Stop sending data to meteotemplate et weathercloud
Hello,
sending data to meteotenplate stops after a few hours a dozen on average
I am obliged to restart WD for the normal return
if i try to reprogram control panel> meteotemplate it does not work
on the other hand if I run cronhttpget manually the data are well received by meteotemplate
/home/lucien/T
do you happen to have set to use the fast send to meteotemplate option?
that seems to cause a problem
one solution could be to have a script program run the cron program to send to MT and weather cloud
I am set at 5 minutes for meteotemplate
I run programs cronhttpget and croncloud
in a script?
yes, you could try that
Hello
It does not work in a script, cronhttpget and croncloud start well but the update of the data is not done, however the data from weatherhub are still done in the GUI of WD
on the other hand, I notice that WD has a lot of hours taking more and more memory, at the launch of WD 17.6% of memory used after ten hours 97% of memory used by WD
and more data transmission
or can we see the logs of WD?
thank you
Hello,
my problem is a memory leak as indicated in the post below:
but the reboot once a day is too long for me
so I wrote a bash script that restarts according to the memory consumed by WD
you define it in the script
and it works very well
Brian Thanks for your answers and this forum that helped me
Lucien
Bonjour,
mon probl
revival_WD.zip (486 Bytes)
hello
script used in a cron :smiley:
I seemed to have been confused (easy )
originally I thought you were refering to the linux version consolewd
but you were refering to the linux version v 10.37Linux Build 296
