Problem with uploading to wunderground. Anybody else?
Anybody else having issues with uploading to wunderground.com? I keep getting the 400 error below for over two weeks now and their “support” is utterly useless / non-existent. (I removed the - correct - password below).
https://rtupdate.wunderground.com/weatherstation/updateweatherstation.php?realtime=1&rtfreq=10&action=updateraw&ID=KOHWESTC5&PASSWORD=*******&dateutc=2018-06-16+20%3A49%3A06&winddir=117&windspeedmph=1.2&windgustmph=0.0&humidity=56&tempf=90.7&rainin=0.000&baromin=29.965&dewptf=72.8&indoortempf=79.3&indoorhumidity=47&weather=CLR&clouds=FEW&dailyrainin=0.000&soiltempf=&soilmoisture=&leafwetness=0.0&softwaretype=WeatherDisplay%3A10.37S
Bad Request
151: HTTP protocol error. 400 Bad Request.
4:49:16 PM
wunderground have been having lots of problems lately
It’s not you, it’s WU
There is no problem with me.
Everything works normally.
https://www.wunderground.com/personal-weather-station/dashboard?ID=IOLOMOUC23
Uploading seems OK here but they seem no longer able to display the webcam image from my own URL - for weeks now.
Also hard to tell if rapidfire works or not - it could be something to do with flash and chrome not playing, but for me it isn’t updating every few seconds anymore but does show latest when you first go to it which is reasonable.
Must echo almost total lack of support, they want you to find an answer in FAQs which is fair enough but when you can’t and eventually work out how to send a message you would expect a response within a few days but nothing happens at all.
The impression you get is that they wish the station uploads would die slowly and go away.
Looks like Wunderground has only started to pick up better quality stations because of overloading the server.
Maybe it’s just my impression, I really do not know.
About 10 stations were available in my area, but as you can see in the picture, I stayed there myself.
None of the stations were VP-2 just mine.
I saw a comment recently that they had shut down all feeds from Netatmo stations, but that has turned out to be incorrect…
Well, not sure what they do - over 3 weeks no updates and zero support response. The data quality of my Davis VP VUE is excellent, CWOP reports 99%-100% all the time and even on wunderground it was issued the “golden badge” for accuracy. I’ll probably just delete the account and let them do whatever they think they want to do. Kind of a bummer having them supported for so many years with free data and then the whole things seems to go down the drain with nobody caring anymore.
what shows when you put the data that WD sends (see the sentwudata.txt file) into a browser window had hit return
Nope, it’s true https://www.netatmo.com/en-US/helpcenter/weather/1/my-weather-station-does-not-appear-on-weather-underground-is-this-normal/55
It just shows “bad request”.
http://weatherstation.wunderground.com/weatherstation/updateweatherstation.php?ID=KOHWESTC5&PASSWORD=**********%R&dateutc=2018-06-16+20%3A42%3A00&winddir=146&windspeedmph=0&windgustmph=0&humidity=57&tempf=90.0&rainin=0.000&baromin=29.963&dewptf=72.8&indoortempf=79.4&indoorhumidity=47&weather=CLR&clouds=FEW&dailyrainin=0.000&soiltempf=&soilmoisture=&leafwetness=0.0&softwaretype=WeatherDisplay%3A10.37S&action=updateraw
I just saw in sentwudatamissed.txt, that there was a comment about not having loaded an SSL library - could this be related?
https://weatherstation.wunderground.com/weatherstation/updateweatherstation.php?
ID=KOHWESTC5&PASSWORD=**********%R&dateutc=2018-07-
30+14%3A34%3A00&winddir=134&windspeedmph=2&windgustmph=21&humidity=72&tempf=72
.6&rainin=0.000&baromin=30.009&dewptf=63.0&indoortempf=72.9&indoorhumidity=47&weather
=CLR&clouds=FEW&dailyrainin=0.010&soiltempf=&soilmoisture=&leafwetness=0.0&softwaretype
Could not load SSL library.
what version/build of WD?
