Weather and the Internet > Creating Weather Web Sites
Weatherlink API
(1/1)
aardvark:
I just got this email today.  Iam fine  but there are others who might need it
As our move to WeatherLink 2.0 proceeds, we are approaching an important update that will affect anyone using the WeatherLink 1.0 API. This may affect you if you use the current API to:
Display data on a personal or community web page.
Share data with a 3rd party service that is dependent on the API.
Access your weather data from our servers.
The current www.weatherlink.com/xml.php API is scheduled to be decommissioned at the end of July, 2018. The new api.weatherlink.com/v1, available in JSON and XML formats, will be the ONLY functioning API after July 2018. This API works for WeatherLink 1.0 and 2.0 and can be used immediately, but it requires the use of a unique API token.
To generate a unique API token: Watch the Generate API Token video
Log in to WeatherLink 2.0 using existing WeatherLink user credentials.
Access the account information in the right sidebar, under the username and account picture.
On the account information page, click Generate API Token.
Fill in the required fields and click the Generate button.
The unique API token will display in the API Token field.
These important changes will help us make continual improvements to the API so that you can access your personal weather station data or share it with 3rd party services faster and with maximum reliability.
If you are aware of any person or 3rd party that may use the WeatherLink 1.0 API, please help us spread the news of the upcoming changes.
Thank you,
All of us at Davis Instruments
Weather Display:
I have confirmed that using this generated code does work when you enter that into WD
Navigation
[0] Message Index
Go to full version
