[size=50]Ive made my own skill that reads the file currentout.txt that WD uploads to my website, its not easy, i needed help but i can supply the code, but you will need to actually create the skill and lambda function, i will do my best to help below. This will not pull specific datas from the file, all it will do is read all the file, so make sure its an understandable file for speech
Here it is in working order https://www.youtube.com/watch?v=G8_2ztdtC-Q
NOTE: READ IT ALL 1st and During this build, never close a tab until you have tested the skill and its working ok, reason is because theres ids thats needed
So, you need to create a lambda function, but 1st, (if you dont have one) create an AWS account here and sign in, [/size]
In the search box, type lambda, and click it
Then click create function
You want Start from scratch (should be highlighted already)
use myWeather as the function name.
Choose Node.js 6.10
Role, Choose, Create custom role, it will open a new page, just click Allow
Then click Create function
From the list on the left, choose Skills set and it will attach itself
Click the box with the name of your skill so that the script box is open below, so scroll down if needed
Now copy and paste the script thats included in this post making sure you edit line 36 and 37
Leave that tab open and open a new one going here, create an account and login or just login if you have one already
Hover over Your Alexa Consoles and choose skills
Click Create Skill
Put in the name you want, i.e. my weather, Boston Weather, bear in mind this will be the name you as Alexa for, ie. Alexa, ask Boston weather…
Make sure Custom is highlighted and click Create Skill at the top right
Make sure Start from scratch is ticked and click Choose
Click invocation name and make sure its what you wanted, ie, Alexa, ask (invocation name)
Click the + next to intents and use GetWeather in the Create Custom Intent box and click Create custom intent
Now this is where you can add all the words that you want or may use to get her to read the txt file, such as, whats the weather status, or current conditions or is it raining or whats the temp or, whats the current conditions, add what ever you may want to use, so, it will be something like this, “Alexa, ask Boston Weather, temp” or "Alexa, ask Boston Weather, whats the current conditions"and she will read that txt file, this isnt about pulling specific datas from the file, just reading the full file, ok, once you added all the utterances you can think of or want, then…
Click Interfaces on the left and choose Display interfaces.
Click Endpoint on the left
Choose AWS Lambda ARN and it will supply you with the arn code, copy that to the clipboard, leave tab open and go back to the other tab you left earlier
Scroll down and post that code in to the Skill ID and then Click Add (bottom right) (SIDE NOTE: you need this ID to go on line 36 on the script)
At the top of that page there is a ARN ID starting arn:aws:lambda…[/size] [/size]copy that and click save
[/size]Go back to the other tab again and paste the new code in to the Default Region box, click the button Save Endpoints
[/size]Then click Invocation name again so that Save Model and Build Model shows at the top, click Save Model, then click Build Model
[/size]At this point you can now goto [/size]Alexa on your PC/mac, click here go to skills, Your skills, DEV SKILLS and you will see it in there and only in there unless you publish it, right, it should have enabled ok, so now go ahead and ask her, test with just the skill name 1st and see if she responds, if yes, then ask one of you utterances, if you are happy and its working ok then you can close the tabs.
exports.handler = (event, context, callback) => {
try {
//console.log(`event.session.application.applicationId=${event.session.application.applicationId}`);
//if (event.session.application.applicationId !== APP_ID) {
// callback('Invalid Application ID');
if (event.session.new) {
onSessionStarted({ requestId: event.request.requestId }, event.session);
if (event.request.type === 'LaunchRequest') {
onLaunch(event.request,
event.session, (sessionAttributes, speechletResponse) => {
callback(null, buildResponse(sessionAttributes, speechletResponse));
} else if (event.request.type === 'IntentRequest') {
onIntent(event.request,
event.session,
} else if (event.request.type === 'SessionEndedRequest') {
onSessionEnded(event.request, event.session);
callback();
} catch (err) {
callback(err);
const isDebug = false;
const APP_ID = 'amzn1.ask.skill.xxxxxxxxxxxxxxxxxxxxxx';
const url_weather = 'http://www.yoursitehere/yourtextfile.txt';
const APP_NAME = 'Weather skill';
const STR_REPROMPT = '\nPlease ask me for the weather';
function getWeather(intent, session, callback, numLetters) {
let speechOutput = '';
let cardTitle = 'Weather output';
getWebRequest(url_weather, function webResonseCallback(err, data) {
if (err) {
speechOutput = `Sorry something went wrong.`;
callback({}, buildSpeechletResponse(cardTitle, speechOutput, STR_REPROMPT));
} else {
//if (isDebug) {"SolveAnagram::data = " + console.log(data)};
speechOutput = data;
//Simple welcome intent handler
function getWelcomeResponse(callback) {
console.log("START session");
if (isDebug) {console.log("getWelcomeResponse()")}
const cardTitle = APP_NAME;
const speechOutput = 'Welcome to '+APP_NAME+'. '+ STR_REPROMPT;
// If the user either does not reply to the welcome message or says something that is not
// understood, they will be prompted again with this text.
const repromptText = STR_REPROMPT;
const shouldEndSession = false;
callback({}, buildSpeechletResponse(cardTitle, speechOutput, repromptText, shouldEndSession));
//Simple end session intent handler
function handleSessionEndRequest(callback) {
console.log("END session");
const cardTitle = 'Goodbye';
const speechOutput = 'Thanks for playing with '+APP_NAME+'.';
const shouldEndSession = true;
callback({}, buildSpeechletResponse(cardTitle, speechOutput, null, shouldEndSession));
function buildSpeechletResponse(title, output, repromptText, shouldEndSession) {
if (isDebug) {console.log(`buildSpeechletResponse(title:${title}, shouldEndSession:${shouldEndSession}, reprompt:${repromptText})`)}
return {
outputSpeech: {
type: 'PlainText',
text: output,
card: {
type: 'Simple',
title: `${title}`,
content: `${output}`,
reprompt: {
outputSpeech: {
type: 'PlainText',
text: repromptText,
shouldEndSession,
function buildResponse(sessionAttributes, speechletResponse) {
return {
version: '2.0',
response: speechletResponse,
sessionAttributes: sessionAttributes,
//----------------- Web service helper ----------------------//
var http = require('http');
function getWebRequest(url,doWebRequestCallBack) {
try
http.get(url, function (res) {
var webResponseString = '';
if (isDebug) {console.log('Status Code: ' + res.statusCode)};
if (res.statusCode != 200) {
doWebRequestCallBack(new Error("Non 200 Response"));
return;
res.on('data', function (data) {
webResponseString += data;
res.on('end', function () {
//if (isDebug) {console.log('getWebRequest::Got some data: '+ webResponseString)};
//the weather isn't JSON so just return the string
//var webResponseObject = JSON.parse(webResponseString);
doWebRequestCallBack(null, webResponseString);
}).on('error', function (e) {
if (isDebug) {console.log("Communications error: " + e.message)};
doWebRequestCallBack(new Error(e.message));
catch(err)
doWebRequestCallBack(new Error(err.message));
// --------------- Events -----------------------
* Called when the session starts.
function onSessionStarted(sessionStartedRequest, session) {
//console.log(`onSessionStarted requestId=${sessionStartedRequest.requestId}, sessionId=${session.sessionId}`);
* Called when the user launches the skill without specifying what they want.
function onLaunch(launchRequest, session, callback) {
//console.log(`onLaunch requestId=${launchRequest.requestId}, sessionId=${session.sessionId}`);
// Dispatch to your skill's launch.
getWelcomeResponse(callback);
* Called when the user specifies an intent for this skill.
function onIntent(intentRequest, session, callback) {
const intent = intentRequest.intent;
const intentName = intentRequest.intent.name;
console.log(" ");
console.log("== New Intent ==");
console.log(`onIntent(${intentName})`);
if (intentName === 'GetWeather') {
getWeather(intent, session, callback,1);
* Called when the user ends the session.
* Is not called when the skill returns shouldEndSession=true.
function onSessionEnded(sessionEndedRequest, session) {
//console.log(`onSessionEnded requestId=${sessionEndedRequest.requestId}, sessionId=${session.sessionId}`);
// Add cleanup logic here
