Data not reporting to Weather Underground
I am new to Weather Display.
I have recently setup. Everything is reporting ok apart from WU.
It says my station is not reporting.
When i had Cumulus it always used to stay active even on the WU Map. It was working earlier but for some reason it says not reporting for over 3 hours. Maybe i have messed with a setting? :slight_smile: Any help will be great. Thank You.
try setting times to send (e.g every 10 minutes) and turning the main switch on
then try clicking on test send
and see what shows
also make sure the main internet switch is also on under control panel, ftp/internet setup, connections setup
I did that. I also went to relogin to WU and it would not let me. So i requested a password reset and it told me the information i entered was incorrect. It is sounding more like a server issue their end as our station seems to appear still on the map with a old reading of 25C which was reported over a few hrs ago. All posting to Met Wow and Twitter with no issues.
check in the file
sentwudata.txt
and then put the data that is shown there that is sent into a browser window and hit return/enter and see what the return result is
401 not authorised
that is the problem
its either a problem with the username (note, that is case sensitive) or the password (do not use strange symbols etc))
