Data from weatherlink.com incorrect
Hi Brian
when i use weatherlink.com option to connect WD by weatherlink account , the extreme data detected do not correspond to the real data.
The daily max gust detected as max average wind speed
the MAx or MIN temp. differ by one tenth of a degree from real value Eg: 24.2
there might be a rounding error with the temperature (from F to C)
but also make sure you do not have any temperature offset set in WD
I am not sure exactly what you are meaning about the wind
need more detailed information (eg screen shots etc)
for the temp i’m sure that haven’t a offset
thr wind is the same for the gust and average
as the main graph show in attachment…
ah
re the wind
if you could message me your weatherlink.com settings, I will see about fixing that
