when I open control panel and click on cwop it freezes up and wont respond to the mouse but continues to collect data and upload.
most likely the CWOP setup screen is trying to open off screen
you can reset the settings for that window
what version/build of WD?
The most recent build 80, downloaded and reinstalled. I can access anything but cwop. I have tried dragging the program all over and opening it, no matter what it freezes up, WD just goes ding, windows error ding and won’t let you click on anything in wd until you force it closed with task manager.
as I have mentioned, it will likely be opening off screen
and you will need to reset the settings to fix that (a search of the forum would find a solution)
in the wdisplay.ini settings file
when WD is not running
find
[Main cwop setup]
last cwop setup left=
last cwop setup top=
delete those settings (and let me know what they were)
[Main cwop setup]
last cwop setup width=1405
last cwop setup height=1018
last cwop setup top=1468
last cwop setup left=30
I deleted all the numbers then when reopened wd, I tried opening cwop it popped up in the upper left corner slightly off screen I had to drag the edges way out so I could see the fields. Hopefully cwop is now working FW3692
