So not sure what I’m doing wrong.
I did a http:\myipofpurpleairmonitor/json and found the SensorID which looks like Mac code. I entered that into the WD setup. I entered just the IP address into the next field.
I’m only getting an AQI of zero, which I know is not correct.
Am I missing something?
looks like the problem is an extra decimal place is now in use
you will need to use a new .zip update of WD to support that, ready to download now
What Id needs to be used? The mac address version from the sensor ID or the 4-5 digit from purple json.
“SensorId”:“60:1:94:41:1c:ca”,“DateTime”:“2018/08/24T05:15:29z”,“Geo”:“AirMonitor_1cca”,“Mem”
Is part of sensor json
