Latest versions of Leuven Template and Scripts
I tried to move all links / information for the Leuven Template and Scripts to one location
Leuven-Template Download and support at support => template
Current version Template: 2.8x is fully PHP7.2 - UTF-8 HTML-5 HTTPS compliant
All scripts Download, Demo and support at support => scripts
Forecast scripts version 4 usable in all regions
[ul]
[li]WXSIM plaintext.txt / lastret.txt /latest.csv[/li]
[li]Met.no[/li]
[li]Yr.no[/li]
[li]WU[/li]
[li]Yahoo[/li]
[li]Darksky[/li][/ul]
For Canada 1 script using Environment Canada data.
For the USA 2 different scripts using NOAA/NWS data for a “Map-Click” type and 1 using SOAP data.
Other forecast scripts for UV and for HWA, a local Dutch provider.
AirQuality scripts for PurpleAir sensor and Luftdaten sensor both in two different versions
WeatherAlarm for Europe / Meteoalarm
WeatherUnderground stations-data is used for a “ColoredTables” type script and for another clone of the “WU-History” script.
All scripts are usable stand-alone and in the Saratoga Template directly from the download.
And most of them are also included in the Leuven-Template.
I will not post individual links anymore as they tend to change (my fault) to much.
So visit the scripts support or template support page and you will find all links there.
Now I have to scan all post to find other old links. If you find old links not working (404) or pointing to the wrong location, a Message with the URL of to the page would be very appreciated.
