I did not receive any links to latest.csv files with the empty lines. So the only one I have seen was the file discussed above.
One dutch user switched to the 2018 release but has no FW fields in the latest.csv only in latestfire.csv Screenshot of his latest.csv attached.
How should he proceed to get the same files as shown above?
Update 2018-08-02 12:00 CEST
Thanks for the files I received. And for the solution: Only the test version in this topic can not be processed. The standard 2018 version is OK
I tested with plaintext.txt and lastret.txt => no problems.
The latest.csv from the 2018 version from the WXSIM website => no problems
The latest.csv from this message above has the two blank lines which move the lines with the UOM’s to an unexpected place.
If you want to use latest.csv, better wait until TOM has removed those two lines in a new (beta/test/final) version.
