@bduren: Check here for a possible solution to your problem.
Thank you.
At end of September I was already running version 37S81 and this test.zip is not in there maybe.
I will try and the result will come in November.
I can add that I corrected the amout in “Rain To Date” yesterday and after i updated NOAA reports it was OK.
Until today.
Same August amount in September NOAA but still correct amount in “Rain To Date”
Brian
Do not know what is happening with this program, but problems appear to be getting worse
I have just checked mine and the lat 7 days rain totals are correct
is there any error under view, program event log?
Brian
No error messages at all
are you using the latest version update?
Brian
Was using the “current” software as per web site … [ build 81] now have replaced WD .exe with your link download and top of screen now tells me it is Ver: 10.37S82
Attached is 7 day rain screen after “update” and date/ days are still not correct … [ no error log info]
cheers
Using the 10/30 V82 WD, yesterday my Davis reported 1.40" of rain.
This morning, WD shows 0.00" of rain yesterday, however storm rain and month rain is correct at 1.40".
How do i fix rain yesterday?
I have not seen a problem with yesterday rain myself
but you can set the needed yesterday rain total under control panel, offsets and initial rain
Thanks, Brian. That straightened it out.
Brian
Brian
Still got this date problem with rainfall as per attachment, and this yesterday’s rainfall does not appear on main display though it appears on detailed rain list
when right clicked on rainfall window
can you post what it looks like after the next midnight reset?
thanks
Brian
As requested shot taken at 15:30 7/12
cheers
that incorrect date is moving down the each day
so after a few more days, all going well, it will all come correct
Brian
This has been going on for months and has never been correct
The rain chart (last 7 days) is not tracking past 1 decimal place…this is from my station running S81…
not sure what you mean exactly, sorry
The main point I was trying to make is that rain of less than 0.1" will show as 0.0" on the 7 day since only one decimal point is shown…although mine did round up the 0.9" to 0.1"…
