Brian
Have had to run a rainfall calibration on Davis rain gauge and I want to remove all calibration data from records … Where can I do it in one go. ??
Tried to use “Log / data file viewer/ Correct Data” screen but with no instruction / info it is VERY difficult to work out and make sense of it …
Is there a better way?? and what files are needed to be corrected …?
you can set your needed rain totals under
control panel
offsets and initial rain
for past day rain totals, I do have a youtube video detailing the steps
Brian
adjusted rain in control panel / Offsets & initial rain and set month total to zero [0.0] WD display “Month to Date” cleared to zero …BUT
When clicked on “yes” button to save settings that window closed and the original “Month to Date” [incorrect] value returned …
Closed pgm and restarted but still displays original incorrect value
you need to click on set, next to each rain total (day, month, year)
then click on yes to save
