Author Topic: Extra temp/hum in SteelSeries Gauges (RESOLVED)  (Read 2289 times)
Offline nineback
  • Mac OS X 10.14.1
  • Chrome 70.0.3538.67
    • Tom's Weather Albertville, AL
Re: Extra temp/hum in SteelSeries Gauges (RESOLVED)
« Reply #15 on: October 22, 2018, 10:09:24 PM »
Yes.  Dew point was the only one I could change that showed a high and low for the garage.  I could not figure out where the inside graph was getting the data.  The customclient file does not contain the high and low values for indoor but does contain high/low for dew point.
I would have preferred changing the indoor metric since I like the pop up chart.
Tom
Offline bitsostring
  • Oregon Scientific WMR200
  • Edinburgh, UK
  • Win NT 10.0
  • Chrome 64.0.3282.140
    • Home Weather Station
« Reply #16 on: October 22, 2018, 10:21:54 PM »
What version of Steel Gauges are you using? If you look at the earlier bit of the thread you will see that Mark only added the inside max/min temps/times in version 2.7.1.
It's meant to be fun. . .
Offline nineback
  • Mac OS X 10.14.1
« Reply #17 on: October 22, 2018, 10:42:14 PM »
Wow.  I got the script from https://www.weather-watch.com/smf/index.php/topic,54945.0.html which obviously is way out dated.  I found 2.7.1 and will install it.  I noticed the customcient does include indoor max/min.
Thanks.  You have been a great help.
I'll update the script and change the customclient to replace indoor variables with garage variables and see how it goes.
I still do not know how the indoor graph is now being generated since my current customclient does not include min/max for indoor vaules?
Tom
Offline bitsostring
  • Edinburgh, UK
  • Win NT 10.0
« Reply #18 on: October 22, 2018, 10:49:05 PM »
I still do not know how the indoor graph is now being generated since my current customclient does not include min/max for indoor values?
Sorry, I can't help you with graphs! Haven't got round to them yet.
Start a new thread and someone will chip in.
Offline niko
  • syzygy
  • Global Moderator
  • Northern California, U.S.A.
  • Win 7/Srvr 2008R2
« Reply #19 on: October 22, 2018, 11:28:19 PM »
Indoor temp graph plots data from clientrawextra.txt
Offline nineback
  • Mac OS X 10.14.1
« Reply #20 on: October 23, 2018, 12:15:17 AM »
Thanks so even if I substitute the tags for my garage temperature and the high and lows for the garage they will not be graphed nor will the popup graph show the high/low temp.  At least if I replace the values for dew point in the customclientraw file the popup will show the high and low temps for my garage.
I wonder why the tags for indoor high/low temps and time were added to customclient since the data comes from the extra file?
Tom
Offline niko
  • syzygy
  • Global Moderator
  • Win 7/Srvr 2008R2
« Reply #21 on: October 23, 2018, 12:46:18 AM »
The wxgraphs and the steel gauges are separate. It's convenient for the gauges to use the wxgraphs for the mouseover graphs but they were developed by a different author and quite a lot earlier. The wxgraphs use the standard wd clientraw*.txt files. The gauges use data from the customclientraw.txt file.
Offline nineback
  • Mac OS X 10.14.1
« Reply #22 on: October 23, 2018, 01:04:11 AM »
I sorta figured that was the case especially when I looked at some of the graph php files and saw the use of arrays.  Anyway having the extra customclient tags available for indoor max/min temp and time are of now use to me since the graph data comes from the extra* file.
Thanks again for the explanation.
Tom
Offline niko
  • syzygy
  • Global Moderator
  • Win 7/Srvr 2008R2
« Reply #23 on: October 23, 2018, 01:06:53 AM »
I would expect to see the min/max on your indoor temp gauge (colored quadrant) so maybe there's something missed there - but I'm no expert on the gauges.
Offline nineback
  • Mac OS X 10.14.1
« Reply #24 on: October 23, 2018, 01:40:36 AM »
I loaded the newest version of the gauges and you are correct.  The max/min are displayed in color. The popup graph still shows the inside temperature but the text at the top of the graph gives the high/low temps with the corresponding time for the garage based on the data in the customclient file.
Thanks again.
Tom
Offline nineback
  • Mac OS X 10.14.1
« Reply #25 on: October 23, 2018, 01:56:07 AM »
I turned the graphs off.  I think I like just having the high/low data popup.  To me the graphs were always hard to read.  At least now the Garage graph shows the high/low colors on the graph itself.
Tom
Offline bitsostring
  • Edinburgh, UK
  • Win NT 10.0
« Reply #26 on: October 23, 2018, 09:42:20 AM »
I looked at your gauges and saw your Garage min was 56F this morning. Selected the C button and got min -5572.8C.
So I checked my own gauges, which are normally set to C, and got Garden min 9.6C. Changed display to F and got min -17996.2F!
We need to find someone running an unmodified version 2.7.1 to compare notes on Inside max-min temps. . .
« Last Edit: October 23, 2018, 10:09:37 AM by bitsostring »
Offline nineback
  • Win NT 10.0
« Reply #27 on: October 23, 2018, 11:23:45 AM »
Interesting.  I just checked mine.  The popup shows the lowest as -5572.8C, the same as what you saw.  I also noticed the shading on the dial when set to C shows the wrong shading which I would expect given the values given on the popup.  When set to F, my default, everything works fine as does yours when set to your default C.
Tom
Offline mcrossley
  • Wilmslow, Cheshire, UK
    • none
  • Win NT 10.0
    • WilmslowAstro Weather
« Reply #28 on: October 23, 2018, 09:45:28 PM »
Ah, you found a bug, well a typo...
Line 3573 of gauges.js (ver 2.7.1)
Code: [Select]
                data.intempTL = convFunc(data.intempTl);
shoud be
                data.intempTL = convFunc(data.intempTL);
roll on 2.7.2 :)
Mark
Offline bitsostring
  • Edinburgh, UK
  • Win NT 10.0
« Reply #29 on: October 23, 2018, 10:30:16 PM »
Thanks, Mark! That fixed it.
« Last Edit: October 24, 2018, 10:42:24 AM by bitsostring »
