Brian
Still got this date problem with rainfall as per attachment, and this yesterday’s rainfall does not appear on main display though it appears on detailed rain list
when right clicked on rainfall window
can you post what it looks like after the next midnight reset?
thanks
Brian
As requested shot taken at 15:30 7/12
cheers
that incorrect date is moving down the each day
so after a few more days, all going well, it will all come correct
Brian
This has been going on for months and has never been correct
The rain chart (last 7 days) is not tracking past 1 decimal place…this is from my station running S81…
not sure what you mean exactly, sorry
The main point I was trying to make is that rain of less than 0.1" will show as 0.0" on the 7 day since only one decimal point is shown…although mine did round up the 0.9" to 0.1"…
ah, got ya
in fact when inches are used, it should change to say .in and not mm
and yes show more decimal places
use the latest .zip update (build 85)
I am surprised no one had noticed that before 8O 8O 8O
Does that work for mm too?
No more decimal places were added for mm
Although I could do that for day if a weather flow station is in use
the latest .zip update of WD should fix the last 7 days rain for when aus 9am reset in use
Brian
possible cause to problem could be as follows… for some reason if data from Davis VP is not downloaded to computer / WD pgm, next time it is downloaded the dates on 7 day rainfall screen are corrupted.
Have Updated to WD 90
No change to previous post
John Y
It’s not very clear to me what part
Of the previous post is still a problem
Note you can set the needed year rain total
Under control panel, offsets and initial rain
Rain for Jan was displayed as it should on main screen when it fell and totals were correct
