Author Topic: WXSIM 218 Build 1.1  (Read 1862 times)
Offline Tom Ehrensperger
  • Firefox 61.0
WXSIM 218 Build 1.1
« on: August 05, 2018, 01:29:48 AM »
Hi Everybody,
I think I've got all the bog fix/suggestion stuff addressed in this new version.  I haven't announced it on the web site (which should now be all fixed, clean and more secure now!!), but want to put it out there to try, and this one IS wrapped in an installer.  Let me know how it goes!
www.wxsim.com/wxsimupg.exe
Here's what changed since the last installer (Build 1.0):
(1) An item that was new in Build 1.0 (below), but which I forgot to list, is the “Adjust” button next to Auto Haze under Refinements on the Data Entry form.  When you click this, a form appears which allows you to specify an offset for the amount of haze generated by the Auto Haze routine.  The primary motivation for this is the addition of solar panel power output forecasting (described below), as this can be quite sensitive to the amount of haze.
(2) Changes were made in the solar panel algorithms to allow a new parameter related to the response of the panels to diffuse (scattered) versus direct sunlight.  Originally, this was included as a constant, but experience with a second customer, with a different brand or type of panel showed that this can vary.  Unless the new value is specified, the program defaults to the original constant.
(3) Another parameter was added to the solar panel algorithm: maximum inverter power.  My second customer has an inverter which occasionally maxes out at a certain wattage, so I added this as an optional variable.  If not specified, the inverter maximum power is assumed to be unlimited.
(4) A bug in Build 1.0 had caused the new wet bulb global temperature to be left blank in the first line of latest.csv.  This has been corrected.
(5) In wret.exe, a message in Build 1.0 had pointed out the lack of Fire Weather Index in older forecast files.  However, this turned out to stop execution during analysis runs (including with autoleearn.exe), so it has been removed.  The default fire index for older forecast files is now set to zero, as it cannot be properly calculated from the data they contain.
(6) In wret.exe, the number of checked items in each section (‘Temperatures and Thickness’ and ‘Other Data’) has been increased from 15 to 20.  The blue-text help items for these also now reflect these changes.
Offline hrvistaweather
  • Tasmania
  • Win NT 6.3
  • Chrome 67.0.3396.99
Re: WXSIM 218 Build 1.1
« Reply #1 on: August 05, 2018, 02:51:55 AM »
Hi Tom,
Sorry to hear about the Website Hack (not good) there are some real low life people in this world.
Thank you for the update : I have installed and tested on my Test PC and all fine.
However I will not be installing on my production PC as I have not yet scripted around the extra fields and (2) extra blank lines in "latest.csv" (else my scripts and MySql DB will crash).
As I mentioned here :  https://www.weather-watch.com/smf/index.php/topic,66840.msg537375.html#msg537375 Is there any way to remove the extra blank rows.
Also Wim will need to adjust his scripts if the extra rows remain :  https://www.weather-watch.com/smf/index.php/topic,66840.msg537413.html#msg537413
Kind regards,
« Last Edit: August 05, 2018, 02:53:56 AM by hrvistaweather »
Tony
Offline SteveFitz1
  • Win 7/Srvr 2008R2
  • Firefox 61.0
    • Tyler Texas Weather
« Reply #2 on: August 05, 2018, 03:37:50 AM »
Tom,
I got the latest upgrade installed. I haven't had a chance to run it yet, but I noticed that on the WRET screen, the 2 occurrences of the "maximum of 15 items" areas did not change to "20". They both still show as "15".
Steve
Online wvdkuil
  • Wim van der Kuil
  • Leuven Belgium CET
  • Mac OS X 10.13.6
« Reply #3 on: August 05, 2018, 06:53:03 AM »
@Tom Ehrensperger
There are two blank lines introduced in the latest.csv. See the discussions in your thread
example of the blank lines at: https://www.weather-watch.com/smf/index.php/topic,66840.msg537375.html#msg537375
These blank lines will break the scripts which use latest.csv as the scripts expects the field-names in the first row and the corresponding unit of measurement in the second row.
I advised my users who's script failed, to either use the official 2018 release from your website (which is OK)  or use lastret.txt when using this test-version or the previous test-version.
My scripts can process either file, but the users will loose functionality when they switch from latest.csv to lastret.txt as lastret.txt contains less fields to process.
In the past 6 years there are multiple different script-versions processing latest.csv, no way anyone can find or warn the users with all their different native languages.  So when they update WXSIM the latest.csv should be usable by them also.
« Last Edit: August 05, 2018, 06:54:36 AM by wvdkuil »
Offline Forever
  • Santa Cruz, CA
  • Win 7/Srvr 2008R2
  • Mozilla compatible
    • WeatherCat
« Reply #4 on: August 05, 2018, 02:40:19 PM »
I can confirm my scripts did not work after updating. I want back to the older version and they are working again.
Offline Breezy
  • Indian Trail Weather
  • Hessville, NY, U.S.A.
    • baldwinj1
  • Win 7/Srvr 2008R2
  • Firefox 61.0
« Reply #5 on: August 05, 2018, 07:24:19 PM »
Tom,
I also agree with Steve's comment, that
Quote
Will you please update this to "20" in the WRET screen?
Thanks much.  :D
Jeff
W7-64, Intel Z170A 16 GB RAM
Davis VP2 Plus & Soil Moisture/Temp Sensors, Laser Snow Sensor LR4/Fluke 414D, 4 Webcams
  • Firefox 61.0
« Reply #6 on: August 06, 2018, 01:00:36 AM »
Working on fixes.  Should have a new version up shortly.  Thanks! :)
  • Firefox 61.0
« Reply #7 on: August 06, 2018, 01:27:32 AM »
OK, I think I've got the blank lines in latest.csv problem fixed.  I also made one other change, asked for by exactly one user - ever: the printout options (none, short form, long form, and graph and summaries) is now saved on exit, hopefully without breaking anything else! :)
Let me know how this goes!  If it checks out OK, I think one will be "official"!
Thanks!
Tom
  • Tasmania
  • Win NT 6.3
« Reply #8 on: August 06, 2018, 04:10:29 AM »
Hi Tom,
Thank you greatly appreciated.
Installed new Upgrade and did a run on my test PC, all ran perfect and I confirm the blank lines in latest.csv problem fixed, now displays as original (just the (2) Header Lines and blanks gone.
Update : Completed my script mods and mysql changes, now running new version on main production PC, all good.
Kind regards,
« Last Edit: August 06, 2018, 07:30:36 AM by hrvistaweather »
Tony
Offline giantocr
    • Weatherstation - MeteoSauwerd
« Reply #9 on: August 06, 2018, 06:42:54 AM »
Hi Tom,
Installed new Upgrade and did a run, all ran perfect and I confirm the blank lines in latest.csv problem fixed now.
Kind regards,
Piet
https://www.meteosauwerd.nl
Offline SteveFitz1
  • Win 7/Srvr 2008R2
  • Firefox 61.0
« Reply #10 on: August 06, 2018, 11:41:09 AM »
Tom,
Got the latest revision installed and everything ran correctly. Checked latest.csv and the extra lines are gone. Also, the "15 maximum checkboxes" has been changed to "20" in both places in WRET.
Thanks for your work.
Steve
Offline Breezy
    • baldwinj1
  • Win 7/Srvr 2008R2
  • Firefox 61.0
« Reply #11 on: August 06, 2018, 09:52:48 PM »
Tom,
Looking good! Thank you.  \:D/
Jeff
  • Firefox 61.0
« Reply #12 on: August 07, 2018, 01:30:37 AM »
Thanks for the feedback!  You can consider this release "official"! :)
Also, thanks for hanging around on the forum while I was quiet for a while.  I had a bunch going on, most of it good, as we had our daughter and two granddaughters (and our son-in-law part of the time) visiting from California for over a month this summer, and then wanted to get out of town ourselves!
Anyway, I'm glad to have a new version out, and kind of excited about the new features.  Thanks, as always, for your support!
Tom
Offline Stegrie
  • Germany
  • Firefox 61.0
    • Wetterstation Johanngeorgenstadt
« Reply #13 on: August 07, 2018, 04:25:52 AM »
Have updatet yesterday.
Looks good and run fine  :D
Stefan
Weather Station - Johanngeorgenstadt
Davis Vantage Pro 2 Plus - WXSIM,Blitzortung ,WD, 2 Soil Temp/Moist + Solar/Rad.
System: Windows 7
  • Firefox 61.0
« Reply #14 on: August 13, 2018, 01:56:38 AM »
Well, still made a couple of very small changes - just to the format of the latestsolardaily.csv file (if you're customized for solar panels).  This won't affect anyone else.  Also, I added a description of the solar panel algorithm and output on pages 76-79 in manual.doc.  This might be interesting reading, especially if you do have (or are thinking of getting) solar panels.
The installer for the new version (for upgrade) is, as usual, at
I do have a question: is anyone writing (or interested in writing) PHP (or other) scripts for the solar panel output?  If so, I'll of course be glad to share samples and discussion of format, etc.
Thanks, and let me know how it goes!  I'll probably update the web page itself sometime this week.
Tom
