I recently updated WD to 37S73 having previously used a very old version.
I use a VP2 station and when I started the WD program I always saw a pop-up showing data being collected from my USB Logger. It was always satisfying to see this although at times it seemed to transfer data for a longer period than expected.
Since using the new version I on longer see this so has there been a change or have I a setting wrong.
I also now see another pop-up screen that shows the FTP passing the files. Again, do I have a setting wrong or is it working as intended.
Many thanks
make sure the switch is on under control panel, data logger
and re the FTP, make sure you have set to run as hidden in the system tray, in the connections setup in the FTP setup
