Author Topic: Windchill and Heat Index transposed? (RESOLVED)  (Read 2118 times)
Offline monadh
  • Scotland
  • Win NT 10.0
  • Firefox 61.0
    • Brora & Nethy Bridge Weather
Re: Windchill and Heat Index transposed?
« Reply #15 on: July 19, 2018, 09:00:34 PM »
Yes. Both are using build 74.
The WD build is automtically picked up a the bottom (after the Units Table).
Offline monadh
  • Scotland
  • Win NT 10.0
  • Firefox 61.0
« Reply #16 on: July 20, 2018, 11:39:53 AM »
The following link shows the two customclientraw.txt files on the server after ftp from the PC's running WD.
http://monadh.com/readcustomclientraw.php (updates every 10 secs)    :hello2: !!!! Link removed !!!! :hello2:
These PC's are identical, hardware and software, and are dedicated to running WD using fully up to date Win10 pro.
Observing the customeclientraw files it can be seen that the wind chill temp is nearly always in excess of the ambient temp on both sites.
« Last Edit: July 21, 2018, 07:46:36 AM by monadh »
  • Davis VP2
  • New Zealand
  • Win NT 10.0
  • Chrome 67.0.3396.99
    • Weather Display
« Reply #17 on: July 20, 2018, 07:44:50 PM »
use a new .zip update to fix (I needed a stronger coffee to see the mistake in the code)
Offline monadh
  • Scotland
  • Win NT 10.0
  • Firefox 61.0
« Reply #18 on: July 20, 2018, 08:38:25 PM »
Brian great :D Glad the stronger coffee worked :wink:
No wind at either site at present, but I assume the wind chill formula will kick in when the winds start blowing.
Thanks for your help.
Ray
Offline bitsostring
  • Oregon Scientific WMR200
  • Edinburgh, UK
  • Win NT 10.0
  • Mozilla compatible
    • Home Weather Station
« Reply #19 on: July 22, 2018, 01:01:38 PM »
Yes, seems to be OK now. Thanks again, Brian.
One more thing on windchill, for Mark: in customclientrawlocal.txt "TwchillTL" should point to tag %minwindcht%, not
%maxwindchillt%.
If people only want to see the minimum windchill temp we might as well show the right time!
« Last Edit: July 22, 2018, 01:20:50 PM by bitsostring »
It's meant to be fun. . .
Offline mcrossley
  • Wilmslow, Cheshire, UK
    • none
  • Android 8.1.0
  • Chrome 67.0.3396.87
    • WilmslowAstro Weather
« Reply #20 on: July 22, 2018, 01:59:05 PM »
Thanks, I'll get that fixed...
Mark
Offline monadh
  • Scotland
  • Win NT 10.0
  • Firefox 61.0
« Reply #21 on: July 23, 2018, 08:55:43 AM »
Mark, the standard windchill tags are:-
%windch% ...................current wind-chill
%windchnodp% ...............current wind-chill, no decimal place
%minwindch% ................minimum wind-chill
%minwindcht% ...............time this occurred
%maxwindchill% .............maximum wind-chill
%maxwindchillt% ............time this occurred
The one you used does not appear to work #-o, but "%minwindch% ................minimum wind-chill", works for me :)
Offline mcrossley
    • none
  • Win NT 10.0
« Reply #22 on: July 23, 2018, 12:03:10 PM »
Doh #-o I'll go fix the fix!  :oops:
Mark
Offline bitsostring
  • Edinburgh, UK
  • Win NT 10.0
« Reply #23 on: July 23, 2018, 12:18:59 PM »
Minimum windchill (wchillTL) tag (%minwindch%) was always correct in customclientrawlocal, it was time of minimum windchill (TwchillTL) tag (%minwindcht%) that was wrong.
« Last Edit: July 23, 2018, 12:32:00 PM by bitsostring »
Offline mcrossley
    • none
  • Win NT 10.0
« Reply #24 on: July 23, 2018, 12:55:30 PM »
OK, just to be 100% sure before I commit...  :wink:
Code: [Select]
    "wchill": "%windch%",
    "wchillTL": "%minwindch%",
    "TwchillTL": "%minwindcht%",
Mark
Offline bitsostring
  • Edinburgh, UK
  • Win NT 10.0
« Reply #25 on: July 23, 2018, 01:18:06 PM »
Code: [Select]
Yes, that's what is working for me!
Offline monadh
  • Scotland
  • Win NT 10.0
  • Firefox 61.0
« Reply #26 on: July 23, 2018, 06:35:08 PM »
Code: [Select]
Yes that is what I am using :D
