Need help editing below the menu bar
I use updated Saratoga, and WD.
It’s been a while since I worked with it, but I need the file name I can use to edit my site just below the menu bar on the left. I’ve been searching for a few hours to no avail. Any help would be welcomed.
Rick Reynolds
www.MohawkValleyWeather.com
I think you are speaking of menubar.php
Try ‘flyout-menu.xml’, see if that works.
Maybe https://saratoga-weather.org/wxtemplates/menubar-config.php would be helpful?
Yes, editing flyout-menu.xml allows you to add additional links to the flyout menu on the site.
Adding stuff below that (and the theme options selection) means editing menubar.php itself. Look for
      </div><!-- end leftSidebar -->
</div><!-- end doNotPrint -->
<!-- end of menubar -->
and put your stuff ABOVE those lines. Example
<p class="sideBarTitle" style="text-align:center">My Links</p>
<ul>
   <li><a href="http://some.site.com/" title="first site">Site 1</a></li>
   <li><a href="http://some.othersite.com/" title="second site">Site 2</a></li>
</ul>
Hope this helps…
menubar.php did the trick… Thanks!
