I have identified and fixed where some FTPS/SSL servers (i.e TLS 1.2)
where there was a 301: Timeout. error
use this update
http://www.weather-display.com/downloadfiles/ftpupd.zip
i.e unzip/extract to where you have WD installed
vers 9.06 of the FTP program
rh205
2
I can confirm that the new ftpupd.exe has solved the 301 timeout error for me and all files are uploading correctly now.
However I still get the 301 timeout error when using the clientrawrealtimeftp.exe version 9.9.
I am running WD Ver 10.37S73.
I have attached a copy of the ftprealtimelog that shows where the 301 error is occurring.
Many Thanks,
Ross.
clientrawftp.txt (4.12 KB)
i have updated the clientraw program too
http://www.weather-display.com/downloadfiles/clientrawrealtimeftp.zip
this was a hard one to crack but in the end was just 1 line of code
hopefully though it does not upset currently working FTPS connections
