Author Topic: Extra temp/hum in SteelSeries Gauges (RESOLVED)  (Read 2281 times)
Offline bitsostring
  • Oregon Scientific WMR200
  • Edinburgh, UK
  • Mozilla compatible
    • Home Weather Station
« on: July 17, 2018, 04:55:03 PM »
I'm experimenting with alternatives to Weather Display Live anent the day Flash gets killed off for good, and one thing I'm really going to miss is the opportunity to display an extra temp (and, preferably, the extra hum that goes with it). Had a quick search and came up with Brian's tour de force on adding an extra gauge here, but I wondered if it could be done more economically (in terms of real estate!) by adding another (customisable) radio button under both the temp and hum gauges: so you would have the choice of displaying Outside/Inside/Extra Temp and Hum.
« Last Edit: August 12, 2018, 01:17:49 PM by bitsostring »
It's meant to be fun. . .
Offline mcrossley
  • Wilmslow, Cheshire, UK
    • none
  • Chrome 67.0.3396.99
    • WilmslowAstro Weather
Re: Extra temp/hum in SteelSeries Gauges
« Reply #1 on: July 17, 2018, 10:06:14 PM »
That sounds a reasonable approach.
You need to get the data into the customclientraw file first, then look at how I implemented the dewpoint gauge and just replicate some of that code.
If you are putting more options on there, you may also want to take a look at my gauges page where I have changed the radio buttons to drop down selectors
Mark
Offline bitsostring
  • Edinburgh, UK
« Reply #2 on: July 20, 2018, 04:37:54 PM »
Thanks, Mark.
As I really have no interest whatsoever in displaying inside temp/hum to all and sundry I then thought I could cheat by setting, e.g., "intemp":%extratemp1%, "inhum":%extrahum1%, etc., in customclientrawlocal.txt and then renaming the "Inside" radio buttons.
But I notice that there is no "intempTL"or "intempTH" to give max-min on the pop-ups (although "inhumTL" and "inhumTH" are present), and it's not exactly clear to me from WD's tagslist what tags I would use anyway!
Back to the drawing board. . .
P.S. No offence, but you have to click twice on a drop down menu to make a selection instead of just once on a button. . .
Offline mcrossley
    • none
« Reply #3 on: July 20, 2018, 04:42:46 PM »
Yes, lots of software doesn't provide that info.
Yep, but it's more compact, and scans better once set I think.
Mark
Offline bitsostring
  • Edinburgh, UK
« Reply #4 on: July 22, 2018, 09:38:20 PM »
So some software provides inhumTL, TinhumTL, inhumTH and TinhumTH but doesn't provide intempTL, TintempTL, intempTH and TintempTH? WD has tags for all these. . .
But WD doesn't seem to have tags for the corresponding extratemp/hum values that I was looking for!
Offline mcrossley
    • none
« Reply #5 on: July 23, 2018, 01:04:28 PM »
Looking at it, it is probably more likely somebody asked me at add indoor humidity min/max on day when I was feeling generous. I have conditional code around those values to suppress them for s/ware that doesn't provide the data.
« Last Edit: July 23, 2018, 01:36:10 PM by mcrossley »
Mark
Offline bitsostring
  • Edinburgh, UK
« Reply #6 on: July 23, 2018, 01:20:00 PM »
Found some WD tags that would work. . . don't suppose you're feeling generous today, are you?  :wink:
Offline mcrossley
    • none
« Reply #7 on: July 23, 2018, 01:38:35 PM »
Post the variable values and I'll put it on the ToDo list - which is currently pretty short ;)
Mark
Offline bitsostring
  • Edinburgh, UK
« Reply #8 on: July 23, 2018, 02:31:43 PM »
Thanks, Mark!
To be clear, if you could implement Inside Temp min/max to match the existing Inside Humidity min/max I reckon I could then substitute extratemp/extrahum WD tags for intemp and inhum in customclientrawlocal (and rename the radio buttons) for my own extra sensor without upsetting anyone who likes looking at indoor values!
Others may be interested in this idea, others may want all three (or more) temps, but all I'd be asking you to do is to complete (or round off) your existing set-up to show Outside and Inside min/max temp/hum.
WD tags for these variables ("intemp" is already there) would be:
"intempTL":"%minindoortemp%"
"TintempTL":"%minindoortempt%"
"intempTH":"%maxindoortemp%"
"TintempTH":"%maxindoortempt%"
There doesn't seem to be a tag for "intemptrend" to be consistent with "temptrend":"%tempchangehour%, but I don't think a trend is necessary anyway?
« Last Edit: July 23, 2018, 03:51:46 PM by bitsostring »
Offline bitsostring
  • Edinburgh, UK
« Reply #9 on: August 06, 2018, 02:15:21 PM »
Great stuff, version 2.7.1 works beautifully! Thanks, Mark.
P.S. the cheque's in the post. . .  :)
Offline bitsostring
  • Edinburgh, UK
« Reply #10 on: August 12, 2018, 11:37:51 AM »
As I really have no interest whatsoever in displaying inside temp/hum I then thought I could cheat by setting, e.g., "intemp":%extratemp1%, "inhum":%extrahum1%, etc., in customclientrawlocal.txt and then renaming the "Inside" radio buttons.
Brian got the WMR extra sensor tags working and I managed to rename buttons, gauge titles and pop-up info (and a few other things).
Thanks, Brian, for tags and thanks again, Mark, for max-min Inside Temps!
Offline nineback
  • Mac OS X 10.14.1
  • Chrome 70.0.3538.67
    • Tom's Weather Albertville, AL
Re: Extra temp/hum in SteelSeries Gauges (RESOLVED)
« Reply #11 on: October 20, 2018, 01:42:02 PM »
I am trying to do something similar.  I do not care about humidex or indoor temperature and would like to replace one of these variables with %extratemp1%.  I have added this to my customclient file and gave it the name garage.  The customclient file is uploading fine and shows something like "garage":"67.0".
How can I modify the gauges to replace either the humidex or indoor temp with my garage tag?
Interestingly I did this several years ago but now can't remember out how I did it.  I seem to remember that I just found the humidex variable and substituted garage for it and it worked . I can not find where that variable is now.
I later changed the titles so the heading and the selector would say garage.
Any help will be appreciated.
Tom
Offline bitsostring
  • Edinburgh, UK
  • Chrome 64.0.3282.140
« Reply #12 on: October 20, 2018, 04:40:10 PM »
As mentioned above, I changed from Inside temp/hum to Garden temp/hum.
First I edited customclientrawlocal.txt so that all 10 of Mark's "in"-variables ("intemp", "inhum", etc.) pointed to the WD tags for the extra sensor data (like your %extratemp1%, %extrahum1%, etc.) instead of inside data.
Then I edited language.min.js and changed every "Inside" label under LANG.EN to "Garden": to, e.g., temp_title_in:"Garden Temp" instead of temp_title_in:"Inside Temp".
That changed the radio buttons, gauge labels and the pop-up max-min info from Inside to Garden. See http://swanston.maui.co.uk/gauges.htm.
Hope that's some help.
« Last Edit: October 20, 2018, 06:23:05 PM by bitsostring »
Offline nineback
  • Mac OS X 10.14.1
« Reply #13 on: October 20, 2018, 07:21:29 PM »
Thanks.  You jogged my memory and as you described is how I did it last time.  I forgot I needed to change the WD tags to point to the extra data. I added the extra data as a new tag instead of just changing where the tags point.
Thanks again.
Tom
Offline bitsostring
  • Edinburgh, UK
« Reply #14 on: October 22, 2018, 09:50:49 PM »
I see you changed Dew Point rather than Humidex or Inside temp!
