Not really a wd issue so that’s why im posting here. So using a script and using wd, the readings compared to the purple air map are very low comparing to another sensor close by. Ive tried many settings but wd and another script keep reading low. SS attached.
Has it been running long enough to have 24 hours of good data?
Yeah, its been over 24 hours.
Looks like your map AQI is comparable to nearby stations.
If you look at the PM2,5 numbers on the map, rather than the calculated AQI, they are in the same ballpark as the script number.
Yeah, compared too nearby stations it looks good. But wd and the sensor script are way under and that’s what i want to post on my page but its too far off for some reason.
I think it’s just a different number, not a wrong number.
The Purpleair map shows realtime values for PM2.5 for your location here When I write this: AQHI is 70 for PM2.5 count of 21
