Great stuff, version 2.7.1 works beautifully! Thanks, Mark.
P.S. the cheque’s in the post. . .
Brian got the WMR extra sensor tags working and I managed to rename buttons, gauge titles and pop-up info (and a few other things).
Thanks, Brian, for tags and thanks again, Mark, for max-min Inside Temps!
I am trying to do something similar. I do not care about humidex or indoor temperature and would like to replace one of these variables with %extratemp1%. I have added this to my customclient file and gave it the name garage. The customclient file is uploading fine and shows something like “garage”:“67.0”.
How can I modify the gauges to replace either the humidex or indoor temp with my garage tag?
Interestingly I did this several years ago but now can’t remember out how I did it. I seem to remember that I just found the humidex variable and substituted garage for it and it worked . I can not find where that variable is now.
I later changed the titles so the heading and the selector would say garage.
Any help will be appreciated.
Tom
As mentioned above, I changed from Inside temp/hum to Garden temp/hum.
First I edited customclientrawlocal.txt so that all 10 of Mark’s “in”-variables (“intemp”, “inhum”, etc.) pointed to the WD tags for the extra sensor data (like your %extratemp1%, %extrahum1%, etc.) instead of inside data.
Then I edited language.min.js and changed every “Inside” label under LANG.EN to “Garden”: to, e.g., temp_title_in:“Garden Temp” instead of temp_title_in:“Inside Temp”.
That changed the radio buttons, gauge labels and the pop-up max-min info from Inside to Garden. See http://swanston.maui.co.uk/gauges.htm.
Hope that’s some help.
Thanks. You jogged my memory and as you described is how I did it last time. I forgot I needed to change the WD tags to point to the extra data. I added the extra data as a new tag instead of just changing where the tags point.
Thanks again.
Tom
I see you changed Dew Point rather than Humidex or Inside temp!
Yes. Dew point was the only one I could change that showed a high and low for the garage. I could not figure out where the inside graph was getting the data. The customclient file does not contain the high and low values for indoor but does contain high/low for dew point.
I would have preferred changing the indoor metric since I like the pop up chart.
Tom
What version of Steel Gauges are you using? If you look at the earlier bit of the thread you will see that Mark only added the inside max/min temps/times in version 2.7.1.
Wow. I got the script from http://discourse.weather-watch.com/t/54526 which obviously is way out dated. I found 2.7.1 and will install it. I noticed the customcient does include indoor max/min.
Thanks. You have been a great help.
I’ll update the script and change the customclient to replace indoor variables with garage variables and see how it goes.
I still do not know how the indoor graph is now being generated since my current customclient does not include min/max for indoor vaules?
Tom
Sorry, I can’t help you with graphs! Haven’t got round to them yet.
Start a new thread and someone will chip in.
Indoor temp graph plots data from clientrawextra.txt
Thanks so even if I substitute the tags for my garage temperature and the high and lows for the garage they will not be graphed nor will the popup graph show the high/low temp. At least if I replace the values for dew point in the customclientraw file the popup will show the high and low temps for my garage.
I wonder why the tags for indoor high/low temps and time were added to customclient since the data comes from the extra file?
Tom
The wxgraphs and the steel gauges are separate. It’s convenient for the gauges to use the wxgraphs for the mouseover graphs but they were developed by a different author and quite a lot earlier. The wxgraphs use the standard wd clientraw*.txt files. The gauges use data from the customclientraw.txt file.
I sorta figured that was the case especially when I looked at some of the graph php files and saw the use of arrays. Anyway having the extra customclient tags available for indoor max/min temp and time are of now use to me since the graph data comes from the extra* file.
Thanks again for the explanation.
Tom
I would expect to see the min/max on your indoor temp gauge (colored quadrant) so maybe there’s something missed there - but I’m no expert on the gauges.
I loaded the newest version of the gauges and you are correct. The max/min are displayed in color. The popup graph still shows the inside temperature but the text at the top of the graph gives the high/low temps with the corresponding time for the garage based on the data in the customclient file.
Thanks again.
Tom
I turned the graphs off. I think I like just having the high/low data popup. To me the graphs were always hard to read. At least now the Garage graph shows the high/low colors on the graph itself.
Tom
I looked at your gauges and saw your Garage min was 56
Interesting. I just checked mine. The popup shows the lowest as -5572.8C, the same as what you saw. I also noticed the shading on the dial when set to C shows the wrong shading which I would expect given the values given on the popup. When set to F, my default, everything works fine as does yours when set to your default C.
Tom
Ah, you found a bug, well a typo…
Line 3573 of gauges.js (ver 2.7.1)
data.intempTL = convFunc(data.intempTl);
shoud be
data.intempTL = convFunc(data.intempTL);
roll on 2.7.2
