Trial version not showing readings
I have Ver 10.37 linux build 296 Trial version, and when I wanted to get data from last year, I shut down WD , reloded it and waited. It only went so far and then just stopped. I tried again but this nothing was been grabbed from my Davies Vanatge Vue.
Also the only data or reading showing on or in WD are the current temperature, max wind gust and maximum temperature.
If I buy the program will that make any difference.
The Davis data logger only keeps a limited amount of data. If set to a one minute archive interval it saves about 42 hours of data, multiply 42 hours by the archive interval to determine how much data your logger will hold.
Ok thanks, I didn’t realise that. The other readings have now been updated, and I’ve set the rainfall totals etc
so you got the linux version to run?
Yes, I did after I installed my new Asus Radeon R7 240 graphics card and the amd drivers.
It’s just like starting again now with WD
