Email/smtp question
I am trying to setup email alerts and i have an error establishing the handshake protocol. This is according to the FTP log. It connects, then enters the secure channel handshake, fails to find a common protocol and fails out. My smtp server no longer supports SSL, it only uses TLS. Does the app support TLS or is it SSL only?
it supports both
you might need to change the port number though
Got it! The problem was the SSL tick box. The problem was that tick box takes out TLS and uses SSL only. gmail is now TLS only, so the box needs to be unticked to work.
