with build 77
if you have not customised the WD screen
then this version, the WD screen will auto resize as you make the WD window screen larger (i.e by dragging on the bottom right hand corner with the mouse)
or if you use set to maximise size, it will fill the whole screen, instead of seeing a big area of black
Awesome…I’m having to run my server at 1280x1024 because the screen doesn’t fit on a smaller resolution and my IPKVM doesnt support 1280x1024. I cant wait to try this out. Thanks for the update Brian
