Author Topic: rain to date display error  (Read 2439 times)
  • Davis VP2
  • New Zealand
  • Win NT 10.0
  • Chrome 70.0.3538.110
    • Weather Display
Re: rain to date display error
« Reply #30 on: December 10, 2018, 06:18:28 PM »
I am surprised no one had noticed that before  8O 8O 8O
Offline bitsostring
  • Oregon Scientific WMR200
  • Edinburgh, UK
  • Win NT 10.0
  • Chrome 64.0.3282.140
    • Home Weather Station
« Reply #31 on: December 10, 2018, 07:47:49 PM »
and yes show more decimal places
use the latest .zip update (build 85)
Does that work for mm too?
It's meant to be fun. . .
  • Davis VP2
  • New Zealand
  • Android 7.1.1
    • Weather Display
« Reply #32 on: December 10, 2018, 08:24:50 PM »
No more decimal places were added for mm
Although I could do that for day if a weather flow station is in use
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #33 on: December 19, 2018, 03:26:41 AM »
the latest .zip update of WD should fix the last 7 days rain for when aus 9am reset in use
Offline Ex-Whr
  • Perth WA
  • Win NT 10.0
« Reply #34 on: February 07, 2019, 04:47:33 AM »
Brian
   possible cause to problem could be as follows.....   for some reason if data from Davis VP is not downloaded to computer / WD pgm, next time it is downloaded the dates on 7 day rainfall screen are corrupted.
I have noticed this a couple of times over past month when I have not accessed WD for several days, and when I do, IF for some reason the data has not been automatically downloaded as it should and WD then downloads stored data, this then appears to corrupt the 7 day dates...
   IF data is up to date when WD is opened, dates are in correct sequence.....
   Problem with Davis or WD accessing data ???    [ WD run on dedicated NIC computer with no other pgm running (win 10 current version ) with 4gb memory  ]
Offline Ex-Whr
  • Perth WA
  • Win NT 10.0
« Reply #35 on: February 08, 2019, 08:13:38 AM »
Brian
  The monthly / yearly rainfall totals are not showing on screen and rain chart totals as can be seen on chart rain on 2nd and  23/24/25 Jan but 0.0 total on summary but number of days correct [4] and wettest [6,6] however total for month 0.0 ??
also on main screen display [rain B] 0.0 for year and on 7 day rain screen " Storm rain total" 8.4 mm..???
WD version current 85
Offline Ex-Whr
  • Perth WA
  • Win NT 10.0
« Reply #36 on: February 08, 2019, 08:31:05 AM »
Have Updated to WD 90
    No change to previous post
John Y
  • Davis VP2
  • New Zealand
  • Android 7.1.1
  • Chrome 71.0.3578.99
    • Weather Display
« Reply #37 on: February 08, 2019, 07:59:21 PM »
It's not very clear to me what part
Of the previous post is still  a problem
Note you can set the needed year rain total
Under control panel, offsets and initial rain
Offline Ex-Whr
  • Perth WA
  • Win NT 10.0
« Reply #38 on: February 09, 2019, 02:01:49 AM »
Rain for Jan was displayed as it should on main screen when it fell and totals were correct
however it appears that it has not updated when Feb commenced and it should be displayed in yearly total
Also on 7day rain screen .. NO yearly total  but a "Storm" Value of total for month ..???
and on Yearly rainfall chart .. daily values are there   but NOT Total for month ??
Offline Ex-Whr
  • Perth WA
  • Win NT 10.0
« Reply #39 on: March 18, 2019, 02:15:03 AM »
Brian
    7 Day rainfall window problem looks like a problem if computer that runs WD has a power failure, and then turned on some time later .
Had a general power outage at 3 am  6 days ago and computer that runs WD did not restart when power came back on....
.was restarted after noticing not operating  [ 2 days later ], and WD restarted automatically and downloaded missing data from consol.
noticed that 7 day window dates were not correct . checked this morning to see what happens and attached image shows 11/12 and 16/17 th day and date correct but other [ 6/7/8th ]
dates are incorrect but days are correct .. dates are exactly one week earlier ..??
hope this makes sense
cheers
Offline Ex-Whr
  • Perth WA
  • Win NT 10.0
« Reply #40 on: March 19, 2019, 12:09:24 AM »
Brian
   it has happened again .. another power failure this morning and when WD computer turned on and data loaded, display of 7 day screen date has reverted to 11/3 instead of 18/3 exactly 7 days low but correct day ????
  • Davis VP2
  • New Zealand
  • Win NT 10.0
  • Chrome 72.0.3626.121
    • Weather Display
« Reply #41 on: March 19, 2019, 03:07:33 AM »
do you mean this is happening with when WD is getting the history data from the data logger?
(what weather station type again?)
Offline Ex-Whr
  • Perth WA
  • Win NT 10.0
« Reply #42 on: March 19, 2019, 03:29:39 AM »
Brian
   Could be the Davis logger is still logging the data while the computer is off line..  [ is connected to mains with bat. back up ]
When I have restarted the computer, the WD program starts automatically and downloads the "missing" data..
prior to the power failures [ general in area ], dates / days were displayed correctly.
cheers
Offline bitsostring
  • Edinburgh, UK
  • Win NT 10.0
« Reply #43 on: March 20, 2019, 11:57:31 PM »
As per #1 in this thread, if WD is not running at rain reset time the 7-day screen will not be updated.
AFAIK that doesn't affect logged data: the 7-day data is kept in WDISPLAY.INI
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #44 on: March 21, 2019, 12:53:06 AM »
I see what the problem is, hopefully
WD is using the current time/date instead of the time/date from the history data, when doing/checking the last 7 days data reset (i.e what day to reset etc)
try this new update
