Author Topic: Twitter feed query  (Read 289 times)
Offline G4MHJ
  • Erith Weather
  • Davis VP2 + Solar/UV
  • Erith, Kent, UK
  • Mac OS X 10.13.5
  • Safari 11.1.1
    • G4MHJ-Home
Twitter feed query
« on: July 09, 2018, 11:40:46 AM »
I had to rebuild my system and I am stuck on the units of the feed.
12:30 PM 28.0oC(H28.9/L15.7), Hum 44%, Wind 3.1 mph ENE, Rain  0.0 mm, Solar 239 W/mē - Day time, UV 2.9 - Moderate, Skin Burn in 39 mins.
I am using %temp% but as you can see it is showing 28.0oC.  How can I get it to show the correct degrees sign?
  • Davis VP2
  • New Zealand
  • Win NT 10.0
  • Chrome 67.0.3396.99
    • Weather Display
Re: Twitter feed query
« Reply #1 on: July 09, 2018, 06:55:46 PM »
the correct one is not compatible I think you will find with twitter
instead you would need to unset to use units in the custom tags and then try and use a key# that is equivalent or a html tag to show it or similar
(there has been other threads about this)
