/11/2018  10:09  0.000  10 1.760
12-11-2018 10:10:00, 10.00, 1.94               12/11/2018  10:10  0.020  10 1.760
12-11-2018 10:11:00, 10.00, 1.95               12/11/2018  10:11  0.000  10 1.770
12-11-2018 10:12:00, 10.00, 1.95               12/11/2018  10:12  0.010  10 1.770
12-11-2018 10:13:00, 10.00, 1.96               12/11/2018  10:13  0.000  10 1.780
12-11-2018 10:14:00, 10.00, 1.96               12/11/2018  10:14  0.010  10 1.780
12-11-2018 10:15:00, 10.00, 1.97               12/11/2018  10:15  0.000  10 1.790
12-11-2018 10:16:00, 10.00, 1.97               12/11/2018  10:16  0.010  10 1.790
12-11-2018 10:17:00, 0.00, 1.97               12/11/2018  10:17  0.000  0 1.790
12-11-2018 10:18:00, 10.00, 1.98               12/11/2018  10:18  0.000  10 1.800
12-11-2018 10:19:00, 10.00, 1.98               12/11/2018  10:19  0.010  10 1.800
12-11-2018 10:20:00, 0.00, 1.98               12/11/2018  10:20  0.000  0 1.800
12-11-2018 10:21:00, 10.00, 1.99               12/11/2018  10:21  0.000  10 1.810
12-11-2018 10:22:00, 10.00, 1.99               12/11/2018  10:22  0.010  10 1.810
12-11-2018 10:23:00, 10.00, 2.00               12/11/2018  10:23  0.000  10 1.820
12-11-2018 10:24:00, 10.00, 2.00               12/11/2018  10:24  0.010  10 1.820
12-11-2018 10:25:00, 10.00, 2.02               12/11/2018  10:25  0.000  10 1.840
12-11-2018 10:26:00, 10.00, 2.04               12/11/2018  10:26  0.020  10 1.860
12-11-2018 10:27:00, 10.00, 2.05               12/11/2018  10:27  0.020  10 1.870
12-11-2018 10:28:00, 10.00, 2.05               12/11/2018  10:28  0.010  10 1.870
12-11-2018 10:29:00, 10.00, 2.07               12/11/2018  10:29  0.000  10 1.890
12-11-2018 10:30:00, 10.00, 2.08               12/11/2018  10:30  0.020  10 1.900
12-11-2018 10:31:00, 10.00, 2.09               12/11/2018  10:31  0.010  10 1.910
12-11-2018 10:32:00, 10.00, 2.10               12/11/2018  10:32  0.010  10 1.920
12-11-2018 10:33:00, 10.00, 2.10               12/11/2018  10:33  0.010  10 1.920
12-11-2018 10:34:00, 10.00, 2.11               12/11/2018  10:34  0.000  10 1.930
12-11-2018 10:35:00, 10.00, 2.11               12/11/2018  10:35  0.010  10 1.930
12-11-2018 10:36:00, 0.00, 2.11               12/11/2018  10:36  0.000  0 1.930
12-11-2018 10:37:00, 0.00, 2.11               12/11/2018  10:37  0.000  0 1.930
12-11-2018 10:38:00, 10.00, 2.12               12/11/2018  10:38  0.000  10 1.940
12-11-2018 10:39:00, 10.00, 2.12               12/11/2018  10:39  0.010  10 1.940
12-11-2018 10:40:00, 10.00, 2.12               12/11/2018  10:40  0.000  10 1.940
12-11-2018 10:41:00, 0.00, 2.12               12/11/2018  10:41  0.000  0 1.940
12-11-2018 10:42:00, 10.00, 2.13               12/11/2018  10:42  0.000  10 1.950
12-11-2018 10:43:00, 10.00, 2.13               12/11/2018  10:43  0.010  10 1.950
12-11-2018 10:44:00, 10.00, 2.14               12/11/2018  10:44  0.000  10 1.960
12-11-2018 10:45:00, 10.00, 2.14               12/11/2018  10:45  0.010  10 1.960
12-11-2018 10:46:00, 10.00, 2.15               12/11/2018  10:46  0.000  10 1.970
12-11-2018 10:47:00, 10.00, 2.15               12/11/2018  10:47  0.010  10 1.970
12-11-2018 10:48:00, 10.00, 2.16               12/11/2018  10:48  0.000  10 1.980
12-11-2018 10:49:00, 10.00, 2.17               12/11/2018  10:49  0.010  10 1.990
12-11-2018 10:50:00, 10.00, 2.17               12/11/2018  10:50  0.010  10 1.990
12-11-2018 10:51:00, 10.00, 2.18               12/11/2018  10:51  0.000  10 2.000
12-11-2018 10:52:00, 10.00, 2.19               12/11/2018  10:52  0.010  10 2.010
12-11-2018 10:53:00, 10.00, 2.20               12/11/2018  10:53  0.010  10 2.020
12-11-2018 10:54:00, 10.00, 2.21               12/11/2018  10:54  0.010  10 2.030
12-11-2018 10:55:00, 10.00, 2.22               12/11/2018  10:55  0.010  10 2.040
12-11-2018 10:56:00, 10.00, 2.24               12/11/2018  10:56  0.010  10 2.060
12-11-2018 10:57:00, 10.00, 2.24               12/11/2018  10:57  0.020  10 2.060
12-11-2018 10:58:00, 10.00, 2.25               12/11/2018  10:58  0.000  10 2.070
12-11-2018 10:59:00, 10.00, 2.26               12/11/2018  10:59  0.010  10 2.080
12-11-2018 11:00:00, 10.00, 2.27               12/11/2018  11:00  0.010  10 2.090
12-11-2018 11:01:00, 10.00, 2.28               12/11/2018  11:01  0.010  10 2.090
12-11-2018 11:02:00, 10.00, 2.28               12/11/2018  11:02  0.000  10 2.090
12-11-2018 11:03:00, 10.00, 2.29               12/11/2018  11:03  0.000  10 2.100
12-11-2018 11:04:00, 10.00, 2.29               12/11/2018  11:04  0.010  10 2.100
12-11-2018 11:05:00, 10.00, 2.30               12/11/2018  11:05  0.000  10 2.110
12-11-2018 11:06:00, 10.00, 2.30               12/11/2018  11:06  0.010  10 2.110
12-11-2018 11:07:00, 10.00, 2.31               12/11/2018  11:07  0.000  10 2.120
12-11-2018 11:08:00, 10.00, 2.31               12/11/2018  11:08  0.010  10 2.120
12-11-2018 11:09:00, 10.00, 2.32               12/11/2018  11:09  0.000  10 2.130
12-11-2018 11:10:00, 10.00, 2.32               12/11/2018  11:10  0.010  10 2.130
12-11-2018 11:11:00, 10.00, 2.33               12/11/2018  11:11  0.000  10 2.140
12-11-2018 11:12:00, 10.00, 2.34               12/11/2018  11:12  0.010  10 2.150
12-11-2018 11:13:00, 10.00, 2.34               12/11/2018  11:13  0.010  10 2.150
12-11-2018 11:14:00, 0.00, 2.34               12/11/2018  11:14  0.000  0 2.150
12-11-2018 11:15:00, 10.00, 2.35               12/11/2018  11:15  0.000  10 2.160
12-11-2018 11:16:00, 10.00, 2.35               12/11/2018  11:16  0.010  10 2.160
12-11-2018 11:17:00, 10.00, 2.36               12/11/2018  11:17  0.000  10 2.170
12-11-2018 11:18:00, 10.00, 2.36               12/11/2018  11:18  0.010  10 2.170
12-11-2018 11:19:00, 10.00, 2.37               12/11/2018  11:19  0.000  10 2.180
12-11-2018 11:20:00, 10.00, 2.37               12/11/2018  11:20  0.010  10 2.180
12-11-2018 11:21:00, 0.00, 2.37               12/11/2018  11:21  0.000  0 2.180
12-11-2018 11:22:00, 0.00, 2.37               12/11/2018  11:22  0.000  0 2.180
12-11-2018 11:23:00, 0.00, 2.37               12/11/2018  11:23  0.000  0 2.180
12-11-2018 11:24:00, 0.00, 2.37               12/11/2018  11:24  0.000  0 2.180
12-11-2018 11:25:00, 0.00, 2.37               12/11/2018  11:25  0.000  0 2.180
12-11-2018 11:26:00, 0.00, 2.37               12/11/2018  11:26  0.000  0 2.180
12-11-2018 11:27:00, 0.00, 2.37               12/11/2018  11:27  0.000  0 2.180
12-11-2018 11:28:00, 0.00, 2.37               12/11/2018  11:28  0.000  0 2.180
12-11-2018 11:29:00, 0.00, 2.37               12/11/2018  11:29  0.000  0 2.180
12-11-2018 11:30:00, 0.00, 2.37               12/11/2018  11:30  0.000  0 2.180
12-11-2018 11:31:00, 10.00, 2.38               12/11/2018  11:31  0.000  10 2.190
12-11-2018 11:32:00, 10.00, 2.38               12/11/2018  11:32  0.010  10 2.190
12-11-2018 11:33:00, 0.00, 2.38               12/11/2018  11:33  0.000  0 2.190
12-11-2018 11:34:00, 0.00, 2.38               12/11/2018  11:34  0.000  0 2.190
12-11-2018 11:35:00, 0.00, 2.38               12/11/2018  11:35  0.000  0 2.190
12-11-2018 11:36:00, 0.00, 2.38               12/11/2018  11:36  0.000  0 2.190
12-11-2018 11:37:00, 0.00, 2.38               12/11/2018  11:37  0.000  0 2.190
12-11-2018 11:38:00, 0.00, 2.38               12/11/2018  11:38  0.000  0 2.190
12-11-2018 11:39:00, 0.00, 2.38               12/11/2018  11:39  0.000  0 2.190
12-11-2018 11:40:00, 0.00, 2.38               12/11/2018  11:40  0.000  0 2.190
12-11-2018 11:41:00, 0.00, 2.38               12/11/2018  11:41  0.000  0 2.190
12-11-2018 11:42:00, 0.00, 2.38               12/11/2018  11:42  0.000  0 2.190
12-11-2018 11:43:00, 0.00, 2.38               12/11/2018  11:43  0.000  0 2.190
12-11-2018 11:44:00, 0.00, 2.38               12/11/2018  11:44  0.000  0 2.190
12-11-2018 11:45:00, 0.00, 2.38               12/11/2018  11:45  0.000  0 2.190
12-11-2018 11:46:00, 0.00, 2.38               12/11/2018  11:46  0.000  0 2.190
12-11-2018 11:47:00, 0.00, 2.38               12/11/2018  11:47  0.000  0 2.190
12-11-2018 11:48:00, 10.00, 2.39               12/11/2018  11:48  0.000  10 2.200
12-11-2018 11:49:00, 10.00, 2.39               12/11/2018  11:49  0.010  10 2.200
12-11-2018 11:50:00, 0.00, 2.39               12/11/2018  11:50  0.000  0 2.200
12-11-2018 11:51:00, 0.00, 2.39               12/11/2018  11:51  0.000  0 2.200
12-11-2018 11:52:00, 10.00, 2.40               12/11/2018  11:52  0.000  10 2.210
12-11-2018 11:53:00, 10.00, 2.40               12/11/2018  11:53  0.010  10 2.210
12-11-2018 11:54:00, 0.00, 2.40               12/11/2018  11:54  0.000  0 2.210
12-11-2018 11:55:00, 10.00, 2.41               12/11/2018  11:55  0.000  10 2.220
12-11-2018 11:56:00, 10.00, 2.41               12/11/2018  11:56  0.010  10 2.220
12-11-2018 11:57:00, 0.00, 2.41               12/11/2018  11:57  0.000  0 2.220
12-11-2018 11:58:00, 10.00, 2.42               12/11/2018  11:58  0.000  10 2.230
12-11-2018 11:59:00, 10.00, 2.43               12/11/2018  11:59  0.010  10 2.240
12-11-2018 12:00:00, 10.00, 2.43               12/11/2018  12:00  0.010  10 2.240
12-11-2018 12:01:00, 0.00, 2.43               12/11/2018  12:01  0.000  0 2.240
12-11-2018 12:02:00, 6.00, 2.44               12/11/2018  12:02  0.000  0 2.240
12-11-2018 12:03:00, 10.00, 2.44               12/11/2018  12:03  0.000  10 2.240
12-11-2018 12:04:00, 10.00, 2.44               12/11/2018  12:04  0.000  10 2.240
12-11-2018 12:05:00, 0.00, 2.44               12/11/2018  12:05  0.000  0 2.240
12-11-2018 12:06:00, 0.00, 2.44               12/11/2018  12:06  0.000  0 2.240
12-11-2018 12:07:00, 0.00, 2.44               12/11/2018  12:07  0.000  0 2.240
12-11-2018 12:08:00, 0.00, 2.44               12/11/2018  12:08  0.000  0 2.240
12-11-2018 12:09:00, 0.00, 2.44               12/11/2018  12:09  0.000  0 2.240
12-11-2018 12:10:00, 0.00, 2.44               12/11/2018  12:10  0.000  0 2.240
12-11-2018 12:11:00, 0.00, 2.44               12/11/2018  12:11  0.000  0 2.240
12-11-2018 12:12:00, 0.00, 2.44               12/11/2018  12:12  0.000  0 2.240
12-11-2018 12:13:00, 0.00, 2.44               12/11/2018  12:13  0.000  0 2.240
12-11-2018 12:14:00, 0.00, 2.44               12/11/2018  12:14  0.000  0 2.240
12-11-2018 12:15:00, 0.00, 2.44               12/11/2018  12:15  0.000  0 2.240
12-11-2018 12:16:00, 10.00, 2.45               12/11/2018  12:16  0.000  10 2.250
« Last Edit: November 12, 2018, 02:49:44 PM by Asperitas »
