I am testing it… but not apreciable diference. I can’t see stationid (and also I can’t put apikey to avoid all people use yours).
And it is the last test version, because has MQTT option (this is the next thing I have to try with OpenHab).
Ruben
Ruben
The station id
Should be showing
Just after where it says
Station id:
That works for me
Maybe u do not have the latest
Cronopenweathermap.exe
That is included in the latest full install
You might want to blank your password in that screen shot?
Thanks, I don’t realize that WUnderground password appears bottom ;-)… :lol: Thanks!
I have replaced with the Cronopenweathermap.exe that is on last weatherdisplaytest.zip
Is this ok?
No Id yet… maybe I need to change lat/lon/name?
I think could be better that we could put our own apikey, or we can’t recover data from our station (as we need to put always apikey to see it).
Ruben
PD: Maybe a apikey textbox, plus a button “Create station” that returns and fill station id, could be great
just tested here again
brand new setup
it works
(after clicking on test and then go back into that setup)
see the attached
http://www.weather-display.com/downloadfiles/cronopenweathermap.zip
Working last update!
I have to remove blank whitespaces on station name… maybe this was the problem before.
Ruben
spaces should never be used on the internet for data ideally (use _ instead of a space if you need to use a space)?
Could you consider the option of putting the apikey also?
In other case, this is not very useful as we can’t read our station data…
Thanks in advance
Ruben
Enviat des del meu SM-T280 usant Tapatalk
normally developer api keys are not supposed to be made public
I could make it where the aggregated data is downloaded at each data send to a file
but what is the point of that…you know your data anyway, you are sending it from WD?
Exactly, not your apikey, each user must put his apikey (like un WU you each user must put his user and password)
Now I can’t know if I am sending anything, I can’t retrieve my station data (for example to do some application, or to use in OpenHab). In fact, I can’t know if all is working correctly, or delete my station.
Moreover, with a little computer skill (very little), actually anybody can retrieve your apikey, watch all the stations that WD (and you) have created, delete it, etc.
I think that the correct working process is that anybody that want to send his data to OWM, needs his apikey to put in WD to manage his station (like other providers).
Ruben
OK, i will make it so that you can enter your own api key
i have done that now in the latest .zip update (normal download)
Just played with the site, at first it was showing California, switched the C to F button, reloaded was still in C. Searched for Phoenix only showed text reports, went back to the map and it was now showing Africa. Seems very buggy
I think you are talking about the openweathermap site?
re WD’s cronopenweathermap
so the first time run, it gets the stationid
and the first data sent works (returns 204)
and that stationis is store for next time…and so next time its run, it uses that initial stationid …but the data sent has a return code of 415 instead of (successfull ) 204
what gives
I will try when I have some time… There are any setup to see “debug messages” from WD to help you to debug that?
but that is the debug info I have provided (the return codes)
I have checked the new version, putting my apikey, and it doesn’t create any station. Maybe this is the reason to give you that error.
I have done this:
https://api.openweathermap.org/data/3.0/stations?appid=ab19d2XXXXmyapikey
And it returns only one station, the one that I create manually some days ago:
[{“id”:“5c927d03XXXXstationid”,“created_at”:“2019-03-20T17:48:51.914Z”,“updated_at”:“2019-03-20T17:48:51.914Z”,“external_id”:“OWMALCOIBARA1”,“name”:“Alcoi - Baradello Gelat”,“longitude”:-0.52167654,“latitude”:38.70305252,“altitude”:810,“rank”:10}]
Ruben
yes, I can use that call
and get a list of the stations I have created under my api key
e.g
[{“id”:“5c9af1316c634e000131b766”,“created_at”:“2019-03-27T03:42:41.184Z”,“updated_at”:“2019-03-27T03:42:41.184Z”,“external_id”:“AW_TEST001”,“name”:“Awhitu Test Station”,“longitude”:173.43,“latitude”:-37.76,“altitude”:150,“rank”:10}
but when I try to send measurements to a previous created station ID I get that 415 return code (instead of 204)
are you able to send measurements?
