Midnight Wind Spike
Has this problem been solved? And I happen to do the same :roll:
make sure you are using the latest update
I have not had a spike since I installed the Aug 2nd zip file…
I tried to update to the latest build for the wind spike issue but i have a custom main screen and its all messed up, even using a backup ini it was still messed up
the latest update of WD has auto resize of the screen
but if you have customised the main screen then it should not try and do that
wait, I think its still trying to do that
so try a new .zip update, ready now
Thank you Brian, that sorted it :slight_smile:
Been awhile but it happened today…
Still see the spike in build 81. I doubt your actively working it but wanted to keep you updated just in case…
try another .zip update, ready now…
I am still on b78 when you 1st resolved this for me and its still ok for me, not seen a spike since then
Installed and monitoring…will let you know…thanks.
i have slept on it…done another update
what is happening is if the max gust during the day is higher than at night, then the time that occured is getting set wrong for the graph data
i.e its getting pegged as at midnight
I think I have a better handle on it now
latest .zip update
Ok, up and running latest and greatest…hopefully this takes care of it once and for all. Thanks for your great support Brian, always appreciated.
This update is looking good for me, as before I would see it 3-in-4 times and since update none.
Thanks for fixing this.
Installed b81 yesterday, gust spike at around 1am and wind gust not resetting at midnight
i have not seen others report this problem
one thing, make sure the time is the same on the console as the pc
The time was still set to winter, it was an hour behind :roll: thanks, that would explain the wind spike being at 1am and not 12pm too.
Looks like I captured another midnight wind spike - see attached.
The max gust for the spike was reported at 00:36, which may be a clue. Let me know if there is anything I can check.
Here is an extract of my log file at this period:
7 10 2018 23 55 05.6 87 03.6 1021.9 1.2 1.7 233 0.0 0.0 4.2 454.4 5.6 7 10 2018 23 56 05.6 88 03.7 1021.9 0.8 1.7 233 0.0 0.0 4.2 454.4 5.6 7 10 2018 23 57 05.6 88 03.7 1021.9 0.4 1.7 233 0.0 0.0 4.2 454.4 5.6 7 10 2018 23 58 05.5 88 03.7 1021.9 0.9 0.9 233 0.0 0.0 4.2 454.4 5.5 7 10 2018 23 59 05.5 88 03.7 1021.9 0.6 1.7 230 0.0 0.0 4.2 454.4 5.5 8 10 2018 0 0 05.5 88 03.7 1021.9 0.8 1.7 231 0.0 0.0 4.2 454.4 5.5 8 10 2018 0 1 05.5 88 03.7 1021.9 0.9 1.7 231 0.0 0.0 4.2 454.4 5.5 8 10 2018 0 2 05.5 88 03.7 1021.9 1.7 18.3 221 0.0 0.0 4.2 454.4 5.5 8 10 2018 0 3 05.5 88 03.7 1021.9 3.4 1.7 221 0.0 0.0 4.2 454.4 5.5 8 10 2018 0 4 05.5 88 03.6 1021.9 0.8 2.6 227 0.0 0.0 4.2 454.4 5.5 8 10 2018 0 5 05.4 88 03.6 1021.9 1.4 2.6 238 0.0 0.0 4.2 454.4 5.4 8 10 2018 0 6 05.4 88 03.6 1021.9 1.7 2.6 245 0.0 0.0 4.2 454.4 5.4 8 10 2018 0 7 05.4 88 03.6 1021.9 1.8 2.6 246 0.0 0.0 4.2 454.4 5.4 8 10 2018 0 8 05.4 88 03.6 1021.9 1.3 1.7 253 0.0 0.0 4.2 454.4 5.4 8 10 2018 0 9 05.4 88 03.6 1021.9 1.5 2.6 254 0.0 0.0 4.2 454.4 5.4 8 10 2018 0 10 05.4 88 03.6 1021.9 1.5 2.6 254 0.0 0.0 4.2 454.4 5.4 8 10 2018 0 11 05.4 88 03.6 1021.9 1.4 1.7 254 0.0 0.0 4.2 454.4 5.4 8 10 2018 0 12 05.4 88 03.6 1021.9 1.2 1.7 254 0.0 0.0 4.2 454.4 5.4 8 10 2018 0 13 05.4 88 03.6 1021.9 0.7 0.9 254 0.0 0.0 4.2 454.4 5.4 8 10 2018 0 14 05.4 88 03.6 1021.9 0.3 0.9 254 0.0 0.0 4.2 454.4 5.4 8 10 2018 0 15 05.4 89 03.8 1021.8 0.1 0.0 254 0.0 0.0 4.2 454.4 5.4 8 10 2018 0 16 05.5 89 03.8 1021.8 0.0 0.0 254 0.0 0.0 4.2 454.4 5.5 8 10 2018 0 17 05.5 89 03.8 1021.8 0.0 0.0 254 0.0 0.0 4.2 454.4 5.5 8 10 2018 0 18 05.5 89 03.8 1021.8 0.0 0.0 254 0.0 0.0 4.2 454.4 5.5 8 10 2018 0 19 05.5 89 03.8 1021.8 0.0 0.0 254 0.0 0.0 4.2 454.4 5.5 8 10 2018 0 20 05.5 89 03.8 1021.8 0.0 0.0 254 0.0 0.0 4.2 454.4 5.5 8 10 2018 0 21 05.5 89 03.8 1021.8 0.0 0.0 254 0.0 0.0 4.2 454.4 5.5 8 10 2018 0 22 05.5 89 03.8 1021.8 0.0 0.0 254 0.0 0.0 4.2 454.4 5.5 8 10 2018 0 23 05.5 89 03.8 1021.8 0.0 0.9 254 0.0 0.0 4.2 454.4 5.5 8 10 2018 0 24 05.6 89 03.9 1021.8 0.4 0.9 254 0.0 0.0 4.2 454.4 5.6 8 10 2018 0 25 05.5 89 03.9 1021.8 0.8 1.7 254 0.0 0.0 4.2 454.4 5.5 8 10 2018 0 26 05.5 89 03.8 1021.8 1.2 1.7 254 0.0 0.0 4.2 454.4 5.5 8 10 2018 0 27 05.5 89 03.9 1021.8 1.2 1.7 254 0.0 0.0 4.2 454.4 5.5 8 10 2018 0 28 05.5 89 03.8 1021.8 0.8 0.9 254 0.0 0.0 4.2 454.4 5.5 8 10 2018 0 29 05.5 89 03.8 1021.8 0.5 0.9 254 0.0 0.0 4.2 454.4 5.5 8 10 2018 0 30 05.5 89 03.8 1021.8 0.4 0.9 254 0.0 0.0 4.2 454.4 5.5 8 10 2018 0 31 05.5 89 03.8 1021.8 0.3 0.9 254 0.0 0.0 4.2 454.4 5.5 8 10 2018 0 32 05.5 89 03.8 1021.8 0.4 0.9 254 0.0 0.0 4.2 454.4 5.5 8 10 2018 0 33 05.5 89 03.8 1021.8 0.6 1.7 254 0.0 0.0 4.2 454.4 5.5 8 10 2018 0 34 05.5 89 03.8 1021.8 1.0 1.7 254 0.0 0.0 4.2 454.4 5.5 8 10 2018 0 35 05.5 89 03.8 1021.8 1.1 1.7 254 0.0 0.0 4.2 454.4 5.5 8 10 2018 0 36 05.5 89 03.8 1021.8 1.0 1.7 254 0.0 0.0 4.2 454.4 5.5 8 10 2018 0 37 05.5 89 03.8 1021.8 0.8 1.7 254 0.0 0.0 4.2 454.4 5.5 8 10 2018 0 38 05.5 89 03.8 1021.8 0.7 0.9 254 0.0 0.0 4.2 454.4 5.5 8 10 2018 0 39 05.4 89 03.8 1021.8 0.1 0.9 254 0.0 0.0 4.2 454.4 5.4 8 10 2018 0 40 05.4 89 03.8 1021.8 0.0 0.0 254 0.0 0.0 4.2 454.4 5.4
you don’t say what version/build
I am running v10.37S (b81) on Windows 7.
