[quote author=Ex-Whr link=topic=66940.msg544516#msg544516 date=1552954164]
exactly 7 days low but correct day
I see what the problem is, hopefully
WD is using the current time/date instead of the time/date from the history data, when doing/checking the last 7 days data reset (i.e what day to reset etc)
try this new update
Have updated with your file as per email …
date and day are currently correct for 16 through 20 and first two are 7/8 th for last Thusday / Friday…
will see what happens IF we get another power fail …
cheers
Brian
Brian
attached are screen shots of 7 day rain screen for yesterday and today … Note the discrepancy of date / dates…
from Saturday 30th on march screen … ALL ates / days correct … to this mornings screen where saturday is correct but sunday is now 24th [ 1 week early out of date ] and Thursday is now 1 April instead of Sunday being 31st of March …??
… and NO this is not an april fools joke… …unless the program knows about these things …
Brian
There is still a problem with rainfall data recording as can bee seen on screen capture attached …
Rain is incorrectly recorded on 19th as 4.6 on 7 day screen and correctly recorded on detailed rain chart screen on 20th…
Rainfall is recorded at 0900 hrs on that day for previous 24 hr period [ by BoM Aust. and I assume NZ whr as well ]
I am using WD ver 96 as can bee seen at top of screen dump.
I assume other Australian users are having same problem as well
Forgot to add that in previous post screen dump
Yes I do and I am in Aus as well. I suspect that is relevant as people in other countries do not seem to have the issue.
See my posts in http://discourse.weather-watch.com/t/66516
Ian
I have been using ver 96
I was unaware of a rain days problem so I don’t know.
Ian
I had done testing for midnight reset and that works OK now
but I had not tested for aus 9am reset
i will do some testing of that
At last … first rain for month and good rain [ more to come ] -helped put out 3 bush fires in southern WA…
attached screen shot from this morning and one date /day error appears to be fixed (?) in an update , tho double first is still showing…
Also note that rainfall total of 25.2 on 6/6 [Thursday] should be recorded as being on 7/6 Friday with BoM reset at 0900
I think you need to check the rain values in the 62019lg.txt around the end of the day and correct if needed for those days then convert logfile to graph
the daily values in the detailed rain (your second image) are stored in the datafile
i have now fixed a bug with the Aus 9am rain reset option for the change in month rain
in build 99
so make sure to update to that before the end of the month 8O
Brian
Have updated to 99 … will advise
cheers
