Can't download data from Davis.
For some odd reason wdisplay will not download any data. I can’t even open the data logger when I click the icon nothing happens. I tried another program and it started the download just fine. I hope someone can help this is driving me mad.
David
re the data logger icon
it might be that that setup screen is opening off screen
what shows in WD under view, debug info?
what shows across the top of the WD program?
does live data work ok from your davis station?
the more information you can provide the better
it might be that the solution is you need to do a complete power down and reset of the data logger
Serial or USB logger?
Have you used it with Davis Weatherlink software?
It shows success in connecting to comport 3 nothing else. I’ve been using wdisplay for a good while,and it’s always worked just fine. This just started happening recently. I can click any other icon in control panel and it opens just fine. I’ve uninstalled ,no matter what I’ve tried data logger will not open .
I opened cumulus and it started reading the data just fine.
I found the problem, I just don’t know how it happened . Somehow the check mark in station type was unchecked. I thank you for the help.
