Author Topic: ARM 64bit and consolewd  (Read 1157 times)
Offline UW
  • Mac OS X 10.13.5
  • Chrome 67.0.3396.99
« on: July 05, 2018, 05:36:48 PM »
Is there a version of consolewd for the ARM 64bit architecture?
I would need it to be run on a Synology DS218play.
  • Davis VP2
  • New Zealand
  • Win NT 10.0
  • Chrome 67.0.3396.87
    • Weather Display
Re: ARM 64bit and consolewd
« Reply #1 on: July 05, 2018, 05:57:55 PM »
yes there is
there is one for the raspberry pi 3 (64 bit) and 64 bit Linux Desktop
see the linux download page
Offline UW
  • Mac OS X 10.13.5
« Reply #2 on: July 08, 2018, 01:21:52 PM »
I did as you suggested and did download, unzip and install according to the readme.txt.
For the Weather Display for Linux console 64 bit Raspberry pi3 if I execute ./consolewd I get:
-ash: ./consolewd: No such file or directory
For the Weather Display for Linux console 64 bit Linux desktop if I execute ./GoWdconsole.sh I get:
ERROR: You can't run this as ROOT. Change to another user and try again.
If I log in as another user than root I get:
./consolewd: ./consolewd: cannot execute binary file
Any help to this?
« Last Edit: July 08, 2018, 01:31:42 PM by UW »
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #3 on: July 09, 2018, 12:06:36 AM »
those errors usually occur when you are running the wrong archetecture (i.e 64 bit on 32 bit or vice versa)
Offline UW
  • iOS 11.4
  • Safari 0.8.2
« Reply #4 on: July 09, 2018, 07:05:10 AM »
This is what I thought, too.
When I do a
Code: [Select]
uname -a I get
Code: [Select]
Linux IoT_Chalet 4.4.59+ #23739 SMP Sat May 19 03:08:07 CST 2018 aarch64 GNU/Linux synology_rtd1296_ds218play
So to me it is an ARM64 architecture. Any other ideas?
I am running consolewd on another Synology system that has an x86_64 architecture without any problem. It looks to me as if the ARM64 version of consolewd is not entirely compatible or having some components left from the x86_64 version (maybe in the deploy folder).
« Last Edit: July 10, 2018, 02:14:53 PM by UW »
Offline UW
  • iOS 11.4.1
  • Safari 0.8.2
« Reply #5 on: July 12, 2018, 08:46:56 AM »
Since it is a problem of 32 or 64bit code, could it be that any of the files in the deploy folder are rather 32bit than 64bit?
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #6 on: July 12, 2018, 09:25:56 PM »
you could try copying the deploy folder from the working version to your current version and then copy the files to /usr/local/lib/ and /usr/lib/
as a test
Offline UW
  • Win NT 10.0
  • Chrome 52.0.2743.116
« Reply #7 on: August 06, 2018, 12:13:25 PM »
I did as you suggested - unfortunately without any success.
To further check I did copy all consolewd files including the ones in the deploy folder from the working x86_64 kernel based NAS to the other NAS that is aarch64 based, unfortunately without any success, too.
So what I can say for now is:
The 64 bit consolewd is running on x86_64 kernel based NAS Synology DS216+II.
The 64 bit consolewd is not running on aarch64 (ARM64) kernel based NAS Synology DS128play.
Is there any way you could compile a version for the ARM64?
Thank you for your support
Urs
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #8 on: August 07, 2018, 07:58:39 AM »
the raspberry pi3 version is compiled for ARM64
Offline UW
  • iOS 12.1
  • Safari 0.8.2
« Reply #9 on: January 10, 2019, 02:51:33 PM »
I did use and install the latest version (Weather Display for Linux console 64 bit Linux desktop Version on 7 September 2018) - and it worked perfectly on my Synology NAS.
Thank you
  • Davis VP2
  • New Zealand
  • Win NT 10.0
  • Chrome 71.0.3578.98
    • Weather Display
« Reply #10 on: January 10, 2019, 06:45:37 PM »
that is good
I think I had the 32 bit version as the 64 bit version at one stage on the download page
